SpiderTrax C`s/Knuckles & Steering Stops - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-02-2016, 04:14 PM   #1 (permalink)
jsawduste's Avatar
Member # 77571
Did a Google Image search. Found one picture of what I think might be a tube welded to the knuckle to act as a threaded portion of a steering stop. Hard to tell because it wasn't very clear where the stop would, well stop on the C.
Don't want the gearbox to be my stop so I am looking for some information on what others have done.
Front side of the knuckle is clear but the back side has the caliper to contend with. Using a brake setup from Blaine and the caliper is a bit larger than the Wilwood`s that SpiderTrax offers. I know the opposite knuckle could be a stop but that still transmits the load through the linkage.
Surely someone in PBB has done a stop set up. Care to share ?
Sent with smoke signal.
jsawduste is offline   Reply With Quote Quick reply to this message
Old 11-02-2016, 04:21 PM   #2 (permalink)
Member # 55444
Was looking at a pic yesterday of erik Milllers front end (I think) and we where having this exact conversation.
It was a tube, with a bolt and a jam nut, welded to the knuckle, and there was a triangular piece of steel welded to the inner C to contact on.
Edit........Found a pic, not the one I was looking at, but you can see it.
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 11-02-2016, 07:10 PM   #3 (permalink)
jsawduste's Avatar
Member # 77571
Thanks Spidr
This is very similar to the pic I found on Google. Think that axle build was a work in progress as there was no stop on the C for the bolt head.
Realize this isn't rocket science but it never hurts to see what some of the others are doing. I suspect Erik has a similar setup in the rear of the knuckle that works around the caliper.
The ability to weld and fab on the SpiderTrax stuff is one reason I have been drawn to them.
Surprises me to no end those that neglect a positive stop and let the linkage and gearbox take all the beating.
Old 11-02-2016, 07:38 PM   #4 (permalink)
mcutler1's Avatar
Member # 167368
I would like to see more examples also. Soon to be building stops on my nines.
I know factory stops are on the front, but is there any advantage to having rear vs front or both.
Matt
90's throw back manche build
Last buggy Build thread;
LS2, th350, atlas 3.0, spidertrax 9's, 39's.
Instagram: CutlerFab
mcutler1 is offline   Reply With Quote Quick reply to this message
