Coil length on 14 inch 2.0 kings - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-05-2018, 09:45 AM   #1 (permalink)
Member # 95763
I broke a lower coil on my 2.0 kings. I'm trying to order a replacement. I know they are 100 over 150 for spring rate, but I don't know the lengths and am unable to get to the jeep to measure them.
I was told by a reputable source they are 16 by 150 but I don't see that length on the Filthy motorsports website.
Is there a standard coil length for these coilovers or are they done by user application?
KarlVP is online now   Reply With Quote Quick reply to this message
Old 04-05-2018, 10:41 AM   #2 (permalink)
Stout Racing's Avatar
Member # 73673
14" top and 16" bottom
Stout Racing Your 4 wheel drive and LS Engine and Tuning Specialist's!
Stout Racing is offline   Reply With Quote Quick reply to this message
Old 04-05-2018, 10:50 AM   #3 (permalink)
Member # 95763
So after finding the spring tech thread and doing lotsa reading I am going to go with 200 16 lower and 100 14 upper.
King doesn't make a 150 16 lower in 2.5.
Old 04-05-2018, 12:28 PM   #4 (permalink)
POR
Member # 206074
I'm petty sure eibach does.. and Pac would too.. I would think. I think you'll like the new spring combo you picked.
POR is offline   Reply With Quote Quick reply to this message
Old 04-05-2018, 12:34 PM   #5 (permalink)
Member # 95763
I think so too.
I re-valved the rear shocks and added a flutter shim on the compression right before KOH. The jeep worked very well, but in the go fast stuff it would tend to blow through the rears on hard hits.
Mind you I don't have bump stops in the rear so I wasn't doing the shocks any favors. The front end soaks up the go fast stuff and I rarely was hitting the bumps.
I'll try these springs with the current valving, add some bumps and try re-valving from there if I need to but I think I've got this thing pretty dialed for what I use it for.
Old 04-07-2018, 02:37 PM   #6 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
springs hold the vehicle up. if you are bottoming out youre valving need to be adjusted
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote Quick reply to this message
Old 04-07-2018, 04:13 PM   #7 (permalink)
Member # 161331
Not true. Not enough spring will cause all sorts of issues.
bdkw1 is offline   Reply With Quote Quick reply to this message
Old 04-07-2018, 09:15 PM   #8 (permalink)
Member # 95763
I tend to agree with this a bit. After I re-valved the shocks and added a flutter shim, yes they did bottom out too quickly in the go fast stuff.
In my case, I think I need more lower spring and also to set the slide stop lower than where it is set. I'm using both springs for far too much of the shock travel. Setting the slide stop lower will cure some of my problems.
If the spring and slide stop don't get me where I want to be, I will add more compression valving starting with taking the flutter shim out.
Overall I have increased the rear suspension characteristics tenfold. Now I just need to dial it in to what makes me happy. I made some "large changes" with springs and shims, now I just need to get it dialed.
Old 04-08-2018, 08:37 AM   #9 (permalink)
Member # 135279
What are the characteristics of not enough spring? Besides ride heights.
shrek tits is offline   Reply With Quote Quick reply to this message
Old 04-08-2018, 09:52 AM   #10 (permalink)
Canuckastani
Boons's Avatar
Member # 164167
I have some 3.0x14 racerunners I need coils for and I can't seem to get a 3.75" in 14" and 16" length with the rates I need. Seem to be stuck with a 8" and 22" or 10" and 20. Obviously the 10 and 20 would be the best choice but am I going to see some tuning/other issues with this?
Making sparks and breaking parts.
1993 Dodge W-250 CTD/Getrag 360/205/kingpin HO72/14bolt on 4Ds
2015 Yamaha WR250R
Boons is offline   Reply With Quote Quick reply to this message
Old 04-08-2018, 02:56 PM   #11 (permalink)
Member # 95763
It looks like PAC makes reasonable rates in a 14. What about two 14s with a tender on the top?
Old 04-08-2018, 03:22 PM   #12 (permalink)
Member # 481234
A tender? What the fuck for?
You need preload. The last thing you need to worry about is the springs coming loose when the shock tops out. Dual rate is all that is necessary. It’s 2018.
For the light spring subject, there’s no such thing as too light. Avoid coil bind and stay within the recommended 1”-3” preload and you’re golden. Springs only support the vehicle. Period.
Too much spring causes very dark things to happen that cannot be unfucked with any amount of tuning. Heavy springs are not the fix for shitty link geometry, compression tuning or roll control. Fix it properly. Lazy dumbasses throw spring rate at a problem. Don’t be that guy.
Select the appropriate spring (takes 1 try, best to start way light because the math does the talking after that) then tune tune tune. Valving, piston design, oil volume and weight, and nitrogen pressure.
[QUOTE=DirtRoads;44405898]All you need to go wheeling is a credit score these days[/QUOTE]
Juicysluice is offline   Reply With Quote Quick reply to this message
Old 04-08-2018, 04:35 PM   #13 (permalink)
Canuckastani
Boons's Avatar
Member # 164167
PAC is twice the cost of eibach. $1400 for springs is fucking retarded.
2015 Yamaha WR250R
Old 04-08-2018, 08:40 PM   #14 (permalink)
generalee7's Avatar
Member # 16522
Where are you finding PAC springs twice as much as Eibach? From what I've seen Eibach are more than PAC everywhere.
generalee7 is offline   Reply With Quote Quick reply to this message
Old 04-08-2018, 08:55 PM   #15 (permalink)
Canuckastani
Boons's Avatar
Member # 164167
Gets pretty pricey in Canadian Monopoly money.
$750 for king coils from either poly performance or filthy motorsports.
So $500 for Eibach is pretty damn good unless I'm missing something?
2015 Yamaha WR250R
Old 04-09-2018, 08:25 AM   #16 (permalink)
mobil1syn's Avatar
Member # 9795
how so?
-George Whitefield
Old 04-09-2018, 02:15 PM   #17 (permalink)
TRD
TRD's Avatar
Member # 8286
I don't necessarily agree that springs just hold the vehicle up.
On long travel trucks it's hard to get it wrong, but on short travel stuff spring rate becomes extremely important.
We may have more rates than our website shows. Always best to call if you have a difficult application.
Ryan
Phone: 424-377-0808
Email: [email protected][websiteURL]
Shop
- Custom Spring and Valving Specialists
See what we're up to:
Coilovers, IBP's, Bypasses & Adjustable Shocks In Stock
Now Hiring - Technical Sales Rep
TRD is offline   Reply With Quote Quick reply to this message
Old 04-09-2018, 02:50 PM   #18 (permalink)
ZAG
ZAG's Avatar
Member # 14113
just curious how does one calculate spring rates for one who drives flat terrain and other who does 90% of driving steep uphills and downhills
ZAG is offline   Reply With Quote Quick reply to this message
Old 04-12-2018, 09:44 PM   #19 (permalink)
Member # 161331
This is 100% rock donkey talk. The OP is having problems in the highspeed stuff.
how so?
Not enough spring and it turns into a wallowy pig in the corners. You have 2 options to try and bandaid this.
1. Cut down on the bleed and add a little rebound. This will compromise ride quality and handling in chattery stuff.
2. Really stiff sway bars. This will compromise traction exiting corners.
Old 04-13-2018, 07:01 AM   #20 (permalink)
arse_sidewards's Avatar
Member # 256962
Even with wide open rebound valving a spring with fuck all spring rate is gonna do fuck all of a job getting the axle away from the vehicle in time for the next hit.
Old 04-13-2018, 01:32 PM   #21 (permalink)
Member # 481234
You define short travel as........?
1. My generalized statement applies to linked coil over vehicles without prejudice to application
2. Heavy spring rates are for go fast?
3. Your peepee got really hard typing rock donkey
4. Not enough spring and it turns into a wallowy pig in the corners. You have 2 options to try and bandaid this. Refer to “Heavy springs are not the fix for shitty link geometry, compression tuning or roll control. Fix it properly.”
Fuck/fuck+(3) = what is the point you’re trying to get across? I’ll guess, you’re saying a light spring hinders rebound? Some people believe in Bigfoot or you could share your results and experience in your quest for chassis and shock tuning.
What I read in this derail is people who have the wrong impression or image in their mind of the purpose of the shocks and what’s happening to the chassis and suspension as it cycles. The public education system is flawed. Too much Shakespeare and not enough Newton. At least when I was in. Now they teach 1+1=5 or some shit
Here’s my accused rock donkey (boing)
Race trim KOH 2018 EMC 4500 #4581 official weight 5,123lbs. 55/45 split. 1-1/4 rear sway bar, 150/200 14” springs rear with 2” preload and 200/250 front 14” and 16” springs 1” preload. Sumbitch corners like a dream on asphalt or dirt-locked front and rear. I plan to remove spring rate from the front still. Of course there’s link geometry, shock angles, shock magic, unsprung weight and other factors that make my setup work or wrong in your eyes because variables.
Old 04-13-2018, 04:32 PM   #22 (permalink)
Member # 161331
Agreed, likewise giant swaybars should not be used to make up for lack of spring rate.
With a KOH rig it's always going to be a compromise, Getting it to work real well in the rocks will have you giving up speed in the fast sections. With a single shock rig it gets even worse. OP's problem.........
Rock Donkey
Old 04-13-2018, 06:35 PM   #23 (permalink)
Member # 56430
Karl..... you're polishing a turd, at this point. Time for you go buggy, or, something like John's rig.
:Your Signature: cannot include the words; Your, Signature.
Treeclimber is offline   Reply With Quote Quick reply to this message
Old 04-13-2018, 08:04 PM   #24 (permalink)
Member # 95763
Yeah, but this turd works so well in the rocks. Getting it to go fast has been a challenge. If I can't do that after this iteration, I'll just leave it for trail wheeling and we-rock stuff.
Maybe a new rig after I "finish" my 1975 cherokee project.
Old 04-15-2018, 11:05 AM   #25 (permalink)
mobil1syn's Avatar
Member # 9795
what valving is in the shock now? where are your crossovers set? how many bleed holes are open on the piston? ooh and PAC or ebiach are the only springs worth running, let alone spending money on.
i dont disagree, but your comparing oranges and avocados. while both citrus, one goes great on tacos the other not so much.
if the OP has less than 5" of uptravel with a 14" shock, he needs to be focusing on getting some uptravel before buying springs.
if you have a wallowy pig in the corners following what is laid out in the spring rate thread then you have poor suspension geometry. go look at footage or pics of bomber #1, that thing torque leaned and cornered poorly because the uppers at the chassis had little horizontal separation (running the 4spd in 2:1 all the time just made it worse). he has increased the separation and the newer ones dont torque lean and corner significantly better.
once you have good ride quality and are progressing as a driver then yes there are things you can do to fine tune or take a creative approach to address a specific issue that generally is a bandaid for poor geometry.
no all shocks are the same, some are better than others and flowing fluid.
-George Whitefield
