The Twins - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-23-2016, 08:01 PM   #51 (permalink)
Member # 55444
Originally Posted by Idaho4x4Bronco View Post
Is that just to keep your hands dry or is the rope that much more brittle compared to cable? Serious question.
Only on PBB
Wet muddy rope wears out faster.
Uv helps kill it too
[CENTER]I have Dumb Ideas[/CENTER]
spidr is offline   Reply With Quote Quick reply to this message
Old 11-23-2016, 08:10 PM   #52 (permalink)
Member # 102813
Yep. The grit that ends up In between the rope fibers wears it out from the inside out.
[/COLOR]
Mr Stubs is online now   Reply With Quote Quick reply to this message
Old 11-23-2016, 08:11 PM   #53 (permalink)
Idaho4x4Bronco's Avatar
Member # 139619
Fuckers.
Now I have to go read up on rope vs cable for my upcoming Bronco..Pricks
Oh by the way, looking great Ryan
Idaho4x4Bronco is offline   Reply With Quote Quick reply to this message
Old 11-24-2016, 09:01 AM   #54 (permalink)
Provience's Avatar
Member # 138976
stick with rope and just replace it every now and then depending on use
Old 11-24-2016, 10:31 AM   #55 (permalink)
Member # 102813
And use the old rope to make things like soft shackles, axle tie downs, and hand pull lines.
[/COLOR]
Old 11-25-2016, 08:02 AM   #56 (permalink)
jsawduste's Avatar
Member # 77571
And get the good rope/recovery stuff from Jim Markham at JM Rigging Supply.
https://www.facebook.com/jim.markham.9?hc_ref=NEWSFEED
JM Rigging
Sent with smoke signal.
jsawduste is offline   Reply With Quote Quick reply to this message
Old 12-12-2016, 05:31 PM   #57 (permalink)
Member # 55444
Been doing a ton of work, some things just take time though.......
Winch cradle done on the 2 seater. Just barely clears the ram truss at full stuff.
Hood still needs to come forward a hair, grill hoop, and a removeable bumper in case he drives by braille.
Got the first windshield started... Should look pretty decent once its finished out.
Old 12-12-2016, 05:32 PM   #58 (permalink)
Member # 55444
And onto the diffs for the 4 seater.......
Old 12-12-2016, 05:45 PM   #59 (permalink)
Member # 102813
You need to lay off the white stuff, or just finish what you start
The two holes in the front of the winch tray. Are they speed holes or will they house turn signals?
[/COLOR]
Old 12-12-2016, 05:55 PM   #60 (permalink)
Member # 55444
These two arent mine.......I'm too busy moving to work on my own
Speed holes. Didnt need to be solid plate, and just seemed like it needed them
Old 12-12-2016, 07:57 PM   #61 (permalink)
Member # 1792
Why the short windshield?
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers. Kid's '70 Jeepster D44/14bolt FF.
Cheepin is offline   Reply With Quote Quick reply to this message
Old 12-12-2016, 08:01 PM   #62 (permalink)
Member # 102813
Turn em into turn signals like the OG 50-70 vintage jeeps.
[/COLOR]
Old 12-12-2016, 08:49 PM   #63 (permalink)
Member # 55444
That's full height. It's the chassis that's taller.
Buried behind the grill. Won't even see them.
Old 12-13-2016, 06:27 AM   #64 (permalink)
Member # 53677
Originally Posted by homeboy View Post
As some who has spidertrax brakes on his 60 and 14 bolt on a buggy with dual manual masters, they are perfect performance wise and are worth the money and weight savings over what that setup is. Only thing I'd do is try running Q pads over the standard K pads they typically come with to shut up the noise and get better bite at lower pad temps.
Do you have any pictures of how you have your caliper brackets set up?
Ford 60 or Chevy 60? (can PM me if you want...dont need to clutter the thread)
Also - try the E pads. They were recommended by a few folks for crawling/trail riding. With how easy they are to swap out, it wouldnt be crazy to have a few different sets anyway in my opinion
2017 JK Buggy / LQ9 / Solid Mfg HP60 / 14bolt / 42" Maxxis / Method Wheels / Radflo
IG: @partiallycommittedracing
slravene is offline   Reply With Quote Quick reply to this message
Old 12-13-2016, 06:51 AM   #65 (permalink)
Member # 102813
Those pockets in the winch tray looks like it would allow you to put the lights in the grille like many of the early model jeeps. I thought it may be a look you were going for.
Anyhoo, carry on.
[/COLOR]
Old 12-13-2016, 07:09 AM   #66 (permalink)
Member # 83301
We get that....but it looks
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
pennsylvaniaboy is online now   Reply With Quote Quick reply to this message
Old 12-13-2016, 09:47 AM   #67 (permalink)
Member # 55444
Anyhoo, carry on.
It took some convincing just to get them to cut the grilll for the winch fairlead to stick it behind the grill......Theyre reading though, so I'm game if they are.
Have faith. Not done yet, it will look right when its finished and mounted
Old 12-13-2016, 10:33 PM   #68 (permalink)
SKOP's Avatar
Member # 109734
Cool
Originally Posted by squamch View Post
Damn mainlanders wannabes!
Nice Twins Spidr .Some serious parts list here !!!
SUB'd
**TTC-2013**
Thx to my Sponsors:
-Western Canadian Rockwell
-NorthWest Fabworks
IG: @big_skop
SKOP is offline   Reply With Quote Quick reply to this message
Old 12-29-2016, 04:41 PM   #69 (permalink)
jsawduste's Avatar
Member # 77571
Spidr,
you mentioned Evolution (EMF) earlier in this thread. Wanted to share a picture with you.
This pin has been used and abused for the last 4 years and over 20,000 miles. Other than a shot of grease once in a while they have not been touched.
I think it looks pretty darn good. Old pin on the left and new on the right.
The joint has never needed to be tightened and was still good and tight when I took it apart.
Old 01-25-2017, 07:03 PM   #70 (permalink)
Member # 166467
Any updates on the twins? Loving all of your builds
ranger4.0 is offline   Reply With Quote Quick reply to this message
Old 01-30-2017, 05:34 PM   #71 (permalink)
Member # 104333
The twins were born pre-mature and were crying out for attention.
Not much to report, they are doing well and should be back on track shortly.
canucklj is offline   Reply With Quote Quick reply to this message
Old 01-30-2017, 06:39 PM   #72 (permalink)
Member # 615050
reaper1313 is offline   Reply With Quote Quick reply to this message
Old 01-30-2017, 08:13 PM   #73 (permalink)
Member # 189239
Last activity date for spidr. 12/28/2016. .. WTF happen in canukistanland? his insta had been dead lately too.
YROC FAB. is offline   Reply With Quote Quick reply to this message
Old 02-20-2017, 08:24 PM   #74 (permalink)
85stanky's Avatar
Member # 72380
yeah!
Just wanted to say awesome it is to see the work you do, out of a shop much like us normal people. Water on the ground never slows you down!
striving to achieve mediocraty
85stanky is offline   Reply With Quote Quick reply to this message
Old 02-21-2017, 08:14 AM   #75 (permalink)
Member # 89362
ARTICULATE ROCK CLIMBER Ladysmith, Cowichan
Issues , not exactly sure what happened ? I think the twins will be getting finished somewhere else ?
too tall is offline   Reply With Quote Quick reply to this message
