Compatibility - L92 VVT motor with Turbo 400 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-14-2018, 09:43 AM   #1 (permalink)
jeep09's Avatar
Member # 143697
L92
Compatibility
____________________
2017 Jimmys Buggy
12v Chase Truck
LS Jeep on Tons
Team 4485 Genright
jeep09 is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 09:58 AM   #2 (permalink)
Twankie's Avatar
Member # 230823
Compare the trans settings with a similar equipped car with a manual transmission.
Twankie is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 10:02 AM   #3 (permalink)
TrailTamer XJ's Avatar
Member # 140878
My first few thoughts; do you have the VSS hooked up? What ECM you’re running? Accordingly to PSI Conversion you’re suppose to be running a E38 ECM.
Edit: unlikely but; have you or your tuner confirmed that your pedal is working correctly? (0-100%, or it stops at 53%?)
TrailTamer XJ is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 10:16 AM   #4 (permalink)
GiS
GiS's Avatar
Member # 31285
I think something simple is being overlooked, or you and your tuner are heading down the wrong path?
Can you confirm you are running the E38 ECM? Also, what pedal are you using, what application did it come from?
Did you keep the factory 87mm Throttle Body?
Rock Posse Racing #686
Driver: Joey Weber
GiS is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 10:23 AM   #5 (permalink)
Member # 7903
Do the ECM, the OS you are using, the throttle body, and pedal all match?
Sent from my SM-G950U using Tapatalk
JohnnyJ is offline   Reply With Quote Quick reply to this message
Old 11-14-2018, 04:54 PM   #6 (permalink)
jeep09's Avatar
Member # 143697
E38 ECM - correct for L92
Factory pedal (new) - 2007 Escalade
Factory throttle body
2017 Jimmys Buggy
12v Chase Truck
LS Jeep on Tons
Team 4485 Genright
Old 11-14-2018, 04:56 PM   #7 (permalink)
jeep09's Avatar
Member # 143697
This is the rub, no VVT manual cars were made. I am missing the signal or "tune mod" from the 6L80
2017 Jimmys Buggy
12v Chase Truck
LS Jeep on Tons
Team 4485 Genright
Old 11-14-2018, 07:08 PM   #8 (permalink)
Member # 7903
Just to be clear since I've seen people get burned.. a 2007 truck throttle body; not one from a Vette?
Old 11-15-2018, 06:37 AM   #9 (permalink)
jeep09's Avatar
Member # 143697
yes, its a truck TB
2017 Jimmys Buggy
12v Chase Truck
LS Jeep on Tons
Team 4485 Genright
Old 11-15-2018, 06:45 AM   #10 (permalink)
Member # 161937
I agree something is getting overlooked. Your tune should even deal with torque management. I would have to look at my tune and cross reference OS numbers. I have a l92 that use to be paired to a 6l80 and then switched to 4l80. I believe the tune needs to be built off a base file such as a corvette with a manual trans.
5.3 TJ linked on ROCKS, ORI's, and 47's ***sold***
U4 buggy
Thanks to:
PCI Radios
BTR Wheels
BF Goodrich
jrad12381 is offline   Reply With Quote Quick reply to this message
Old 11-15-2018, 06:57 AM   #11 (permalink)
jeep09's Avatar
Member # 143697
That was reviewed with my tuner, Corvettes didn't come with VVT is apparently the issue
2017 Jimmys Buggy
12v Chase Truck
LS Jeep on Tons
Team 4485 Genright
Old 11-15-2018, 07:39 AM   #12 (permalink)
Member # 140878
I think the most logic next step is to contact PSI Conversion’s tech support. I’d imagine they have an answer because they sold you a harness specifically for either manual or non-computerized transmissions.
Old 11-15-2018, 08:05 AM   #13 (permalink)
Member # 97574
What is pcm out of and what base tune?
I run a built L92 out of an 07 escalade with a th350 behind it with no issues. Either wrong base file or the tuner is missing something.
https://www.facebook.com/groups/OFFROADCNCFILESHARING/
ROXROES is offline   Reply With Quote Quick reply to this message
