F-150 frame - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-19-2018, 07:12 PM   #1 (permalink)
Grumpy356's Avatar
Member # 151139
F-150 frame
So I picked up a 2004 f150 4x4 and the price was right, but the passenger side frame rail is rusted worse than I thought.
I want this to be as easy as a fix as can be deemed safe.
I origannally thought I could get by with putting a piece of 3” flat bar down the rail, but it moved a little further up than I thought.
Now I am thinking a piece of 2.5 inch rectangular tubing would slide inside the rail and i can weld it in.
What would PBB do?
Mass quantities of anxiety, internal conflict and discontent, all balled up in one short, tattooed body.
Grumpy356 is offline   Reply With Quote Quick reply to this message
Old 03-19-2018, 09:21 PM   #2 (permalink)
Member # 145904
tannerite
winter4x is offline   Reply With Quote Quick reply to this message
Old 03-19-2018, 09:23 PM   #3 (permalink)
Member # 225201
Holy shit.
erictylers1 is offline   Reply With Quote Quick reply to this message
Old 03-19-2018, 09:26 PM   #4 (permalink)
BamaJeeper's Avatar
Member # 14620
Dibs on your stuff when you die!
Priest "The time has come to liberate the potential of the coming porkappocalypse."
BamaJeeper is offline   Reply With Quote Quick reply to this message
Old 03-19-2018, 09:30 PM   #5 (permalink)
Member # 225201
I guess insure it and crash it?
Not to be an ass, but buying trucks at current prices as watching them rot would make me nuts. Working on them would make me want to slit my wrists.
Guess I shouldn't complain about the rust on the exhaust on my '02 GMC. Stock tailpipe.
Old 03-19-2018, 09:52 PM   #6 (permalink)
Grumpy356's Avatar
Member # 151139
I drove that bitch (with no power steering I might add) from New Hampshire to Houston. A 2004 Ford 4x4 with 140k miles for $400. I couldn’t pass it up.
I know I may die, but if anyone has any tips on holding it together though, I’m all ears.
Old 03-19-2018, 10:23 PM   #7 (permalink)
Twankie's Avatar
Member # 230823
I would buy a complete frame or a frame rail for that side from the junkyard and graft it in.
Twankie is offline   Reply With Quote Quick reply to this message
Old 03-19-2018, 10:48 PM   #8 (permalink)
Member # 562866
Dude, that frame is NOT salvageable, even to Michigan standards. Keep that rolling bus-full-of-nuns killing piece of shit off the roads you retard.
#durangoclan
Alex456123 is offline   Reply With Quote Quick reply to this message
Old 03-20-2018, 05:13 AM   #9 (permalink)
Member # 834074
Is this a 2004 heritage model or the the new body that was available from 2004-2008? A lot of these F150 frames are only made from 0.100-0.110" thickness material when they're new, with rust that bad even the good sections could wind up being dangerously thin once you get them cleaned up enough to weld new material into them. Looking at the truck from the side does it look like it's bowing down in the middle or is it still somehow fairly straight looking?
SALEEN961 is offline   Reply With Quote Quick reply to this message
Old 03-20-2018, 06:32 AM   #10 (permalink)
Member # 85771
Fill it with two cans of Great Stuff and paint it black.
Make Forums Great Again!
Old 03-20-2018, 06:47 AM   #11 (permalink)
arse_sidewards's Avatar
Member # 256962
Especially since you already did the hard part of driving the truck down south. You won't have to look to hard to find a buyer who doesn't check all that hard for rust.
Unethical, sure. But if that bothers you just sell it to someone you hate.
Old 03-20-2018, 08:21 AM   #12 (permalink)
Grumpy356's Avatar
Member # 151139
It's fairly straight.
I agree they were shit from the factory, that's why I felt comfortable with the idea of welding real steel in there. To me it would be stronger than it was from the factory.
Old 03-20-2018, 06:31 PM   #13 (permalink)
Member # 834074
They really weren't great from the factory, the 09-14 trucks started with 0.100" wall frames for short wheel base trucks, most trucks got 0.110" wall frames, and then only the "Heavy Duty Payload" and extra long frames got 0.150" wall frames.
The funny thing is the 0.110" and 0.100" frames were 49,300psi yield steel, and the "heavy duty" frames were only 36,000psi yield steel, how does that make sense?
Old 03-20-2018, 10:27 PM   #14 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
This
& Blaine
:tank:
Old 03-21-2018, 05:18 AM   #15 (permalink)
45acp's Avatar
Member # 13671
"Price was right"
So, like, $150? If you really think you can fix it, ive got half a spool of iron oxide .024 you can have. POP POP POP POP bzzzzzz POP POP bzzzzzzzzzz
Kidding aside, i dont see anything fixable about that. Other than a new frame. That you would be setting a rusty body down on.
45acp is offline   Reply With Quote Quick reply to this message
Old 03-21-2018, 07:59 AM   #16 (permalink)
wheelerfreak's Avatar
Member # 4135
My guess is new style ‘04, I’ve seen several trucks from that generation, from areas that salt their roads, that have that much frame rot.
I’d find a totaled truck from AZ, NM, CA, and do a frame swap. Patching that is just going to be never ending. Or just part it out.
The press is a gang of cruel faggots. Journalism is not a profession or a trade. It is a cheap catch-all for fuckoffs and misfits—a false doorway to the backside of life, a filthy piss-ridden little hole nailed off by the building inspector
wheelerfreak is offline   Reply With Quote Quick reply to this message
Old 03-21-2018, 08:11 AM   #17 (permalink)
Member # 85771
Originally Posted by 45acp View Post
"Price was right"
Everything is fixable, yer just a jaded not salted road having gentleman.
Old 03-21-2018, 08:52 AM   #18 (permalink)
Grumpy356's Avatar
Member # 151139
"Price was right"
$400. for a '04 4x4. so ......
I have a piece of 2.5" square tubing that I think is going to fit in the rail nicely.
I was just going to weld it in, but I am now thinking of something like this.
bolts on 5" centers and welds at top and bottom.
Maybe I can't get t clean enough, I guess I'll see.
Old 03-21-2018, 09:07 AM   #19 (permalink)
Member # 85771
Bolts? Just cut off the junk, clean it and weld new stuff.
Old 03-21-2018, 09:13 AM   #20 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Grind back and see how much good metal is actually in those frame rails. It doesn’t look like much.
& Blaine
:tank:
Old 03-21-2018, 09:24 AM   #21 (permalink)
Member # 3132
Leave it alone. Weight reduction=better fuel economy.
Have fun welding to rust. I would probably strap a 4x4 pressure treat to it.
Old 03-21-2018, 09:37 AM   #22 (permalink)
Mr. Mindless's Avatar
Member # 24238
That was a hellova waste of a drive.
part it out or put it on a new frame (and enjoy snapping EVERY fastener). there's nothing worth trying to save there.
There's a reason we salt belters go south to buy used. You just learned why you should never come north to buy used. That truck is SOP up here for something that doesn't get taken care of - and by taken care of I mean either not driven in the winter, or washed religiously.
EDIT to add:
if the frame looks that good, are the fenders
A) gone
B) replaced
C) 3" thick of bondo over rot
D) barely covered in fender flares that are about to fall off because they're attached to air?
Same goes for rockers and door bottoms, except there is no D) for rockers and doors. Or cab corners. Or bed floors.
Last Minute Motorsports
#5, Legends #571, UTV codog #901
koh19 crew: 4632
koh18 codog: 901, 4816 - crew: 928, 209, 4610
Mint17 pit crew: 4454, 946, 8199
koh16 codog: 2700 - crew: 572, 928, 4610
koh15 crew: 572
Mr. Mindless is offline   Reply With Quote Quick reply to this message
Old 03-21-2018, 10:36 AM   #23 (permalink)
Member # 213125
This is possibly the dumbest thread in the existence of Pirate4x4. OP drives cross country to the rust belt from the south to buy POS. OP now plans on wasting time and effort on fixing said piece of shit? Holy fucking Christ.
Aisin is offline   Reply With Quote Quick reply to this message
Old 03-21-2018, 10:39 AM   #24 (permalink)
Member # 85771
Not even close to the dumbest.
Old 03-21-2018, 10:44 AM   #25 (permalink)
Member # 213125
I’ve already written off the Mcnutgargle thread. I still think that guy was a troll.
