gear change--axle in, or axle out? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-04-2016, 08:04 PM   #1 (permalink)
Member # 119289
i am going to change the R&P in my f-sd (dana 80) from 4.63 to 4.10. i have never done this before. should i make my life easier and take the axle out of the truck and put it on stand in front of me? if it makes it that much easier to work on, ill buy new ubolts. or fuck around with it under the truck trying 100 different shim options?
im a fairly competant mechanic, employed as "head fleet mechanic" for a private fleet of delivery trucks--just never done this, and i know it has to be done exactly right. i have micrometers, torque wrenches etc
'97 f450; 24v cummins, zf5, 19.5s, no stickers, no smoke, no stacks, no bullshit
some zilch is offline   Reply With Quote Quick reply to this message
Old 10-04-2016, 09:31 PM   #2 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
For me unless its a 14 bolt or similar with adjustment collars I wouldn't do it on the ground. Either up on a lift or pull axle and put on stands.
MNorby is offline   Reply With Quote Quick reply to this message
Old 10-04-2016, 09:33 PM   #3 (permalink)
Member # 127197
If you've never done one, I would pull it and do it in stands.
LANDABUSER is offline   Reply With Quote Quick reply to this message
Old 10-04-2016, 10:04 PM   #4 (permalink)
Member # 229017
Pull it, it will come in and out three or four times and weighs too much to do it under the truck without phucking up your arms,shoulders and back ....been there and done that....$.02
1968 Highboy CrewCab-4BT,ZF5, 205/203,44/60 trutracks
eggman918 is offline   Reply With Quote Quick reply to this message
Old 10-05-2016, 02:25 PM   #5 (permalink)
lil,yota's Avatar
Member # 102395
You can pull it out before you start or after you start. Either way you're gonna pull it out
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 10-05-2016, 02:53 PM   #6 (permalink)
Mr. Mindless's Avatar
Member # 24238
if you're working on a lift, in the truck is fine. If it doesn't have a rear fuel tank, anyway. I don't love working on the 11.5 in my tow rig in the truck since the fuel tank is very in the way, but I don't hate it enough to think about pulling the axle either.
Last Minute Motorsports
#5, Legends #571, UTV codog #901
koh19 crew: 4632
koh18 codog: 901, 4816 - crew: 928, 209, 4610
Mint17 pit crew: 4454, 946, 8199
koh16 codog: 2700 - crew: 572, 928, 4610
koh15 crew: 572
Mr. Mindless is offline   Reply With Quote Quick reply to this message
Old 10-05-2016, 03:34 PM   #7 (permalink)
Member # 181868
I can't believe the consensus is pull it. I've done this quite a few times and I wouldn't consider pulling it unless I had another reason also. All of my changes have been in lifted trucks, so there was no interference with tank/frame. I feel that it might be better in the truck unless your stands/bench can hold it real solid.
Project : Amphibious HEMTT
