speed sensors? 4L60E with dual cases - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-02-2004, 11:22 AM   #1 (permalink)
orangefj45's Avatar
Member # 6816
so i'm getting ready to install a vortec 5.7 with a 4L60e (both 1996) and a 203 rangebox with a landcruiser transfer case in a vehicle.
how many speed sensors do i need to run and where should they be placed?
i was going to run one on the t-case output, but i do not think the trans will upshift in low or double low, because the computer has no way of knowing that the vehicle is using an extra gear reduction.
do i have to run a sensor on the trans output?
if so, where and how do i install the sensor? i'm using the stock gm 350-203 plate adapter and the AA output shaft for that application.
do i still run the one on the t-case output?
thanks in advance!
Maybe you outta stick to legos!
orangefj45 is offline   Reply With Quote Quick reply to this message
Old 06-02-2004, 11:53 AM   #2 (permalink)
orangefj45's Avatar
Member # 6816
we've already started a thread in the cruiser forum, but i figured the more input the better.
https://www.pirate4x4.com/forum/showt...67#post2851967
Old 06-02-2004, 12:37 PM   #3 (permalink)
Dinkerdoodledoo
Member # 10448
Send a message via Yahoo to Grendel
Run it on the last t-case output.
I am using a Auto meter sender, 4K pulse.
Youre the only person on earth who knows all the details of your life, and thus, you are the most qualified captain of your own ship. Dont worry about justifying your course for pirate's sake. There's always someone here to tell you that you did it wrong.
Grendel is offline   Reply With Quote Quick reply to this message
Old 06-02-2004, 12:48 PM   #4 (permalink)
orangefj45's Avatar
Member # 6816
one of the guys from AA just helped me figure it out. check the other thread.
running the rear t-case output only will not work properly in low or double low; it'll never upshift. on a non computer controlled trans it would work perfect, but not on the 4L60E.
Old 06-02-2004, 02:50 PM   #5 (permalink)
TOY 2's Avatar
Member # 12800
I got the AA reluctor kit part# 716073. I'm running a 4.3/4L60E in my toyota. The vss mounts in the rear of the tranny housing.
[SIZE="3"][COLOR="Red"]Need custom UTV parts [SIZE="5"]TURNKEY UTV[/SIZE] has you covered!!![/COLOR][/SIZE]
Contact: (775) 283-9950
TOY 2 is offline   Reply With Quote Quick reply to this message
