ARB Fawk up, help - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2004, 04:06 PM   #1 (permalink)
Member # 20206
ARB Fawk up, help
Ok, SOME HOW, I grabbed the wrong drill and drilled a 9/16th hole in my housing instead of a 7/16th. WTF do I do now? I checked at the local patrs store for a 9/16th filling that goes down to 7/16th but I couldn't find one. Any other ideas? Maybe somewhere I can find the correct fitting? I know it the holiday weekend and I will have to wait till Tuesday.
93yjsahara is offline   Reply With Quote Quick reply to this message
Old 05-30-2004, 04:20 PM   #2 (permalink)
Member # 27230
Send a message via AIM to JEEPSKEET
try lowe's or home depot, thay have a lot of brass fitting.
you should find something to work!!
if not, weld the hole up and start over !!
you do have a welder??
thats a PBB must
If anyone ask's, I got it off E-BAY for $100.00
JEEPSKEET is offline   Reply With Quote Quick reply to this message
Old 05-30-2004, 04:52 PM   #3 (permalink)
willyswanter's Avatar
Member # 16419
Send a message via ICQ to willyswanter
You can just thread the 9/16" hole you drilled to whatever size thread fits it and put a pipe plug in it. Then drill another hole next to it to the correct size.
[SIZE="3"]Jason "Willyswanter" Payne[/SIZE]
[SIZE="5"][COLOR="Red"]R.I.P. DOZER[/COLOR][/SIZE]
We'll miss you Noel :(
[SIZE="3"]Added by PBB: RIP Jason, we already miss you.
[/SIZE]
willyswanter is offline   Reply With Quote Quick reply to this message
Old 05-30-2004, 08:02 PM   #4 (permalink)
Member # 16545
or go buy a helicoil kit for 7/16"
how did you manage to confuse 9/16 and 7/16"?
Broncoo is offline   Reply With Quote Quick reply to this message
Old 05-30-2004, 08:02 PM   #5 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Tap it to whatever is the closest NPT (Probably 1/2Pipe) and use a brass or aluminum pipe bushing to reduce it to the correct NPT.
& Blaine
:tank:
Old 05-30-2004, 09:34 PM   #6 (permalink)
Member # 20206
easy, 2 drills, 2 bits, 4 hours sleep, deadline to get the jeep done=Fawk up on my part
Old 05-30-2004, 09:52 PM   #7 (permalink)
Member # 20943
Simple. Just install the REALLY big ARB...............
If brains were brass, you wouldn't have enough metal to make the set screw in the generator of a lightning bug's ass!!!
shadetreezj is offline   Reply With Quote Quick reply to this message
Old 05-31-2004, 12:30 PM   #8 (permalink)
Haole's Avatar
Member # 5859
Ka 'aina uluwehi, ko kakou
kuleana.
- The lush life-giving land, our personal responsibility.
- Darlington County Chapter
Haole is offline   Reply With Quote Quick reply to this message
Old 05-31-2004, 05:08 PM   #9 (permalink)
Member # 187
weld it shut and redrill to the proper size how easy could that be also you can use a 29/64 bit to do the job but 9/16 that must be some set of bits you got there
[FONT="Arial Black"][SIZE="5"][/SIZE][/FONT]
:flipoff2:
GearMan is offline   Reply With Quote Quick reply to this message
