Gear pattern check - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-16-2016, 05:29 PM   #1 (permalink)
surftaco's Avatar
Member # 47670
Gear pattern check
Toyota Fj80 rear axle
.057" pinion shim
im thinking it's still a bit shallow?
"Whoso Speaketh Of What Concerneth Him Not Shall Hear What Pleaseth Him Not."
Sir Richard Francis Burton
Build Thread -
surftaco is offline   Reply With Quote Quick reply to this message
Old 11-16-2016, 06:53 PM   #2 (permalink)
Member # 450338
Run it
nukegoat is offline   Reply With Quote Quick reply to this message
Old 11-16-2016, 06:59 PM   #3 (permalink)
Member # 102813
Dd or off road?
If its a DD run it. If it isn't then shoot for deeper.
[/COLOR]
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 11-16-2016, 07:10 PM   #4 (permalink)
surftaco's Avatar
Member # 47670
Originally Posted by Mr Stubs View Post
Dd or off road?
Trail rig that will see lots of road use.
Think I'll try .06 pinion shim and check the pattern again.
Build Thread -
Old 11-17-2016, 05:01 PM   #5 (permalink)
surftaco's Avatar
Member # 47670
.059 pinion shim
.006 backlash
Think I'm going with it...
Build Thread -
Old 11-17-2016, 05:14 PM   #6 (permalink)
Member # 102813
Looks good.
Make sure to get 100+ ftlbs worth of pre-load on those carrier bearing adjuster nuts.
[/COLOR]
Old 11-17-2016, 05:27 PM   #7 (permalink)
surftaco's Avatar
Member # 47670
For some reason only the elocker 9.5" diffs use carrier bearing shims instead of the adjuster wheel. The got the carrier in there damn tight though
Build Thread -
