np231 doubler - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-14-2004, 11:05 PM   #1 (permalink)
Member # 21888
np231 doubler
Its booty fab at its best but someone somewhere may find it useful, I posted it like ayear ago but busted mine on a nice pointy rock and had to start over, so here it is with pics and better detail.
homegrown np 231 doubler how to:
This is what the finished product will look like....kinda.
I used a 207 front case (freebie) this time around, after destroying my original set-up (231-231) on a nice gooner rock, I was just to lazy to pick up the free 231 my bud jay was giving me. So either a 207 or 231 can be used to do this. The second (rear) case however must be a GM 207 or 231 because it has the 27 spline input that matches both the jeep and chevy output.
Now I wont get into how to take the damn things apart (if you cant figure that out you shouldnt be attempting this mod) but you start this project by gutting the front case, leaving ony the shifting mechanism and planetary gears. This here pic is what come out or off of my front np207....except for that c-bushing that snuck into the picture when I wasnt looking
You also must cut the front drive output off the front case in order to clear the front drive shaft. I cut mine off a lil past the oil fill plug, so your left with a gutted and cut case that will look like something like this:
Well, its time to figure out how the hell were gonna get the slippery stuff to stay in this booty fabbed psycho butchered thing. We must block off the big hole we left in the side of the case, I used a piece of aluminum to do the job. I cut it somewhat shaped like the hole in the case, leaving little tabs that will be bent and used to anchor it to the case with a few self tapping screws, hopes are high that a generous amount of smooge will keep the slippery liquid inside. This ugly mess is what we got so far:
Surely a better job could have been done here but unless she's a bleeder, I myself am happy with that twisted tortured chunk of metal. Next in line is starting to put the front case back together. You will only need to put the shaft back in and the first tailshaft chunk of housing back on (like in pic below). The rear most chunk of the t-case housing can live a better life by being recycled into a beer can. So please recycle, it does more than just help the environment. Now...where were we? Oh Lets put these bitches together, leaving the future beer can off the case you may now have to cut a chunk of the tailshaft off, I had to remove 1 1/8" from my shaft. Depending on your adapter you may need more off or less (*see below for how to determine amont that will need cut off*). You should now have a chunk of scrap that looks something like this
I used an original GM tranny-tcase adapter to mate these things together. This piece (dont know no part# or what all they came on) will bolt directly to the rear case, it looks like this...kinda
Once bolted on the rear case slide the two cases together. This is how you will know how much of the shaft you must cut off the front case (this is the shit I was talkin about up above). Once all cut and slid together its as simple as getting the things welded together, just decide how you want the rear clocked. I have mine up a lil for better clearance but you will likely need a small body lift, i have 1.5". The cases will still come apart, the adapter will unbolt from the rear case and they will slide right apart but adapter becomes a part of the front case. It in no way interferes with disassembly of the front case should you ever need to take the thing apart.
IMPORTANT TO NOTE
1) The compound low WILL destroy motor mounts almost immediately, solid mounts or even a ghetto chained motor is an absolute necessity.
2) You will need two crossmembers, I also recommend adapting a brace from the front case to the rear portion of the rear case. GM used a brace that went from the tranny to t-case on a bunch of vehicles, this can be adapted easily.
3) The cases will shorten the rear driveshaft and lengthen the front by about 15"...give or take, so it is not ment for your wrangler...
4) This doubler will give you a low-low of
np231 to np231= 7.4:1
np207 to np231= 7.1:1
np207 to np207= 6.8:1
slap a 4:1 in one of the puppys and it gets crazy low. This is not a simple mod but it aint a real hard one either. The effort is well worth it, your chevy or heep vehicle will crawl with the best of em, and if you find a case cheap (or free like i did) you wont break the bank to do it.
psychobilly is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 12:43 AM   #2 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
Ghetto But you get an A+ for originality
desertCJ is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 07:17 AM   #3 (permalink)
rockmup's Avatar
Member # 16699
You are a crack head. Weld that plate on and you wont have any leaks at all.
But good job.
rockmup is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 08:57 AM   #4 (permalink)
moveaside's Avatar
Member # 11983
Yet another reason to learn how to weld on aluminum and to ask yourself
Got wheelbase?
My crappy build
moveaside is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 10:38 AM   #5 (permalink)
MossMan's Avatar
Member # 11995
Send a message via MSN to MossMan Send a message via Yahoo to MossMan
1) I think you should make something even longer. Less drive shaft is a good thing right? edit: just realized the front shaft will be super long
2) All that and not even a SYE
3) Take all that time, energy, and ability and do something that makes sense
MossMan is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 11:02 AM   #6 (permalink)
B.A.R.K's Avatar
Member # 8540
You couldn’t pay me to run that setup in my rig....
....but I would place a bet on how long it will take to grenade!
92YJ/2.5L/HD4:1D300/F&R D44/5:38/36 SX/99"WB
Nothing is stronger than stupid...
B.A.R.K is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 11:16 AM   #7 (permalink)
Member # 21888
last one made it over a year, then a lil rock took her out or it would still be going
Old 07-15-2004, 11:44 AM   #8 (permalink)
Jamus2's Avatar
Member # 12943
Send a message via AIM to Jamus2 Send a message via Yahoo to Jamus2
If you got the wheelbase, might as well use it. Not everyone runs Jeeps and Zukis.
[QUOTE=papee]This game IS real life for us web wheelers.:flipoff2: [/QUOTE]
Jamus2 is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 12:14 PM   #9 (permalink)
TexasBlake's Avatar
Member # 9722
Cool. If the suit fits, wear it.
I thought about doing somthing similar when I was with 35s, but I'm just going to do an entire driveline swap now.
TexasBlake is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 03:32 PM   #10 (permalink)
Member # 26206
Ya ..I agree ..it's total ghetto but shit if you got the wheelbase and what about $150 for everything ?...Sounds good for a budget truck to me .Add a cut and tap SYE and you have a pretty good set-up for like $200-$300.I wouldn't feed it v8 power but a 6cyl and lots of axle gear ...should last long enough to more than pay for itself.
Terranaut is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 05:30 PM   #11 (permalink)
Member # 27312
Send a message via ICQ to Amund Send a message via MSN to Amund
Cool! I never threw the old 207 away, knowing I could always use it for something interesting GM NP231, is that like in S10's?
my buggy: https://pirate4x4.com/forum/showthread.php?p=8498152#post8498152
Amund is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 05:38 PM   #12 (permalink)
Member # 26206
Yes!
Old 07-15-2004, 06:22 PM   #13 (permalink)
TexasBlake's Avatar
Member # 9722
Yes same transfercase. A majority (if not all) of the NP231Cs have a wider chain.
Old 07-15-2004, 06:41 PM   #14 (permalink)
Member # 28661
Send a message via AIM to 4xFreak Send a message via Yahoo to 4xFreak
Couldnt any GM th350 or 700r4 t-case be used for the rear case?
Zach
Gentlemen, start your livers.
75 IH Scout II, future street queen
79 Chevy K10, backup wheeler
80 GMC K25, undecided
97 Chevy S10, the crawler
05 Dodge 3500, the tow rig
4xFreak is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 07:16 PM   #15 (permalink)
Member # 15778
Ignore the haters that is way cool. Getto but still a cool idea. I'm confused on what you used to bolt them together with, what adapter?
flat black hoo-ride
roctoy is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 08:06 PM   #16 (permalink)
Member # 21888
I've actually run some variation of this for some time now (like 4 years or so) one with a 208 and 231 and then 231-231 and now the 207-231. Strength of the internals or shaft was never an issue, remember gm cases are 27 spline. The 208-231 got busted up when my motor mounts tore apart, split the housings into pieces cuz the cases were mounted kinda solid (1/2" of rubber on each side with bolt through the mount) then the 231-231 doubler got busted up real good by some rocks. I didnt have a skid cuz I was lazy and the cases tucked up inside the frame rails, didnt think I would really need it...oops. As for the shaft lengths, I run an s10, hp 44 front moved 4 iniches to the front and I still have a shorter shaft than a YJ. The rear shaft is like 30-35 or so inches long. This set up is the cats ass in an s10 but may work in a cherokee or any buggy running a 4.3. The adapter was off some gm 4wd tranny, its just the stock gm adapter that goes from the tranny-t-case on some GM's. I dont know what all had them, I know my s10 didnt, this one was on a tranny just sitting in a junkyard, I just looked to see it was the right bolt pattern and pulled it, didnt ID the tranny it was on.
wish I had a good pic of the drive shaft clearance but I dont, this is the best I can do now....its a linky cuz its a larger file
http://img28.photobucket.com/albums/...4/P5290048.jpg
Old 07-15-2004, 08:07 PM   #17 (permalink)
Member # 26206
take that pic to your local wrecking yard and someone there will know what it is.
Old 07-15-2004, 08:47 PM   #18 (permalink)
Jamus2's Avatar
Member # 12943
The adapter you used looks just like the ones I have, which is any s-series automatic(4bolt) to the s-series t-case(5bolt). Be aware that in, 96 I think, the s-series went to a 6-bolt t-case wich is the same as Jeep uses. The input is still 27 spline though. If you know about where GM used things, such as the 700-208, you can make many different combos using this idea. I'm working on a 207-233 setup in my blazer but I bolted the adapter where billy welded. I can't weld aluminum good enough, and I figure grade 8 bolts and 3/8" plate is strong enough.
Old 07-15-2004, 10:01 PM   #19 (permalink)
Member # 10736
excellent. could you use a gm 27 spline 205?
masonmachines is offline   Reply With Quote Quick reply to this message
Old 07-15-2004, 10:40 PM   #20 (permalink)
Member # 21888
Excellent info Jamus! I didnt know the s10 went to a 6 bolt t-case?? I thought my adapter was a 700r4 but I wasnt sure enough to post it up, my nv3500 doesnt have that piece.
I dont see why somthing like this couldnt be done with the 205, but then again I never messed with one of them, someone try it.
Old 07-16-2004, 07:47 AM   #21 (permalink)
Jamus2's Avatar
Member # 12943
Yeah, I figured if this twin case setup didn't work out, I'd get one of those Jeep 231 4:1 deals that replace the front half of the case. Then swap in my Cheby 27 spline input. But I had the extra 207 laying around, so like $20 invested compared to around $1,000. Think I'll try this first, haha. On a side note, anybody know id a 208 is 27 spline output too? Ir is it 32 spline, my 233 is 32 spline output.
Old 07-16-2004, 03:22 PM   #22 (permalink)
Member # 17313
cool Idea unit!
I've been looking at doing the same setup with a 13-56 and a 208.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion.
Jrod-13 is offline   Reply With Quote Quick reply to this message
Old 07-16-2004, 05:09 PM   #23 (permalink)
Member # 15778
What options do you have as far as shifting, same as a marlin?
flat black hoo-ride
Old 07-16-2004, 05:32 PM   #24 (permalink)
TNScrambler's Avatar
Member # 10818
Send a message via AIM to TNScrambler
Anyone know if a GM 208 has the same 27 spline input?
Justin
random parts stashed in various locations that might someday become part of a Jeep ;)
TNScrambler is offline   Reply With Quote Quick reply to this message
Old 07-16-2004, 08:33 PM   #25 (permalink)
Jamus2's Avatar
Member # 12943
If the 208 came behind a 700R4 it would have to have 27 spline input correct? I don't know about std tranny but I see no reason for it to differ.
