DIY Sheet Metal Brake - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-28-2004, 03:39 PM   #1 (permalink)
Member # 4173
Anyone build their own manually operated brake, or have plans to build one? Nothing big just something that could handle 14g at 30" wide. Links, pics, tips?
When I die, I want to go peacefully like my grandfather did...in his sleep, Not screaming like the passengers in his car.
ShawnM is offline   Reply With Quote Quick reply to this message
Old 06-28-2004, 04:14 PM   #2 (permalink)
crashinaz's Avatar
Member # 4669
I did a search on Google for this a while ago and came up with some pretty simple designs for both the bottle jack and manual types.
crashinaz is offline   Reply With Quote Quick reply to this message
Old 06-28-2004, 04:16 PM   #3 (permalink)
crashinaz's Avatar
Member # 4669
Oh and you might try moving this over to the new "tool and shop" section.
Old 06-28-2004, 04:58 PM   #4 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
Search for "press brake" there are 3 threads that I can remember which are all about homemade brakes and such. But with steel prices like they are, its almost cheaper to just buy one.
In vino veritas
73 linked 5.8efi Bronco
braxton357 is offline   Reply With Quote Quick reply to this message
Old 06-28-2004, 06:36 PM   #5 (permalink)
Member # 29634
the one at harbor freight looks pretty cool. Do you bend that much sheet metal? Find u a buddy with a sheetmetal shop. It'll pay off when u wanna bend 1/4"
The less we take care of our neighbors, the more $ U.Sam will take to screw up trying to do our job
bigsub is offline   Reply With Quote Quick reply to this message
Old 06-28-2004, 07:02 PM   #6 (permalink)
payton's Avatar
Member # 11067
Send a message via AIM to payton Send a message via Yahoo to payton
why not use some angle iron cut to what ever width you want. then take and weld a couple of washers on each end then a couple of bolts on the 2nd piece of l channel.. botls thru washers.. weld ya some kinda handle.
use c clamps clamp to table. and bend away
this space for sale
payton is offline   Reply With Quote Quick reply to this message
Old 06-28-2004, 08:56 PM   #7 (permalink)
Member # 4173
I almost can picture it in my head and put it together but not quite. I've been racking my brains about this for an hour... I think if I lay out some steel I'll clue in.
Old 06-28-2004, 09:06 PM   #8 (permalink)
payton's Avatar
Member # 11067
bench.. take a section of l channel. putt a couple of washers down. for spacers so sheet metal will slide. c clamp each end make the L channel with the L facing into the tabel. then you could either put some type of hinges or weld on some sort of washers to use as a henge. if you use washer then you would need to line up the bolts with the washers so its all square. if you use hinges then it would simple require bolting it together. then weld some kind of handle on. im thinking the washer and the bolt would be a lil better fit.. lil closer. so it would end up looking like a cross + and teh edge of the work bend would be used along with the section of l channel thats c clamped as the break. i could draw ya something if you like.. my art skills suck tho.
this space for sale
Old 06-28-2004, 09:38 PM   #9 (permalink)
Member # 20597
Scott (from Rockstomper) built one once. He talked about it here.
Otherwise, if it's an occasional thing, find your local industrial sheet metal shop, it will make life easier
Mike
azrain is offline   Reply With Quote Quick reply to this message
Old 08-27-2011, 07:10 PM   #10 (permalink)
Member # 141944
So... Resurrecting an OLD thread to see if there's any new ideas...
I need to bend some 6' wide sheet-either 14 ga aluminum or thinner steel for a few trailer lids. This will be a seldom-used item in the shop at this width. Does anyone have any decent ideas/plans for a DIY portable setup that I can stash away for most of the year when it's not in use that won't cost a fortune? I have a couple ideas using 3" and 4" angle, hinge, long handles. Just curious what the experts think/say. Also-at 6' wide, will an average guy have the testicular fortitude (strength) to bend 14 ga material by hand with no hydraulics???
Thanks, greatly appreciated!
Best of Luck,
Mike
'05TJLWBRUBY is offline   Reply With Quote Quick reply to this message
Old 08-27-2011, 07:31 PM   #11 (permalink)
Member # 1636
I built one a few years ago out of some c-channel, flat stock and some big bolts for the hinges. it's ugly and sat outside in the weather since I built it, but it works OK. Mine is 50" wide and I bent 090" aluminum up to 48" long easily.
The clamping part I made by welding a piece of flatstock into 2" angle. There are bolts welded to each side of the bottom piece of c-channel that the clamp bolts to. The clamp kind of warped when I welded the flatstock in it, so I used clamps to tighten it against the material. I need to build a better clamping mechanism.
I'll have to get pictures sometime. Like I said it is very fugly but it works.
chris demartini is offline   Reply With Quote Quick reply to this message
Old 08-27-2011, 09:28 PM   #12 (permalink)
Member # 141944
Ugly-hell, it's a work of art compared to what I've got... Yes, would appreciate pics. I had a couple ideas using angle, but am a little confused how you went with the C and flat stock??? Probably just retarded and not thinking it through, but regardless, would appreciates some pics if you get the chance.
Thanks for the info!
Best of Luck,
Mike
Old 08-27-2011, 10:23 PM   #13 (permalink)
Member # 1636
Its two pieces of c channel stacked together with a simple hinge on each side. The material clamps against the bottom piece of channel, and the top piece pulls down. Ill get some pics after the hurricane leaves town.
Old 08-27-2011, 10:53 PM   #14 (permalink)
Member # 67889
I built one. 4" C channel and 2.5" angle iron
53" wide / removable handles /
jeepgif is offline   Reply With Quote Quick reply to this message
Old 08-27-2011, 10:58 PM   #15 (permalink)
Member # 67889
.063 AL
Forgot to add that I can change the bend radius.
Old 08-28-2011, 09:41 AM   #16 (permalink)
Member # 1636
That's the same as mine only that clamping bar is much nicer. I may have to copy that.
Old 08-28-2011, 09:56 AM   #17 (permalink)
Member # 141944
Awesome! That's pretty close to what I had envisioned and I THINK I had seen that posted here before, but my search skills sucked and was unable to find it again. Thanks for the pic-that helps a ton and answers a few questions in my head. Looks like it works great.
Thanks!
Best of Luck,
Mike
Old 08-28-2011, 10:33 AM   #18 (permalink)
ZAG
ZAG's Avatar
Member # 14113
i have one home made
ZAG is offline   Reply With Quote Quick reply to this message
Old 08-28-2011, 07:05 PM   #19 (permalink)
JayMcJay's Avatar
Member # 111999
Swag offroad has a kit for building one. It uses an HF press as a base.
JayMcJay is offline   Reply With Quote Quick reply to this message
Old 08-28-2011, 08:03 PM   #20 (permalink)
Member # 141944
Yes, Troy is a vendor here and I have had his press brake for some time now. It's great and handles up to 19" with ease between the HF press it was built for. Excellent kit that does a great job. Been very happy with it and used it far more than I thought I would for various things.
BUT...
I'm talking about a sheet brake to handle widths of 6'. Need to do a few trailer lids for some M416's I have here at the moment. I don't mess with sheet much and unless I acquire a few more trailer builds, likely won't be needing it again much after so for my purposes, a 6' DIY sheet brake that is portable and could be removed and stored upright in the back of the shop is a good looking solution. I think I can build this relatively easy enough for cheap enough to do what I need with these lids, then store it till the next go-round. Some great pics above that were pretty dang close to what I was thinking. Of course, I'm still open to other ideas as well...
Best of Luck,
Mike
