JHF-Goatbuilt Chassis - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-20-2018, 01:15 PM   #1 (permalink)
hurleygo3's Avatar
Member # 80862
Building a JHF-Goatbuilt chassis for a buddy. Figured I start a thread on here.
Specs
Stroked LS1
th400
Atlas 3.0
9" axles, all Spidertrax
MEGA Hi-9's
14" FOX IPB's
39" Krawlers
110" WB
82" Wide
Started on it a few weeks ago. Rear axle is cut down, link mounts on, and rear shocks mounted. Motor and trans, and case are mounted.
Mike Johnson #43 7 time EMC KOH finisher, 6 top 5's
hurleygo3 is offline   Reply With Quote Quick reply to this message
Old 07-20-2018, 01:19 PM   #2 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
& Blaine
:tank:
Old 07-20-2018, 01:32 PM   #3 (permalink)
Member # 129493
Sounds like it'll be a blast. Do you know the manufacturer and model of your bead locks (the ones in the first few pictures, not the orange-ish one in the last picture)?
My sincere thanks to
for making the
happen in 2018. Additional thanks to East Coast Gear Supply, PSC, & WFO Concepts for their excellent products and support.
LowDown is offline   Reply With Quote Quick reply to this message
Old 07-20-2018, 01:52 PM   #4 (permalink)
hurleygo3's Avatar
Member # 80862
Fuel Off-Road. Great wheel with a forged outer ring.
Old 07-23-2018, 09:24 AM   #5 (permalink)
hurleygo3's Avatar
Member # 80862
Rear end is finished and read for final welding. Got the front end cut down and shock and lower link mounts in place.
Old 07-23-2018, 11:36 AM   #6 (permalink)
Member # 23843
What....No Portals....? I thought those came in the kit now!
THANKS TO MY SPONSORS....TFAB,TRAIL-GEAR,YUKON,TORCHMATE AND RUFFSTUFF!!!
Rock Ape is offline   Reply With Quote Quick reply to this message
Old 07-23-2018, 02:58 PM   #7 (permalink)
hurleygo3's Avatar
Member # 80862
I don't think this chassis is ideal for portals. Unless you like a buggy that is 8' tall.
I dig the portal axles. But with the way this chassis is designed. It'd be hard to keep it low enough.
Old 07-24-2018, 10:28 AM   #8 (permalink)
Member # 97574
UC Fab said his is 71" with 39s at ride height.
https://www.facebook.com/groups/OFFROADCNCFILESHARING/
ROXROES is offline   Reply With Quote Quick reply to this message
Old 07-24-2018, 10:58 AM   #9 (permalink)
hurleygo3's Avatar
Member # 80862
Kyle's is far from finished. My car has 9" axles with 7" of uptravel. I had to notch the frame to get that up travel. I'm at 70-71" to the roof. Portals are about 6" taller? So if he also notched the frame. He's got 1" of uptravel? I'm also on 37" tires.
The GB chassis is 52" from subframe to roof line. When I was building car I had talked to Jesses about portals. He said sure, but the car will sit pretty tall.
Old 07-24-2018, 11:12 AM   #10 (permalink)
Member # 97574
Just repeating what I read, it looked like it had 4-5" uptravel. iirc the portals are 4-5" taller?
Old 07-24-2018, 11:49 AM   #11 (permalink)
hurleygo3's Avatar
Member # 80862
I get it. Some of the issues with this chassis are uptravel and link separation. To get one you have to sacrifice the other. The rear you have a bar that limits uptravel of the upper links. The front you have the winch mount and engine mounts. This car will see some high speeds. So it needs a solid 7" of shaft showing. I'd like to have a roof line of 72", that means a belly of 20" with 7" of shaft on a 39" tire.
Old 07-24-2018, 12:30 PM   #12 (permalink)
Member # 7903
Thanks for moving faster on your build my slow ass. Will be good for reference.
JohnnyJ is offline   Reply With Quote Quick reply to this message
Old 07-24-2018, 09:46 PM   #13 (permalink)
Fl-Krawler's Avatar
Member # 47337
3.9"
I had to do a 9" raise in my frame rails to clear my portals at full stuff with 45" tires
Fl-Krawler is offline   Reply With Quote Quick reply to this message
Old 07-25-2018, 12:35 PM   #14 (permalink)
Member # 135421
Looking good, what are your thoughts on a Jeep 4.0 fitting in there?
SMCRUZ13 is offline   Reply With Quote Quick reply to this message
Old 07-25-2018, 02:08 PM   #15 (permalink)
hurleygo3's Avatar
Member # 80862
I'd be tight up front. Would have to go rear radiator.
Old 08-14-2018, 12:21 PM   #16 (permalink)
hurleygo3's Avatar
Member # 80862
Almost a roller. Pulling the axles to do final welding.
Old 08-14-2018, 05:22 PM   #17 (permalink)
pcoplin's Avatar
Member # 17986
Looks great! Must only be able to do HP thirds in front?
BTW, did you have the front IBPs converted to external resi? I saw there was a top cap available for that.
98 TJ LQ4/TH400
FullStack MotorSports
pcoplin is offline   Reply With Quote Quick reply to this message
Old 08-14-2018, 06:36 PM   #18 (permalink)
Member # 7903
Do you mind showing a pic of the axle LCA and shock mount?
Sent from my SM-T710 using Tapatalk
Old 08-15-2018, 09:20 AM   #19 (permalink)
hurleygo3's Avatar
Member # 80862
My car has a LP in the front, and piggy back reservoir. This car has remote reservoirs.
I'll get some pics tonight.
Old 08-15-2018, 09:23 AM   #20 (permalink)
pcoplin's Avatar
Member # 17986
Yeah, meant LP, fat fingered that one. Thanks.
98 TJ LQ4/TH400
Old 08-15-2018, 09:25 AM   #21 (permalink)
hurleygo3's Avatar
Member # 80862
This car has a HP front and rear. No problem with a 2 piece shaft up front.
Old 08-20-2018, 02:07 PM   #22 (permalink)
hurleygo3's Avatar
Member # 80862
Almost a roller. The Goatbuilt fuel tank is a perfect fit.
Old 08-20-2018, 02:41 PM   #23 (permalink)
Member # 127171
Mike, Front or rear radiator?
sleepsontoilet is offline   Reply With Quote Quick reply to this message
Old 08-20-2018, 02:53 PM   #24 (permalink)
hurleygo3's Avatar
Member # 80862
Rear. Running the coolant in the frame rails.
Old 08-20-2018, 09:24 PM   #25 (permalink)
Kraqa's Avatar
Member # 24741
Send a message via AIM to Kraqa Send a message via MSN to Kraqa
sweet. its about time to see a fast moving build thread.
Keep the pics coming.
REDWOOD PLASTICS RACING
Toyo Tires Offroad Race Team | EMF Rod Ends | Mulitia Muffler | VancouverWaterjet.com | RCV Performance Shafts | Redwood Plastics & Rubber
Instagram & Twitter: @Kraqa
Kraqa is offline   Reply With Quote Quick reply to this message
