First Buggy Attempt - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-13-2018, 07:11 PM   #1 (permalink)
BiggernBetter's Avatar
Member # 558554
First Buggy Attempt
started this back in August 2016, its my first attempt at a full on buggy build. I have had a lot of help from my friend Cory, hes let me take u the half of the garage for 2 years now and i cant thank him enough. shes roughly 70% complete, just down to all the little shit now.
Anywho heres the specs:
Motor:
90's 454 TBI - All prettied up with lots of chrome/polished stuff and a new coat of paint and seals. upped the TBI with a higher pressure return spring injector spacer, TB spacer, and a full rebuild. all new sensors on it and an MSD Distributor and coil. Exhaust is some amazon special heaers cut up and re angled going into a 2.5" tubing to a flowmaster 44 series with a 3" tail pipe. using a high flow oil pump and shorter pickup tube to match the shallow car pan. belt system is a flat 8 rib. Using a chromed 200AMP alternator to power up everything. all guages for it are Autometers.
Trans:
80's Turbo400HD built up with all USA parts and a Hughes reverse manual valve body with engine braking. Torque Converter is a Hughes GM2200-2400 Stall. using a derale cooler and fan with a deeper pan and plans to add a second cooler.
Tranfercase
Went with an Atlas 2 packed with all HD internals and 4.3 Gears. used a northwest flange for the rear so i can use the rockwell flanges
Axles
70's Rockwell 2.5s both steering. all re sealed and bearings from Rockwelloffroad.com, Chromolly Shafts from Boyce Equipment, and lots of time sucking in lead paint from cleaning. Planning on picking up some ouverson drive flanges soon too.
Suspension
Shocks are 2.5x16 King coil overs on all four accompanied by King 2x4 Bump stops. Heims are from Rockwelloffroad.com, all 1.25" Right and left hand. Aluminum Links are by the awesome guys at Wide open design, all the same length of 34", 2" upper and 2.5" lowers. wheelbase is set right now at 120"
Wheels and Tires
Currently its a st of custom made H1's re-centered with Trail worthy inserts wrapped in 46" Mickey Thompson baja claws that are in ok shape, most around half tread.
Steering
Both Rams are PSC 3x9, PSC Orbital to match, Front Power steering pump is from Lee's steering, P series setup with a #12 feed and #8 pressure running at 1900 PSI with a 10% reduction pulley. PSC res and a derale 18" cooler. Rear is a full electric setup by Leroy Latham, custom hydraulic pump and res pushing 2100psi and 7.8GPM (if im remembering right) etc accompanied by his RTC kit.
then etc etc blah blah, heres some pics and a link to my original build thread
Final ride height is 6'7" with 26" of ground clearance
u-s-a
BiggernBetter is offline   Reply With Quote Quick reply to this message
Old 05-13-2018, 07:17 PM   #2 (permalink)
Member # 558554
so updates are usually spaced due to me working out of state so bare with me. heres the latest. figured out the brake pedal setup. used willwood 1" cylinders and custom pedals. Cory machined up the clevises and spacers in his mill then we cut out the pedals and arms on the plas table
u-s-a
Old 05-13-2018, 07:20 PM   #3 (permalink)
Member # 558554
and also got the bump stops mounted up
Full extension.
Here you can see the rub mark on the pads during suspension cycling
And then once theyre coming down they hit tese little ramps and start compressing
u-s-a
Old 05-13-2018, 08:06 PM   #4 (permalink)
Member # 69690
Sub'd here and RME, nice build you have going!
You'll either get over it or die from it.
Toysupra1 is offline   Reply With Quote Quick reply to this message
Old 05-13-2018, 09:01 PM   #5 (permalink)
Member # 481234
Top notch fabrication from MFL. Lookin good man. So excited to see you’re almost finished with it.
Juicysluice is offline   Reply With Quote Quick reply to this message
Old 05-13-2018, 09:14 PM   #6 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
is it just me that can't see the pictures? i'm not a member at the linked site so i can't view anything more than a tiny thumbnail there.
sounds like a badass time
Provience is online now   Reply With Quote Quick reply to this message
Old 05-13-2018, 10:03 PM   #7 (permalink)
Member # 684754
its not just you.
RMKrawler is offline   Reply With Quote Quick reply to this message
Old 05-13-2018, 11:25 PM   #8 (permalink)
Member # 558554
Sorry guys, ill find a server i can upload them and get them to work shortly
u-s-a
Old 05-13-2018, 11:39 PM   #9 (permalink)
Member # 558554
Let me know if these work!
u-s-a
Old 05-14-2018, 06:17 AM   #10 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
hey those work!
mind if i ask how long you brake pedal assembly and pedal ratio is for using those 1" master cylinders?
Old 05-14-2018, 07:35 AM   #11 (permalink)
Member # 83301
no dice on pics for me, what server are you using?
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 05-14-2018, 09:51 AM   #12 (permalink)
Member # 23843
I hate to be the guy that tells ya this......roller with drivetrain is about 40-50% done all the little details and more thinking time than working comes when you're making panels , endless brackets and tabs and figuring out where and how to hang it all......oops don't forget wiring and plumbing steering and brakes!
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!!
Rock Ape is offline   Reply With Quote Quick reply to this message
Old 05-14-2018, 12:34 PM   #13 (permalink)
Member # 228875
Tell me about it ! I've been 90% done my Formula Ford for 2 Years ! The tiny details and packaging conflicts drive you crazy. Now I know why the Trans-Am team I crewed for named their car "Minutia" ....
stephen wilson is offline   Reply With Quote Quick reply to this message
Old 05-14-2018, 01:18 PM   #14 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
that is the fun stuff though!
Old 05-14-2018, 06:15 PM   #15 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
cool buggy. thanks for sharing!
MNorby is offline   Reply With Quote Quick reply to this message
Old 05-14-2018, 08:33 PM   #16 (permalink)
Member # 189239
It was a Roller with in the first month we started this pile back in 16'. He is really close now wrapping up the little things. He has already wired, plumb, and started the motor. The trans just got back from being rebuilt. last month he fully rebuilt both axles and stuffed some chromolly shafts in it. Mount the gas tank, engine skid, and some interior panels are the larger tedious things left. He was working on brake lines when i left which will be rather simple with only two calipers all together. Austins good at tedious shit.
I hear you though on the little details. I just wrapped up my single seater buggy after 4 years, It was a roller in a month too
YROC FAB. is offline   Reply With Quote Quick reply to this message
Old 05-15-2018, 01:41 AM   #17 (permalink)
Member # 838146
holy hell
tnertb is offline   Reply With Quote Quick reply to this message
Old 05-15-2018, 07:40 AM   #18 (permalink)
Member # 558554
hey those work!
we went with a 1.5" to 10 on it
u-s-a
Old 05-15-2018, 07:42 AM   #19 (permalink)
Member # 558554
Yea that ^
u-s-a
Old 05-15-2018, 11:42 AM   #20 (permalink)
Member # 23843
The fun stuff it a roller with drivetrain...then the pain begins!!!
I wasn't baggin on anyone... I literally have to space out the fun parts of a build (after its a roller with drivetrain) to keep me motivated to finish it.... or start gathering parts for the next build...thats good motivation to finish the current one!
Cool build either way.... because who doesn't love a BIG BLOCK CHEVY?
Old 05-15-2018, 04:47 PM   #21 (permalink)
Member # 189239
I didnt think you where baggin anyone. I was just trying to get a little more info on the build since Austin sucks at posting
Old 05-15-2018, 06:10 PM   #22 (permalink)
Member # 232666
this looks really good! Great fab work. I hope you get it finished soon so you can enjoy the fruits of your labor.
Originally Posted by 03f350
... Well first off FUCK JEEPS..
sterlingfire is offline   Reply With Quote Quick reply to this message
Old 05-15-2018, 07:13 PM   #23 (permalink)
Member # 181868
Sub'd
Project : Amphibious HEMTT
Old 07-15-2018, 02:46 PM   #24 (permalink)
Member # 558554
sory yall been slammed with our buddies crap and work etc, anywho update time
I started working on my floor pans with all the scraps around the shop after cory gave me a quick crash course on his tig.
While i was doing this cory knocked out my fuel cell mount/hold down and my roof bars and tabs
Also had him burn in a helmet/wheel hook since he was there.
u-s-a
Old 07-15-2018, 02:49 PM   #25 (permalink)
Member # 558554
Next project cory tackled was the dash and i couldnt be happier with the fitment etc, did an awesome job!
and while he did that i was tinkering with the gas pedal and got it positioned and cable done up, now i can smash on it and make motor noise. also burned in my second trans cooler
All i got for now, but we are planning to get ALOT dont this hitch so ill keep it updated
u-s-a
