weld on misalignment washers? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-28-2016, 01:49 PM   #1 (permalink)
whitneyj's Avatar
Member # 135947
I'm looking for misalignment weld washers and I know I've seen them on a few builds here, but my google-foo can't dig them up. Anyone know where I can get some? Anyone have any experience with them? I figure a weld misalignment washer kills two birds one stone, but I'm not sure on the amount of misalignment they'll offer versus a misalignment spacer...
Something along these lines.
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is offline   Reply With Quote Quick reply to this message
Old 09-28-2016, 02:06 PM   #2 (permalink)
skullver's Avatar
Member # 60364
Don't most misalignment spacers also reduce bolt size and seat within the joints?
Not exactly what you're looking for:
http://www.allensfasteners.com/searc...3&txtCatName=2
:flipoff2::flipoff2::flipoff2::flipoff2::flipoff2:
skullver is offline   Reply With Quote Quick reply to this message
Old 09-28-2016, 02:14 PM   #3 (permalink)
whitneyj's Avatar
Member # 135947
Weld Washers
They do and the application I'm looking to use them in I definitely don't need to NOT step down in bolt size.
Those look like they'd work, but I'm looking for a 1" ID. That's the other trick....
Old 09-28-2016, 02:24 PM   #4 (permalink)
skullver's Avatar
Member # 60364
That's a double redundant statement? Are you meaning to say you do NOT want to step down?
Why not get some thick walled 1" ID tubing and turn a generous chamfer on the inside facing edge?
I don't think I've ever seen any 1" ID misalignment spacers.
Aw, sort of what you're looking for:
https://www.sneveysoffroad.com/misal...off_road_parts
Old 09-28-2016, 02:37 PM   #5 (permalink)
whitneyj's Avatar
Member # 135947
I can't English today, sorry about that...
I wouldn't necessarily benefit from the step down but there isn't a benefit to keeping the 1" diameter bolt by not stepping down. I have hardware in both 3/4" and 1" sizes.
I have 1" ID tubing, I just don't have ready access to a lathe anymore. I'd like to buy a set to bolt to a joint to verify range of movement between that and a spacer that steps down to 3/4". If the compromise is small then I'll just go that route.
Old 09-28-2016, 02:49 PM   #6 (permalink)
skullver's Avatar
Member # 60364
Belt sander? Angle grinder? Spacer and bolt through the tubing and chuck it up in the drill press, remove material with material removal device?
Good luck.
Old 09-28-2016, 03:51 PM   #7 (permalink)
Member # 110135
ruffstuff
Power Giant is offline   Reply With Quote Quick reply to this message
Old 09-28-2016, 05:02 PM   #8 (permalink)
Member # 224958
I've seen people weld safety washers on as misalignment washers.
Safety Washer
CarolinaCrawler1 is offline   Reply With Quote Quick reply to this message
Old 09-28-2016, 07:58 PM   #9 (permalink)
whitneyj's Avatar
Member # 135947
Originally Posted by Power Giant View Post
ruffstuff
I looked everywhere on their website and didn't see any.
Old 09-29-2016, 06:27 AM   #10 (permalink)
Member # 21282
I drew some up and wanted to go that route but couldn't get any interest from suppliers or someone with a lathe.
you lose ALOT of misalignment not reducing the bolt size. Jesse Haines uses spacers all the time and seems to get away with it just fine.
Recommended Stuff:
91blaze is offline   Reply With Quote Quick reply to this message
Old 09-29-2016, 06:42 AM   #11 (permalink)
Member # 110135
Safety Washer
I Googled "misalignment spacer" and Ruffstuff was the first item on the list.
Old 09-29-2016, 08:43 AM   #12 (permalink)
Member # 110135
Qa1
Poly Performance
Rod End Supply
Barnes
Artec
Trail Gear
RuffStuff
Old 09-29-2016, 10:26 AM   #13 (permalink)
whitneyj's Avatar
Member # 135947
I'm not looking for a misalignment spacer. Read the thread. Everyone sells misalignment spacers, but no one seems to sell a weld on misalignment washer.
Old 09-29-2016, 10:28 AM   #14 (permalink)
whitneyj's Avatar
Member # 135947
THAT's where I've seen it done....
91blaze, what size joint and ID did you draw up? Still have those files?
@mudtruck44, can you shed some light on this for me please? Otherwise I can pm/message you.
Old 09-29-2016, 10:34 AM   #15 (permalink)
Member # 55444
Everyone sells HIGH missalignment spacers. You're still looking for a spacer, just one that doesnt neck down the bolt.
Like these?
BTF Misalignment Spacer (1") BTF07007 – Blue Torch Fabworks, Inc.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 09-29-2016, 10:38 AM   #16 (permalink)
whitneyj's Avatar
Member # 135947
Like these?
Ah, good call on the high part....
That'd be what I'm looking for, yup. I've found SS ones, but not chromo or mild steel ones.
I figured I'd lose some angle to the joint, but if it's a considerable amount, then I'd like to hear how Jesse uses them successfully. Otherwise I suppose I'll just have to use chromo weld washers and high misalignment spacers.
Old 09-29-2016, 10:39 AM   #17 (permalink)
skullver's Avatar
Member # 60364
Like these?
Unless he's building the bracketry out of stainless also, he's looking for weldable spacers, from what I can tell.
Old 09-29-2016, 10:39 AM   #18 (permalink)
Member # 55444
Or these.
1.00" Heim Spacers
Old 09-29-2016, 10:40 AM   #19 (permalink)
Member # 55444
You can weld stainless to mild steel. Done it more times than I can remember.
It loses the rust free characteristics at the weld, but it still stays.
Old 09-29-2016, 10:47 AM   #20 (permalink)
whitneyj's Avatar
Member # 135947
What wire and gas? I remember trying years ago and couldn't get it to lay a bead. I could tack it, but that was it.
Those shock spacers you posted up are too thin. I'm looking to keep the width of the bracket to the standard 2 5/8", or 3", in case I get froggy and want to go with whatever.
The BTF ones look like a solid option though. I may buy a set from them and if they work for me I'l see if they'll spin some from mild. Or else I'll just get my own lathe and make them....
Old 09-29-2016, 10:47 AM   #21 (permalink)
Member # 21282
I still have them somewhere
they are for a 1.25 heim and include a weld washer portion on them
Recommended Stuff:
Old 09-29-2016, 10:55 AM   #22 (permalink)
whitneyj's Avatar
Member # 135947
Yikes... That may not be worth it then. That looks to have cut misalignment by nearly 1/2....
Slick design though. I may run with that for my trackback
Old 09-29-2016, 11:21 AM   #23 (permalink)
Member # 21282
I think it cuts misalignment to 12 degrees or so EDIT: maybe 18? I'll look soon and let you know
each direction so total 24 degrees.
I had the suspension all set up and it just barely works but you have to get the brackets in the exact right spot and angle
my thoughts were to have all my parts plasma cut and hole quality didn't have to be great with these.
I went with a goatbuilt kit though and didn't need these.
I think that little chamfer got a few extra degrees. I'm not sure how Jesse gets away with dom spacers but he does and does well. Part of it will be shorter shocks. I don't think you need that much articulation as everyone is getting to perform well but I didn't want my joints to be the limiting factor. They would probably self clearance with little to no affect.
Recommended Stuff:
Old 09-29-2016, 11:24 AM   #24 (permalink)
Member # 21282
Now you could put a bushing inside the heim only and make these smaller diameter and get alot of misalignment back. If you want to mess with a second piece or convince someone to only drill out the center to 3/4 when manufacturing
Recommended Stuff:
Old 09-29-2016, 12:46 PM   #25 (permalink)
whitneyj's Avatar
Member # 135947
I had thought about that too, but for $5 a high misalignment spacer from Ruffstuff I'm not sure it's not worth my time to have someone else make them. I'm looking at getting a lathe, so maybe I'll try a few this winter.
