Rock Apes big Gay truck build..... $100 Krew.. - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-27-2018, 07:26 PM   #126 (permalink)
Member # 23843
Originally Posted by desertCJ View Post
OK, I see. The angle was throwing me off. I thought they were just vertical. Steering clearance makes more sense.
Yeah I havenít tightened the heims yet (and oriented one on each end of the links) to make them stay in position for tire clearance.
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!!
Rock Ape is offline   Reply With Quote Quick reply to this message
Old 02-28-2018, 09:06 AM   #127 (permalink)
Member # 46240
I think you should have mounted the fuel cell on the top of the cab. That way gravity will make the fuel go to the engine faster.
Nice build man. Makes me want to build something for the more scenic trails around here.
RaginCaucasian is offline   Reply With Quote Quick reply to this message
Old 02-28-2018, 10:02 AM   #128 (permalink)
Member # 23843
Nice build build man. Makes me want to build something for the more scenic trails around here.
Ill tell ya more than a few of my buddies are shaking their head on why I built this, like most people here....hell, I refer to it as my "big stupid stuck build" ..... I get most people cant understand why I didn't just buy a truck and modify it to do what this truck will likely see....
Its more about building something I haven't seen before.... using ideas I have done on countless buggies I have built... in the process.
Is it for all out rock crawling performance.....? No! Now....do I expect it would do well if put in that situation... yes! But Im not gonna try to fit this into any of the better than hammers canyons around where I live....? Nope....I have 2 buggies and a jeep on 42s for full retard stuff.
I figured the title of this thread was enough......
Old 02-28-2018, 06:55 PM   #129 (permalink)
Member # 429
Yeah, but we may finally be getting some snow to go play in this weekend.
Jack
2007 2500hd max/ali with stuff.
2008 FWC Hawk
1985 4Runner 4.3, R151 on tons
locrwln is offline   Reply With Quote Quick reply to this message
Old 02-28-2018, 08:43 PM   #130 (permalink)
Member # 23843
Jack
I hope so! Iíd be willing to freeze in my YJ for a couple feet of snow wheeling goodness!
Old 03-01-2018, 07:15 AM   #131 (permalink)
Blase's Avatar
Member # 63692
Any side view pictures of the front end with the frame section cut off?
[QUOTE=JR;13666387]:laughing: You know, Ifs is kinda like a vagine. It's soft,sexy and expensive.[/QUOTE]
Blase is offline   Reply With Quote Quick reply to this message
Old 03-01-2018, 06:16 PM   #132 (permalink)
Member # 429
I hear you. Going to head up to Verdi Peak on Sunday. Meeting at the Cabela's/Boomtown Chevron at 9am.
Jack
2008 FWC Hawk
Old 03-02-2018, 04:43 PM   #133 (permalink)
Member # 23843
Crappy pic.... but I cut a ton off and even moved the rail tips up a few inches since my original issue was not having any kind of frame to start with so I ended up taking measurements off a friends 2wd crew and then tweaking it alot to be able to get the low ride height/good this will have.
Old 03-02-2018, 08:57 PM   #134 (permalink)
Member # 40131
Amateur hour with Your potatoe pictures. We want high quality porn pics!
Motorsport Syndicate:::Edinburg TX
Bitches today are too fucking uptight.
72blazer is offline   Reply With Quote Quick reply to this message
Old 03-03-2018, 07:15 PM   #135 (permalink)
Member # 673218
If you get a chance can you tell me what the length of your drag ling and panhard are. And what angles they are at at full bump and droop. Thanks
Mighty Mats is offline   Reply With Quote Quick reply to this message
Old 03-06-2018, 08:32 PM   #136 (permalink)
Member # 23843
Dude... if I posted pics of my hot redhead GF... Iíd seriously derail this thread...
The draglink is 41Ē and 17.5 degrees at full droop... since the panhard has a slight bend to clear the balancer on the engine at full compression I canít teally give you a number other than itís length itís...38.5 ď
Since I would have to pull the front springs to check the angle of the panhard/draglink at full stuff , it likely wonít happen any time soon, but as I remember it was almost flat if not a few degrees inverted.
The suspension is built to be able to use all 16Ē of shock travel , and keeping a steering box has been the challenge.
Old 03-07-2018, 05:06 AM   #137 (permalink)
Member # 673218
This is where I am at as well. I am using the same coilovers and to say it has been a challenge is putting it lightly.
I have found that I need to make the jeep sit very low at full bump in order to stop the heim joints in the steering from binding at full droop.
And I have my steering box mounted on the inside of my frame. If i had to re-do it i would make my frame more narrow raise the front frame rails up 4". That might solve most of my problems, oh well.
Old 03-07-2018, 08:00 AM   #138 (permalink)
Member # 23843
I have a yj Im going to link in the future for a friend and keep the steering box but we are only gonna use 14" shocks for the reasons you are describing.
Before I started this project I saw this...
https://www.pirate4x4.com/forum/chevy...uck-build.html
And after seeing the issues of moving the steering box inboard I thought it would be best to just narrow the frame section up front on mine(that caused its own bunch of issues with the exhaust) and deal with any tire rub. As part of the frame stretch on mine the box moved forward as well and actually down(helping the angle of the draglink at full droop).
Old 03-21-2018, 06:31 AM   #139 (permalink)
Blase's Avatar
Member # 63692
How's it coming?
Old 03-21-2018, 09:41 AM   #140 (permalink)
Member # 23843
How's it coming?
Truthfully....it runs and after a bit a welding and fluids its ready to pull out of the shop....not done but under its own power.
You'll have to image the pics until I get home and upload a few.....
Old 04-17-2018, 02:50 PM   #141 (permalink)
Blase's Avatar
Member # 63692
YEP......its me again...... BUMP for updates. LOL
Old 05-30-2018, 07:24 AM   #142 (permalink)
Blase's Avatar
Member # 63692
last bump and i'll leave this thread alone.
Old 05-30-2018, 08:46 AM   #143 (permalink)
Member # 23843
Ok.. ok.... Iíll pull it outta the shop tonight and get some pics since I need to turn it around anyways.... major mechanical is done because Iím already on the gather for my next buggy build.
Old 05-30-2018, 11:55 AM   #144 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
Ok.. ok.... Iíll pull it outta the shop tonight and get some pics since I need to turn it around anyways.....
Old 05-30-2018, 12:26 PM   #145 (permalink)
Blase's Avatar
Member # 63692
I saw that on FaceBook...........are you gonna do a build thread here LMAO
Old 05-30-2018, 02:48 PM   #146 (permalink)
Member # 23843
I donít know.... about another build thread... and who would care about a single seat rear engine moon buggy on portals that does amazing things........?
Iíd probably just do it all wrong anyways!
Old 05-30-2018, 04:16 PM   #147 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
I don't know, but it doesn't sound "Fast" so nobody probably cares anyways
desertCJ is offline   Reply With Quote Quick reply to this message
Old 05-30-2018, 09:30 PM   #148 (permalink)
Member # 23843
Ok as promised a few pics.....
Now for some specs....
Top of cab 81"
fender height at front wheel center 55"
Belly 24" (which is the same as the sliders since they are flush with the bottom of the frame)
8" of uptravel/8" down
And the pic where it is nose to nose with my completely stock 87 3/4 ton....its 7" taller but when measured center for the front hub to the fender top..... its only 2" difference.... so its like my 3/4 ton with a 2" lift and 41.5 tall tires!!
Old 05-30-2018, 09:55 PM   #149 (permalink)
1975f100's Avatar
Member # 716946
Glad to see this got bumped. Builds are getting scarce around here
1975f100 is offline   Reply With Quote Quick reply to this message
Old 05-31-2018, 04:14 AM   #150 (permalink)
Member # 40131
Gives me a chubby
