4l60e won't bolt to 5.3? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-30-2017, 09:44 PM   #1 (permalink)
1990GT50's Avatar
Member # 109423
I have a one piece case 4l60e (older 4l60e) that Im mating to a lm7 5.3. Trans bolted up fine on mockup. I installed converter (generic 4l60e converter rebuilt), and now I have about 3/8" gap between bell housing and motor when attempting to mate them.
Currently-
Converter is definately completely seated. Tripple checked, and its about 1/8" from hitting the bolts on the trans, so it cant sit any deeper towards trans.
Converter "snout" fits into flexplate hole fine.
Were there multiple flexplates used, or do I have a funky converter? It has to be one or the other....
I can try to get more pics tomorrow...
Pic of how close I can get everything. Dowel pins barely touch, but iat his point, the converter is seated, and converter pads against the flexplate...
This is what the converter/ flexplate looks like when I have the spacing seen in the first pic. Everything is touching fine here, but bellhousing gap exists...
The converter... You can see the pads in the lower right corner.... They step out twice if that make sense (1 step out from converter, then another). Im thinking this could be the issue??
I was 8 hours deep working on it today, so I didn't think to try to bolt the converter to the flexplate without the trans (just to double check everything lines up). Ill do that tomorrow and can take any other pics.
What am I missing here?
If you try to fight me I'm simply going to interpret it as an attempt to kill me.
Go back to riding your Fag Dog Brokeback or whatever the fuck its called.
1990GT50 is offline   Reply With Quote Quick reply to this message
Old 07-30-2017, 10:07 PM   #2 (permalink)
Member # 130483
Ls cranks are closer to the block then prev gen motors
Do you have a spacer between the crank and flex plate?
What are the applications for the flex plate and converter?
99 Silverado,35's,locked 14b,4.8L,nv4500
92 s dime is offline   Reply With Quote Quick reply to this message
Old 07-30-2017, 10:15 PM   #3 (permalink)
1990GT50's Avatar
Member # 109423
The flexplate on the 5.3 is whatever came stock. Ill grab a pic of it tomorrow. I have no spacer between the crank and flex, but if I did, it would make the issue worse, as it would push the bell housing and engine apart more.
Engine is an 02 5.3 with DBW (if that matters)
4l60e is older 1 piece housing. I tried to bring up the e-bay add I bought the converter from, but couldn't. Headline was "4L60E 4L65E 4L70E TMBX TORQUE CONVERTER 4.8L 5.3L 5.7L 6.0L TRANSMISSION"
Im an LS newb so hopefully this is not too costly a lesson...
Old 07-30-2017, 11:11 PM   #4 (permalink)
Member # 1956
That is one odd looking convertor compared to the last one I swapped out.
The forest was shrinking, but the trees kept voting for the axe because itís handle was made of wood
Shadow man is offline   Reply With Quote Quick reply to this message
Old 07-31-2017, 07:41 AM   #5 (permalink)
DCXterra's Avatar
Member # 228471
That's not even close to the 2 4l80e converters or th350 converter I've put behind an ls engine. The 4l80e's and th350 looked a lot different, they didn't have that snout coming out from the center. Which I'm guessing is your problem. That and the centering pin looks to be way too big. It's one of those that's the problem.
DCXterra is offline   Reply With Quote Quick reply to this message
Old 07-31-2017, 03:42 PM   #6 (permalink)
zen as fuck
gmcxt's Avatar
Member # 115122
X3
That converter looks odd.
"..hey Guy come on, were sympatico here look at us. Huh, we even web wheel on the same forum...hey hermano."
gmcxt is offline   Reply With Quote Quick reply to this message
Old 07-31-2017, 10:24 PM   #7 (permalink)
Member # 85796
He has later model 4l60e converter there, he needs earlier style converter, like for the transmission that is looks like 93-98 , the converter he has is for like 2002 and newer? with removable bell housing
BIGJOEDUCKSLAYER is offline   Reply With Quote Quick reply to this message
Old 07-31-2017, 10:34 PM   #8 (permalink)
Member # 3132
If that is the case, there is no way the converter can be seated all the way. Different input. Earlier 4l60 had 3 steps. Late has only 2.
Take a pic of the trans input. Then take a pic of the inside of the torque converter snout.
Old 07-31-2017, 11:00 PM   #9 (permalink)
pcoplin's Avatar
Member # 17986
Agree. If the converter is for sure seated in the trans, and is sitting against the flex plate when the trans is still spaced from the block, the converter is too thick for that combo. There should b a gap in the converter when the trans is seated against the block.
98 TJ LQ4/TH400
FullStack MotorSports
pcoplin is offline   Reply With Quote Quick reply to this message
Old 07-31-2017, 11:50 PM   #10 (permalink)
1990GT50's Avatar
Member # 109423
This is what i started figuring today, which would make sense since i ordered without knowing any better....
Maybe newer will still seat but is too thick overall? Its def. seated as far back as possible. Its about 1/8" from touching the bolts holding the input to the trans or whatever.
I took some more pics today and measured shit- not that that mattered as im thinking i need a new converter anyways as stated above. Ill post some pics tomorrow anyways, but all in all, i guess a $200 mistake wont kill me. Live snd learn...
Old 08-01-2017, 03:33 PM   #11 (permalink)
1990GT50's Avatar
Member # 109423
So after some phone conversations, it appears I need a Pre 98 4l60e converter, and also a spacer that moves the flexplate away from the crank. Does this sound correct to others? Is the earlier converter that much shorter than the style I have? It will need to be 3/8" shorter to bolth the trans to the motor, plus the distance of whatever the crank spacer is.....
Nobody could clearly answer this question on the phone....
Old 08-01-2017, 07:32 PM   #12 (permalink)
Member # 85796
Yes earlier converter is shorter, If I get time tomarrow at my transmission shop I will tell how much taller the later converter is?????? and yes the later converter has larger spline and will go into early trans.
Old 08-01-2017, 08:56 PM   #13 (permalink)
1990GT50's Avatar
Member # 109423
Much appreciated!
Old 08-03-2017, 12:37 AM   #14 (permalink)
Member # 3239
Send a message via AIM to Brad Send a message via Yahoo to Brad
Just cut the fucking shaft down 3/8" and DONE!
TDO DYSFUNCTIONAL ROCKCRAWLERS
Brad is offline   Reply With Quote Quick reply to this message
