Spool & Gear Cost for Dana 60 & 44 ??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-09-2002, 11:20 PM   #1 (permalink)
Member # 2757
What should i expect to pay for 4.56 or 4.88 with spools
DANA 44 WAGGY 1984 DRIVERS SIDE DIFF (has 3.31)
DANA 60 FORD 1979 REAR FULL FLOATER (has 3.45)
Just trying to price out, if i should just weld an open carrier locked, or just go with a spool and r/p...
what do yall think?
ESREVER NI EVIRD
SMART ASS is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 12:56 AM   #2 (permalink)
Member # 5472
Im welded front and rear. For sure just weld the rear.
Did you ever notice: When you put the 2 words "The" and "IRS" together it spells "Theirs?"
spoolnaround is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 07:14 AM   #3 (permalink)
Member # 6291
let me know when you find a 30-spline spool for that rear D60 you've got ...
morpheus is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 08:01 AM   #4 (permalink)
The Piratenite
camo's Avatar
Member # 4
Send a message via Yahoo to camo
why bother....make it 35 spline
Millennials, making hippies look tough since 1980
camo is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 08:30 AM   #5 (permalink)
Member # 2119
Id weld the rear after buying a couple 35 spline side gears. Then if you are just keeping it 8 lug full floater I would call Dutchman or the axle brand of your choice and get custom 35spline shafts that are way stronger than stock 30 spline. The axles are 300 bucks and the side gears cant be more than 50 new.Then you have one strong locked d60 for less than 400 bucks.You can even buy as thick gear and run the 3series carrier. Just buy an open 4series d44 carrier, $50. new and your gears and a lockrite .
How many licks does it tak.... A
JUST SUCK IT
wheelinjp is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 09:27 AM   #6 (permalink)
Member # 6291
you lost me here ... what's with the d44 carrier ?
any chance of finding some 35 spline d70 or 14 bolt
shafts to fit in the d60 after adding 35 spline side gears ?
- jack
Old 01-10-2002, 09:31 AM   #7 (permalink)
Member # 3774
There's one problem with this. The 35 spline shafts won't fit through the spindles. They are too small. Do you have a cheap way to open them up for the 35 spline shafts?
GhettoRig is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 10:16 AM   #8 (permalink)
Member # 6494
you could use a dremel Do a search there's actually a couple of really recent threads on boring spindles.
Easy
[SIZE="4"][FONT="Trebuchet MS"][I][COLOR="Magenta"]#914 Pampered Chef Buggy[/COLOR][/I][/FONT][/SIZE]
[SIZE="2"][U][COLOR="Blue"]Companies we're proud to work with[/COLOR][/U][/SIZE]
[COLOR="Blue"]East Coast Gear Supply[/COLOR]
[COLOR="Red"]Reid Racing[/COLOR]
[COLOR="DarkOrange"]RCV Performance Axles[/COLOR]
[COLOR="Sienna"]Rose Grinding & MFG[/COLOR]
[COLOR="DarkOliveGreen"]Single Source Welding[/COLOR]
[B][COLOR="Wheat"]Northern member of MUD DEVILS[/COLOR][/B]
EasyXJ is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 10:50 AM   #9 (permalink)
CrazyHorse's Avatar
Member # 3420
Send a message via ICQ to CrazyHorse Send a message via AIM to CrazyHorse
my 79 ford 60 rear had spindles with a 1.7" ID stock, from what I've seen and been told about half of the axles have large enough spindles from the factory. The OD is the same for 60, 70, and 14 bolt spindles judging by the bearing #'s I've found, so if the bore on your spindles is too small just take your axle to a machine shop and have them bore the spindles. Lincoln Welding in Sacramento said they could do it for me for about $120, then I found out I was one of the ones lucky enough to have the large bore spindles stock.
John Foottit 70 Bronco Buggy
Contact me about Custom Cabinetry www.beniciacabinetry.com
CrazyHorse is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 11:55 AM   #10 (permalink)
redruM's Avatar
Member # 7855
gears - 200
cheap install - 28
full install - 108
per axle, no spool for a 30 spline
go to a JYD and get 35 spline drill your spindles and get t 190$ spool. (if you want a spool)
98TJ 4.0L, Auto, 4.0 231, 60F Detroit, 61R Spool, 4 links F&R,5.38's, Hydro, Beadlocks, TSL&Boggers
redruM is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 04:06 PM   #11 (permalink)
Member # 6494
I still don't see why people buy spools for $190+ when you can spend about $3 on some welding rod. Don't give me any shat about carrier strength either, cuz you ain't gonna break that 60 carrier.
Easy
Old 01-10-2002, 05:14 PM   #12 (permalink)
TR
TR's Avatar
Member # 2877
I just called randys and here was my quote on gears.
Dana 60
5.86 Gears $253
Master Install Kit $149.92
4.56 up 35 Spline spool $193
35 Spline axles $165 per side cut to fit
Dana 44
5.89 gears $199
Master Install Kit $96.92
4.10 Up Open Carrier $54
4.10 up ARB $664.35
4 Wheel Parts Wholesalers Prices
Dana 60
5.86 Gears AND install kit $234.95
Dana 44
5.86 Gears AND install kit $174.95
4.10 up ARB $649.95
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 05:27 PM   #13 (permalink)
Member # 144
Easy
Lemme see I could go out and buy a new open carrier for the gears Im installing.. cause well that'd be easier than cleaning them. Then weld them up.. or I could spend the $190 and not worry about it. Besides, I dont care what you say the spools stronger. And yes, I've seen split carriers.
That's because you're a pinko fascist. - Haole
I know what antidisestablishmentarianist means
mike is offline   Reply With Quote Quick reply to this message
Old 01-10-2002, 06:08 PM   #14 (permalink)
Member # 2757
Hey thanx dude! much just what i asked! Looks like i'll be going 5.13 open open - welded front / rear for 38's
Dana 60
5.86 Gears $253
Dana 44
5.89 gears $199
4.10 up ARB $664.35
Dana 60
Dana 44
4.10 up ARB $649.95
ESREVER NI EVIRD
