Magnesium run flats - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-17-2018, 07:09 PM   #1 (permalink)
Member # 98973
Magnesium run flats
I have some old 8 bolt run flats. Will they work with my 12 bolt wheels? They have been trimmed down. The width have not been trimmed. I don’t have a extra $200.00 for the pvc run flats. My tires are super swamper 44x18.5x16.5. They worked with my 8 bolt wheels. They leaked where the two pieces bolted up. They where pitted really bad. That why I got the 12 bolt wheels
bronco1ab is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 07:03 AM   #2 (permalink)
arse_sidewards's Avatar
Member # 256962
Originally Posted by bronco1ab View Post
I have some old 8 bolt run flats. Will they work with my 12 bolt wheels? They have been trimmed down. The width have not been trimmed. I donít have a extra $200.00 for the pvc run flats. My tires are super swamper 44x18.5x16.5. They worked with my 8 bolt wheels. They leaked where the two pieces bolted up. They where pitted really bad. That why I got the 12 bolt wheels
As far as I know the wheel width didn't change so they should work. It's not like it costs you money to try.
Old 06-18-2018, 07:38 AM   #3 (permalink)
Atomic Test Lab Rat
Member # 25325
More likely they leaked because the inserts are too wide. I couldn't get my 42 TSLs to bolt together on my 8 bolts without going to a narrower insert. You can cut down the magnesium ones (width), I have one in my spare that
I cut 1/4" off each side using a sawzall.
IDI F250 Crawler
redranger4.0 is offline   Reply With Quote Quick reply to this message
Old 06-18-2018, 07:56 AM   #4 (permalink)
Member # 98973
Thanks I was thinking about cutting 3/8 off of them. I finally found something on them. Some people are saying 1/4 to 1/2. Thought I would do between the to.
Old 06-18-2018, 08:19 AM   #5 (permalink)
Atomic Test Lab Rat
Member # 25325
It was pretty easy, just time consuming, knock off the aluminum guards on the sides and cut them then put the guards back on.
IDI F250 Crawler
Old 06-18-2018, 08:25 AM   #6 (permalink)
Member # 98973
Thanks for the help. It is ok to cut just one side isn’t it?
Old 06-18-2018, 08:48 AM   #7 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
They leaked because the insert was too wide with the 44. The flange couldn't clamp down on the oring.
Will be worse with the 12 bolts.
We could have corrected the issue with PVC instead of new wheels. The 12 bolt is a more sustainable platform for the future. So it is a legit upgrade.
I'll answer your email about width if you publicly state you won't hold me liable.
Old 06-18-2018, 08:52 AM   #8 (permalink)
Atomic Test Lab Rat
Member # 25325
I did both sides, so that the flanges where the two halves bolt up weren't funky.
IDI F250 Crawler
Old 06-18-2018, 09:14 AM   #9 (permalink)
Member # 98973
You won’t be liable for anything. This rig never see the street. I wish I had the extra money for the pvc run flats.
Old 06-18-2018, 09:36 AM   #10 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
If you mounted the 44's on stock width wheels with stock width mags you should look at the bead on each tire on each side and make sure it isn't damaged. Usually people spread the 8 bolt wheel apart going that route. The stock outer width on the 8 bolt wheel is 9.75". If you have something wider than that then the wheel is damaged.
The stock width on the 12 bolt wheel varies from 9.5" to 9.625".
If your wheel is stock width and the bead width is 1" on the 44's you need that stock mag to be somewhere around 6.5" wide.
All of that is based on your wheel being the stock width and the bead width I mentioned. If the bead on the tire is damaged in any way the insert will need to change with it.
Old 06-18-2018, 09:51 AM   #11 (permalink)
Member # 98973
I ordered the wheels from you a few months back. If I had the money I would have gotten the run flats to. The wife about cut my sack off with everything I ordered from you. Thanks for the help. Everything you sold me is top of the line.
Old 06-18-2018, 09:59 AM   #12 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
I have some end pieces of the pipe that we sell at a discount. Absolutely nothing wrong with them other than they don't look like the full body pieces. If you get there let me know and I'll work you a deal on them.
Old 06-18-2018, 10:09 AM   #13 (permalink)
Member # 98973
You said you have some end pieces. What do you mean by don’t look like full body pieces. If they will work just fine how much shipped to 64151 in Kansas City missouri. It’s a residential.
Old 06-18-2018, 10:16 AM   #14 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
You said you have some end pieces. What do you mean by donít look like full body pieces. If they will work just fine how much shipped to 64151 in Kansas City missouri. Itís a residential.
Send me an email and I'll email you the pics.
[email protected]
