Dana 300 VS NP205...$ and opinions - Pirate4x4.Com : 4x4 and Off-Road Forum
Register Blogs FAQ Community Calendar Premium Memberships
Old 06-16-2004, 10:10 PM   #1 (permalink)
Member # 10894
Send a message via AIM to 46willys
OK...This question willl be a for a garage built buggy I am working on.
Dana 60/14 bolt should be around 3400 pounds. With 39.5 Iroks
The motor is a chevy 350, TBI, Flat top pistons and some other good parts.
I am running a Turbo 400 Tranny with reverse manual Valve body.
I currently own a Dana 300 with a AA kit to mount it to a Turbo 400. It does not have the 32 spline output at this time.
I also currently own a one ton NP205 with the turbo 400 adapter. However it has a long tailhousing on it and Im not sure what I would have to do to get rid of that.
I know the 300 will have a lower gear and may weight a bit less but stock the 205 will be stronger. I will be selling the other in order to pay for some beadlocks so I need to make up my mind on what to run and since I have them both I cant seem to decide.
Please include good tech and opinions and help me make up my mind.
Thanks
46willys is offline   Reply With Quote Quick reply to this message
Old 06-16-2004, 10:30 PM   #2 (permalink)
B.A.R.K's Avatar
Member # 8540
After building my D300 with Tera Low 4:1, JBcon 32 spline f&r outputs, and AA adapter.....
....I wish I would have bought and ATLAS
You are going to want lower gearing than the 205 can produce.
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
Old 06-16-2004, 10:55 PM   #3 (permalink)
Member # 10894
Sell both , buy atlas...come up with bead locks later.....hmmm
Old 06-16-2004, 11:04 PM   #4 (permalink)
Member # 2569
sell the 300....you are going to spend quite a bit to make it worthy.......
keep the 205 it will be strong enough as is....imho
take the $$ from the 300 and buy beadlocks.......
take the upgrde $$ you will spend on the 300...outputs and 4-1 kit....and buy a klune..........
you will have a stronger and better geared setup than anything....
71RCKCRZR RYAN is offline   Reply With Quote Quick reply to this message
Old 06-17-2004, 08:42 AM   #5 (permalink)
SpineTx's Avatar
Member # 1499
I agree, I ran a 300 with 32spline o/p and 4:1 with a 4.0 IL 6 and 40's. after 1 season I pulled the t-case out because of some "noise" I was hearing and it had a cracked case and gears. I now have a 205 and Klune-v with 42's and a 351 no problems yet.
Pain is your Mind Failing you;
Body Damage is your driving ability failing you
SpineTx is offline   Reply With Quote Quick reply to this message
Old 06-17-2004, 08:48 AM   #6 (permalink)
Member # 17612
I am curious to what gears you guys were running that had problems with in the 300. I just finished building my 300 but, didn't do gears because I don't need that much low range. My slushy takes care of it.
I personally like the 300 over the 205 because it is smaller, shorter, and lighter. For my buggy, that worked out better. I have no doubt that it will take anything I am going to give it with a slushy in front of it.
Lost without going anywhere
Camp is offline   Reply With Quote Quick reply to this message
Old 06-17-2004, 08:54 AM   #7 (permalink)
BlackSkies7's Avatar
Member # 31931
nothing beats a free case but the 205 aside from its crappy low, is 1 big bastard of a case! The 300 will provide for better angles, seems like youl spend the least cash just throwing the 205 in right now, that is if your in a rush. Otherwise id have to agree wit the above, go atlas.
[FONT=Comic Sans MS][COLOR=Blue]
Somewhere out there is America, then there is New York...
CJ2a- 360... caged.. axles etc...
97ZJ 318/nv3500... d30/44h.... 8.8 etc
[/COLOR][/FONT]
BlackSkies7 is offline   Reply With Quote Quick reply to this message
Old 06-17-2004, 11:19 AM   #8 (permalink)
Member # 10736
sell the 300, postpone beadlocks and go doubler. Th 400 to 203 adapters are cheap.
masonmachines is offline   Reply With Quote Quick reply to this message
