My fab 9 full float on a budget - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-30-2018, 08:29 AM   #1 (permalink)
Member # 174458
This is my DIY budget fab ford 9. I used corporate 14 bolt outters and tabbed the housing myself. I used the tubes and spindles from the 14 volt as well. I machined the C&C hubs for 5x5.5 with 9/16 studs. I used a Yukon nodular 3.25" third with a Daytona pinion support and a 35 spline yukon grizzly locker. And dutchman axle made me the custom shafts to tie it all together. I wanted a fab 9 and had to build it on my budget. The hardest part definitely was bending the cones on the belly of the housing.
TRAIL RAIDED @trail_raided
2000 xj, aw4 nwf eco-I doubler d300, narrowed d44 and 8.8 etc
deemac is offline   Reply With Quote Quick reply to this message
Old 04-30-2018, 08:32 AM   #2 (permalink)
Member # 174458
Some more pictures.
Old 04-30-2018, 08:35 AM   #3 (permalink)
Member # 174458
Some more pictures. It can be seen more on my Instagram @trail_raided
Old 04-30-2018, 09:31 AM   #4 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
nice.
dumb question, are the seals all one part of the hub?
Old 04-30-2018, 12:29 PM   #5 (permalink)
Member # 11757
Send a message via AIM to slowJEEP
Damn, that's some handsome work. What'd the shafts run you?
99 TJ
85 k10
slowJEEP is offline   Reply With Quote Quick reply to this message
Old 04-30-2018, 12:58 PM   #6 (permalink)
whitneyj's Avatar
Member # 135947
Hats off. I love the DIY aspect of everything. Would you do this again? Or just buy a housing?
Place banana in your ear.
Observe that there are no alligators around.
Conclude bananas placed in ears keep alligators away.
whitneyj is offline   Reply With Quote Quick reply to this message
Old 04-30-2018, 04:41 PM   #7 (permalink)
Member # 174458
Yeah the seals are on the back of the hubs. The bearings are bathed in oil.
Would I do it again? Yeah i think i might build one for the front eventually. I could build a second one faster I think.
Old 04-30-2018, 04:44 PM   #8 (permalink)
Member # 174458
Dutchman has all their pricing up on their website. They are the same price as a set of full float axles for a dana 60 or whatever. Same price for any set of full float shafts. The shafts were really well done. They fit perfectly. I had them turn theflange down to fit my hubs and they were perfect. Really really happy with the shafts. If you need some, give dutchman a call.
Old 04-30-2018, 07:27 PM   #9 (permalink)
Member # 203218
How did you keep everything flat, square, true, ect? An alignment bar or anything else to fixture it? If so have any pics?
I'm interested in this kit C/E4210 -Mild Steel Weld Up Kit but I'm worried about keeping it straight enough to not fatigue the shafts long term.
wadey is offline   Reply With Quote Quick reply to this message
Old 05-01-2018, 07:47 AM   #10 (permalink)
Member # 83301
@Syrings72
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 05-01-2018, 09:04 AM   #11 (permalink)
Member # 66955
I would say an alignment bar is bare minimum best would be a jig as well. That's a lot of pieces that have to be almost perfect after a lot of welding/heat.
sherm$ is offline   Reply With Quote Quick reply to this message
Old 05-01-2018, 09:28 AM   #12 (permalink)
Member # 9835
Thats some pretty amazing home fab work
ChiScouter is offline   Reply With Quote Quick reply to this message
Old 05-01-2018, 10:13 AM   #13 (permalink)
Member # 187534
Got any pics of the housing with the third removed?
707offroad is offline   Reply With Quote Quick reply to this message
Old 05-01-2018, 07:09 PM   #14 (permalink)
Member # 174458
Unfortunately I didn't take any pictures of the housing with the third removed. Yes I used an alignment bar i bought from speedy metals. I machined all the alignment pucks myself. And I machined some that thread onto the spindles to hold the tube straight. I fit it all up and tacked it then pulled the tubes out and welded the belly together inside and out and I welded a skidplate on the bottom before the tubes were put in as well. The belly takes a lot of heat and I did have to massage the fit a little bit to get the tubes back in and fitting nice. There is also an internal bulkhead to hold the tubes better. Then I slid the tubes in with pucks in the mockup third and a puck on each end of the tube. It came out nice and straight. Housing is dead on, at least for the moment.
Old 05-01-2018, 07:11 PM   #15 (permalink)
Member # 174458
A few more pictures of the housing
Old 05-01-2018, 07:17 PM   #16 (permalink)
Member # 174458
By far the hardest part was forming the cones on each side of the housing. I don't use CAD so the math was done on paper. It was CAD=CARDBOARD ASSISTED DESIGN
Old 05-02-2018, 04:40 AM   #17 (permalink)
Member # 650161
Damn nice work.
telewacker is offline   Reply With Quote Quick reply to this message
Old 05-02-2018, 07:17 AM   #18 (permalink)
Wilson's Avatar
Member # 7233
How many hours would you guess are invested into this?
Old 05-02-2018, 08:37 AM   #19 (permalink)
Member # 174458
I didn't keep track and it's kind of hard to say how many hours. I just worked on it a little here and there. Sometimes it would sit for a month or more without any work done. I figure I saved approx $2500 when you figure on buying 5x5.5 hubs. (These are c&c hubs so I haven't seen any you can even buy for to get this wms) and you buy a housing and spindles and perches etc. And a big part of why I built it was to see if I could do it. For the challenge.
Old 05-02-2018, 08:34 PM   #20 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
Great job, looks like it turned out killer.
desertCJ is offline   Reply With Quote Quick reply to this message
Old 05-03-2018, 07:47 AM   #21 (permalink)
today
fredycruger's Avatar
Member # 225557
nice work !!
fredycruger is offline   Reply With Quote Quick reply to this message
Old 05-03-2018, 08:12 AM   #22 (permalink)
Member # 85771
Turned out great.
Make Forums Great Again!
Old 05-03-2018, 03:54 PM   #23 (permalink)
desertCJ's Avatar
Member # 9026
What rotors are those? Samurai?
Old 05-03-2018, 06:03 PM   #24 (permalink)
Member # 174458
They are explorer rotors and calipers and brackets etc
Old 05-03-2018, 07:13 PM   #25 (permalink)
daddytall's Avatar
Member # 74936
Damn, that is sweet.
Cancer really sucks.
My daughter kicked ass.
I miss my Kayla.
daddytall is offline   Reply With Quote Quick reply to this message
