Fox or King Internal Bypass Coil-Overs - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-20-2018, 09:22 AM   #26 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
Originally Posted by DriverJC View Post
Thank you for the real world advice. I have been leaning toward Fox shocks, however, budgeting constraints have me looking at Kings as well due to the $100/shock difference in price.
Thanks again.
Joel
im willing to bet your price savings on kings will be negated once you start messing with valving, at ~$4/shim it adds up quick where as fox is ~$1.
also keep in mind the fox is a low take off reservoir from a flow path stand point which is a big deal.
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote Quick reply to this message
Old 04-20-2018, 09:32 AM   #27 (permalink)
NERD
gtxracer's Avatar
Member # 25303
+1 for Fox, I run 2.0 coilovers all around with 2.0 bumps in front. 2.5 bypasses going into the rear. Kings are the "cool guy" shock, as I've seen it, with Fox always being the best bang for your buck. Also noticed that Fox and Radflo have very similar designs and lengths which helps when tuning and setting up shock mounts. King and Swayaway have unique features, lengths, and tuning setups which makes it a giant PIA to work on your shocks.
IBP shocks are great for packaging but I'd take a coilover and ext bypass shock over an IBP on the rear axle any day. Much better for tuning and practicality.
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote Quick reply to this message
Old 04-20-2018, 09:37 AM   #28 (permalink)
Member # 161331
Helpful for that extra small piston.
bdkw1 is offline   Reply With Quote Quick reply to this message
Old 04-20-2018, 10:18 AM   #29 (permalink)
hurleygo3's Avatar
Member # 80862
IBP's can be a much better setup for cars with very little sprung weight. I would also say a much better option for a trail car. Packaging is much easier, cost is much less and a much lighter setup.
Mike Johnson #43 7 time EMC KOH finisher, 6 top 5's
hurleygo3 is offline   Reply With Quote Quick reply to this message
Old 04-20-2018, 10:44 AM   #30 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
Send a message via ICQ to DriverJC Send a message via Yahoo to DriverJC
...also keep in mind the fox is a low take off reservoir from a flow path stand point which is a big deal.
Can you tell me what a "low take off reservoir" is or does? I've never heard that term.
Running a separate Bypass shock in the rear might be something to look into once I start working the rear end. Although it would add another approximately 1200 to the cost of this build.
Thanks for all the info. I am going with Fox shocks, just not sure if I get the IBP's with DSC or just the DSC's
Joel
DriverJC is offline   Reply With Quote Quick reply to this message
Old 04-20-2018, 01:03 PM   #31 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Joel
There was a set of Fox 2.5 IBP with DSCs in the classifieds a few months ago, so it can be done.
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 04-20-2018, 01:10 PM   #32 (permalink)
hurleygo3's Avatar
Member # 80862
Every pair of FOX IBP's I've seen have had DSC on them. Including the ones I have.
Old 04-20-2018, 02:33 PM   #33 (permalink)
Member # 700186
On the brand part. Fox and King both have great quality. I find fox to be a lot better on the support side.
If I wasn't racing I wouldn't do bypass. Its just not worth it for the money IMO. But that's just me. Cheers.
Buck Wild Racing is offline   Reply With Quote Quick reply to this message
Old 04-20-2018, 03:11 PM   #34 (permalink)
Weasel's Avatar
Member # 5639
That's my 2 cents as well.
Kindness doesn't condemn or condone
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
Old 04-20-2018, 09:12 PM   #35 (permalink)
mobil1syn's Avatar
Member # 9795
Joel
on a regular coilover the pressure in the reservoir keeps the oil in place while the piston travels through it. what happens on a top take off reservoir is that occasionally you get the piston moving fast then the reservoir can build pressure to keep it in place so the piston push the oil into the reservoir instead of it passing through the piston. this is called cavitation. on a low take off reservoir the top cap of the shock is what is keeping the oil in place so you dont have to cavitation.
i went and checked out your build thread and props for building in the dirt, youre way more dedicated then i would ever be.
-George Whitefield
Old 04-21-2018, 09:34 AM   #36 (permalink)
Member # 161331
Also, a bottom mount resi will pass more fluid through the piston than a top mount due to shaft displacement. Although it's still not enough to make up the difference in size between a 2.0 piston and a 2.5..........
Old 04-21-2018, 12:19 PM   #37 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
Thanks for the information and the props. I would much rather build it in the garage, but unfortunately it's full. lol...
Joel
Old 04-21-2018, 09:30 PM   #38 (permalink)
pcoplin's Avatar
Member # 17986
Fox has just raised the price to $2 a shim.
98 TJ LQ4/TH400
FullStack MotorSports
pcoplin is offline   Reply With Quote Quick reply to this message
Old 04-21-2018, 09:42 PM   #39 (permalink)
mobil1syn's Avatar
Member # 9795
steel has gone up quite a bit since the beginning if the year. expect everything offroad related to be on the rise
-George Whitefield
Old 04-21-2018, 10:10 PM   #40 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
And king is raising their prices as of the end of the month.
Old 04-22-2018, 10:19 AM   #41 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
To All,
Thanks for the advice and information you all have given me. I'm going to be going with the Fox Factory Series 2.5" x 16" travel Coil-Overs w/ Remote Reservoir and DSC.
Thanks again.
Joel
Old 04-22-2018, 12:38 PM   #42 (permalink)
mobil1syn's Avatar
Member # 9795
To All,
Thanks again.
Joel
id suggest a 14”. with your sprung to unsprung weight you may run into soring rate problems, plus 16” make an axle swing a lot during articulation. quality over quantity
-George Whitefield
Old 04-22-2018, 12:43 PM   #43 (permalink)
NERD
gtxracer's Avatar
Member # 25303
X2 or go with trailing arms
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 04-22-2018, 01:25 PM   #44 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
That’s another term I haven’t heard yet. Can you explain what Soring Rate Problems are?
Old 04-22-2018, 01:28 PM   #45 (permalink)
mobil1syn's Avatar
Member # 9795
soring is fat fingers and lack of proof reading. soring was supposed to be spring.
-George Whitefield
Old 04-22-2018, 01:52 PM   #46 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
No problem. I kind of figured when I googled it and nothing came up but interest rate stuff. lol...
However, can you elaborate on the Spring Rate Problems I might face?
Old 04-22-2018, 02:12 PM   #47 (permalink)
mobil1syn's Avatar
Member # 9795
for a 16” shock youll need a 18” lower spring and a 16” upper. my hunch is that you been in the 150/250 range on springs for a 14” shock in the front and 100/125 in the rear. going to a 16” shock makes the rates drop and finding a 18x150 or 100 in the rear difficult and the springs will bow eating shocks.
if you havent read the spring thread started by zukizzy go give it a read.
-George Whitefield
Old 04-22-2018, 03:00 PM   #48 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
I weighed the Jeep prior to starting this build and came up with an unsprung weight distribution of 51% front and 49% Rear the weights were (without me in it )
RF: 820.5
LF: 838.5
RR: 848.5
LR: 754.5
I used the average to calculate the spring rate I would need for the 16" shocks and it looks like for the fronts and rear I get 16" 125/ 18" 200 ( 3" Preload, 7" of shaft showing and an installation angle of 20* ).
Unless I did something very wrong on my math, which is completely possible for my Public School Education. lol
Thanks for the advice, I haven't ordered anything yet and won't until most likely next month.
Joel
Old 04-23-2018, 09:41 PM   #49 (permalink)
mobil1syn's Avatar
Member # 9795
you should only have 1" of preload in the front and 2" in the rear. you are better off not ordering springs until the thing is assembled and you can back calculate actual information.
read this
https://www.pirate4x4.com/forum/gener...ch-thread.html
-George Whitefield
Old 04-24-2018, 05:03 AM   #50 (permalink)
GIJEEPN
DriverJC's Avatar
Member # 135100
read this
When I first read that thread ( a couple weeks ago ) I calculated the spring rate based on the information in that thread including ZukIzzy's stated 2-3" ( I used 3" ) of preload.
However, the more I think about the set up of these things the more I think you might be right about going down to 1" of preload, as it will give me room to adjust for extra parts, gear, etc...
I'm not set on the 16" shocks, however, I am attempting to build it to utilize them.
Thanks for the advice this is definitely a learning experience.
Joel
Hopefully, I will be purchasing the Shocks next month so I have time to think about things.
