40 spline stub shaft seal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-14-2016, 09:48 AM   #1 (permalink)
Member # 54530
What are u guys using for 40 spline dana 60 stub shaft seals?
73 F-250 44 boggers,428 big block on propane,d60 front,40 spline d80 rearsteer,ARB/Spool,PSC full hydro steering, dual winches
73 ford guy is offline   Reply With Quote Quick reply to this message
Old 08-14-2016, 09:54 PM   #2 (permalink)
K5runner@hotmail.com's Avatar
Member # 96153
Stock lip seal on my CTM stubs, with a bunch of tacky mining grease. BUT I don't do water crossings or mud....... Although some for the U4 tracks can get muddy at certain spots. I also suck/pull the stub out to the drive flange so I don't break that seal. A few years of racing and I have never seen dirt inside......
Offroad Design ♦ Atomic MC ♦ Jantz Engineering
K5runner@hotmail.com is offline   Reply With Quote Quick reply to this message
Old 08-14-2016, 10:22 PM   #3 (permalink)
Member # 54530
I seen this other thread on here about the superduty model 60's using a different seal and can be a better upgrade choice. Any thoughts?
Originally Posted by Subybaja View Post
Yeah, calipers, brackets, and spindles all have to come off to pull the axle shafts out.
Bearing reassembly:
https://www.pirate4x4.com/forum/gener...g-preload.html
Keeping the socket on the locknut is a PIA. I used a 6" extension, with a jackstand under the end to keep it aligned during final torque.
Take the locknut with you to make sure you get the right socket. The parts monkeys will be happy to sell you one for a D44!
If you get the type of socket that has a collar over the lugs, be sure that you have room inside the spindle for it. Otherwise, just get the kind with 4 tabs sticking out.
You might also think about Longfield spindle bushings while you're in there:
https://www.trail-gear.com/TG/Longfi...694-2-KIT.aspx
They replace the little needle bearings (and seal and thrust washer) inside the spindle, which support the stub axle:
You can upgrade the axle-to-spindle seal/slinger to a '99+ Superduty seal as well. This replaces the whole shebang, and rides on the inside face of the spindle.
Dana Spicer Part 50381 - Dana 60 Spindle Seal - 4 Wheel Parts
Old 05-05-2017, 02:25 AM   #4 (permalink)
gt1guy's Avatar
Member # 236179
Bringing this back up.
I've got the Solid 40spline D60 spindles. I had read someone was making a bushing which I can't seem to find anywhere. Also, need some kind of seal too.
Can someone point me in the right direction?
Kevin
gt1guy is offline   Reply With Quote Quick reply to this message
Old 05-09-2017, 11:13 AM   #5 (permalink)
Member # 727649
Can you give me the dimensions of what you need for a seal? We may have something in stock that will fit.
Seals-it is offline   Reply With Quote Quick reply to this message
Old 05-10-2017, 10:18 PM   #6 (permalink)
gt1guy's Avatar
Member # 236179
I'll get those dimensions for you tomorrow. Thanks
Kevin
Old 05-11-2017, 07:24 PM   #7 (permalink)
gt1guy's Avatar
Member # 236179
Here you go. Spindle I.D. for seal is 3.375", and the depth is .200". Axles are 40spline so I believe that's 1.72" diameter.
Anyone else have a line on a bushing for the Solid 40 spline Chevy spindles? The dimensions are in the picture.
[IMG][/IMG]
Kevin
Old 05-16-2017, 12:38 PM   #8 (permalink)
Member # 727649
[IMG][/IMG]
Sorry nothing we currently carry is that narrow.
Old 06-13-2018, 04:52 PM   #9 (permalink)
Member # 174674
Are 40 spline stub shafts/inners still available?
enginetech is offline   Reply With Quote Quick reply to this message
Old 06-14-2018, 01:50 PM   #10 (permalink)
Member # 96153
CTM has nothing on the shelves except for raw material and U-joint.
They will make whatever you want in whatever configuration you want it in....
Just give Jack a call.
Old 06-15-2018, 06:39 AM   #11 (permalink)
GiS
GiS's Avatar
Member # 31285
Spidertrax?
Rock Posse Racing #686
Driver: Joey Weber
GiS is offline   Reply With Quote Quick reply to this message
Old 06-15-2018, 08:31 AM   #12 (permalink)
Bunk's Avatar
Member # 41059
Send a message via Yahoo to Bunk
Branik?
Bunk is offline   Reply With Quote Quick reply to this message
