Full hydro pump noise - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-28-2018, 09:13 PM   #1 (permalink)
Member # 179421
I have a psc double ended ram, Eaton valve, and a new Saginaw pump. Pump started whining last trip. First replaced the filter, topped off and bled system. No difference. Pump had allot of end play so I replaced it, topped off and bled system. Still whines.
All I can think is it's drawing air in somewhere. Can't find any leaks. Not sure where to go from here.
Any pointers?
banjobend is offline   Reply With Quote Quick reply to this message
Old 06-28-2018, 09:53 PM   #2 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
foamy fluid?
Provience is online now   Reply With Quote Quick reply to this message
Old 06-28-2018, 10:03 PM   #3 (permalink)
Member # 179421
Originally Posted by Provience View Post
foamy fluid?
I wouldn't say foamy. But there are some tiny bubbles in the fluid. The surface is free of foam.
Old 06-29-2018, 07:41 AM   #4 (permalink)
nvrstuk@elltel.net's Avatar
Member # 63366
So its a new pump then? Still has air in tbe system and thats causing the noise and bubbles.
I had small bubbles after following PSC's step by step how to bleed the system 2X. Drove me nuts, did it again and bubbles dissappeared... easy to have a little air trapped in the system...
'68 Bronco, 100" WB, 460sbf dyno'd at 597hp/710ftlbs, 24 fwd gears, 4r70w, KluneV, 205, ORI's...
nvrstuk@elltel.net is offline   Reply With Quote Quick reply to this message
Old 06-29-2018, 08:26 AM   #5 (permalink)
Member # 179421
Yes, new reman pump. But the old one whined too. Done the psc bleed procedure several times. Lock to lock, wait, lock to lock, wait. Probably a dozen times.
Old 06-29-2018, 08:36 AM   #6 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
How big of a ram are you running and what's your axle/wheel/tire/scrub radius setup?
Old 06-29-2018, 08:43 AM   #7 (permalink)
Member # 179421
2x8psc DE. king pin 60. Centered h1s. 42 inch pitbulls. The funny thing is, it worked flawlessly for the last year.
Edit: it's a 2.5x8 ram
Old 06-29-2018, 08:48 AM   #8 (permalink)
ANGER IS A GIFT
Dookey's Avatar
Member # 23680
I had this same scenario with my TJ. May not be your problem but it is worth looking into.
PSC system. So all the pieces came from PSC. I had my pump off and back to them multiple times before I got really pissed off sitting at the trail head in Arizona. The next week I took all the stuff off and sent it back. Tom called and asked what I was doing. I was running a 2.5" ram with really wide everything and he stated that my pump was having to work at its maximum capacity at all times just to function. So I kept burning them up.
Swapped to a 2.75" ram and haven't had an issue since.
Old 06-29-2018, 10:21 PM   #9 (permalink)
Member # 145841
Billavista hydro steering bible gives some information on whining.
warrencj6 is offline   Reply With Quote Quick reply to this message
Old 06-30-2018, 06:11 AM   #10 (permalink)
H M F
Im4yotas's Avatar
Member # 8758
Is the whine constant? Just at high RPM? Just at full lock? Or maybe just at idle?
The pump pulling too much suction due to restrictions in the supply line will cause the same cavitation problem as sucking in air.
Drive it like Tim!
Im4yotas is offline   Reply With Quote Quick reply to this message
Old 07-03-2018, 05:06 PM   #11 (permalink)
Member # 179421
Only when under load and above idle. I bypassed the filter and cooler to help narrow it down. Currently have an 8 inch return from the valve to the pump, no kinks or restrictions. Still whines.
Anyone have a way to troubleshoot an Eaton steering valve?
Old 07-04-2018, 05:01 PM   #12 (permalink)
Member # 179421
Also, I'm running an inline fluid filter. I believe it's for tranny fluid. Would that make to much resistance?
Old 07-04-2018, 08:32 PM   #13 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
get a pressure gauge it will tell you a lot.
ive also heard of hydro boost guys having issues getting the proper pump because they lump
all of the hydro and non hydro pumps under one pn. so its hit and miss if you get a pump that flows and builds enough pressure.
as i get older buying a complete system from howe or psc doesnt seem so expensive once i factor in my time chasing issues cause by parts not being deaigned to work together.
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote Quick reply to this message
