OK, what's this secret squirrel sauce from Fox - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-06-2019, 05:59 AM   #1 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
The KOH announcers have been alluding to some new tech from Fox that is allowing Shererrerrr to go 20-24mph faster.
Spool valves?
Mag shocks?
I get adds for ghey cruises.....
Anyone else????
Roc Doc is offline   Reply With Quote Quick reply to this message
Old 02-06-2019, 06:52 AM   #2 (permalink)
Shift to the Best
R.DesJardin's Avatar
Member # 68266
Spool valves?
Mag shocks?
Hello, it's a secret. I heard them say it many times. I bet after the dust settles the details will start to leak out. (No pun intended). Orrr..... it's propaganda to psyche the other guys out.
Shift controllers and shifters, AMS mounts
Toyota Triple & Twin Sticks
John 3:16- He is the answer.
R.DesJardin is offline   Reply With Quote Quick reply to this message
Old 02-06-2019, 06:55 AM   #3 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
Well I asked about it on the Poly Performance FB page and they said to PM them for the low-down, so it can't be that secret.
Anyone else????
Old 02-06-2019, 07:16 AM   #4 (permalink)
Bunk's Avatar
Member # 41059
Send a message via Yahoo to Bunk
Mental warfare
Bunk is offline   Reply With Quote Quick reply to this message
Old 02-06-2019, 07:24 AM   #5 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
The whole claim of 20-24mph faster made me laugh.
Anyone else????
Old 02-06-2019, 07:34 AM   #6 (permalink)
Member # 3007
25mph and shit went off the rails
Bones is online now   Reply With Quote Quick reply to this message
Old 02-06-2019, 07:36 AM   #7 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
yeah, don't want to sound preposterous.
Anyone else????
Old 02-06-2019, 01:06 PM   #8 (permalink)
Member # 848417
Killersoundz is offline   Reply With Quote Quick reply to this message
Old 02-06-2019, 01:17 PM   #9 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
I presume it’s their electronically controlled shocks that compensate for inertia, steering angle, etc. I guess fox makes it for the new raptors also. They have a couple of jeeps running around with it and a couple old raptors.
& Blaine
:tank:
Beat95YJ is online now   Reply With Quote Quick reply to this message
Old 02-06-2019, 01:33 PM   #10 (permalink)
welndmn's Avatar
Member # 398
They swapped out the Fox oil and are running sperm whale oil.
Mark
Old 02-06-2019, 01:42 PM   #11 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
servo controlled valving?
Anyone else????
Old 02-06-2019, 01:43 PM   #12 (permalink)
Change is good.
Roc Doc's Avatar
Member # 20631
Just glad they didn't go cheap with coyote oil.
Anyone else????
Old 02-06-2019, 01:53 PM   #13 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Yes. They have had it on sxs for a while. They also have a JL kit.
& Blaine
:tank:
Old 02-06-2019, 03:33 PM   #14 (permalink)
Member # 24859
Don't matter, if it aint on the 321 it is not gonna win.
Mellonhead
peesalot is offline   Reply With Quote Quick reply to this message
Old 02-10-2019, 10:01 PM   #15 (permalink)
Member # 853678
nobrakes is offline   Reply With Quote Quick reply to this message
Old 02-11-2019, 07:44 AM   #16 (permalink)
Clifcattankass's Avatar
Member # 40472
https://www.ridefox.com/content.php?c=livevalve-bike
I don't know if they have adopted this to motorsports shocks, but could be.
Clifcattankass is offline   Reply With Quote Quick reply to this message
Old 02-11-2019, 12:20 PM   #17 (permalink)
Member # 73037
There's no question I'm buying this as soon as it trickles down to Ultra distance style race mtb bikes (shorter travel ~130 front/100-120 rear). This past year I used the Quarq shock wiz to analyze and tune the shocks on my current mtb race bike it made a huge difference. Mount it to the pressure valve, ride the bike, review the results and suggestions, modify, repeat. In 2 sessions I had it riding great. The Fox system takes this up a whole nother level though and the reviews so far have been great.
I spent many time consuming hours of try and test re-valving of the Bilstein 7100s on my previous truck and Radflos on my current. In the end I got them where they were performing great, but at least having electronic data logging would make it so much quicker to dial in. I know this is in use in motorsports generally but it doesn't seem to have trickled down yet.
cruiser_moby is offline   Reply With Quote Quick reply to this message
Old 02-11-2019, 01:06 PM   #18 (permalink)
Weasel's Avatar
Member # 5639
THat doesn't sounds like a quick swap into a U4 car though, having to be powered, etc?
Kindness doesn't condemn or condone
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
Old 02-11-2019, 01:58 PM   #19 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
I presume it would be designed in. Retrofitting might be a pain.
& Blaine
:tank:
Old 02-11-2019, 03:22 PM   #20 (permalink)
Member # 13787
Send a message via AIM to zcarczar
You can see the bypass tubes on Jason's car in a few of the pictures. It doesn't look like servo activated bypasses.
Unless they did something with the coil-over? I'm not familiar with the system they run on the Raptor or RZR's.
zcarczar is offline   Reply With Quote Quick reply to this message
Old 02-20-2019, 04:43 PM   #21 (permalink)
Mac5005's Avatar
Member # 92932
I asked Jason what changes fox made.
He said larger bypass tubes and a nitrogen valve instead of the spring in the tube. Says it holds the car up longer and takes the hit smoother.
Need someone smarter to decode the “nitrogen valve” part. Haha
From the pics I have and I was looking for the servos, it didn’t have servos on any bypass tube or c/o resi.
Mac5005 is offline   Reply With Quote Quick reply to this message
Old 02-20-2019, 04:55 PM   #22 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
interesting ...
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote Quick reply to this message
Old 02-20-2019, 05:42 PM   #23 (permalink)
Member # 14196
Send a message via AIM to wes8517 Send a message via MSN to wes8517 Send a message via Yahoo to wes8517
I know I questioned the single 3" IBP coilover on the front of Jordan Pelligrinos new car and they said it was getting the re-circulating resi's like their Gen2 Raptor shocks to help ensure they didnt get shock fade. I dont know if they had any shock fade issues, but with a front engine car, with a 3" IBP that has the fluid volume of a standard 2.5" shock I was doubting it for sure especially for the first lap of desert section.
Wes
Nothing worth noting here
wes8517 is offline   Reply With Quote Quick reply to this message
Old 02-20-2019, 08:11 PM   #24 (permalink)
El Conquistador
Valley Rock's Avatar
Member # 208306
QUOTE: a nitrogen valve instead of the spring in the tube. Says it holds the car up longer and takes the hit smoother.
So #76 is running 90/10's ?
If that "Nitrogen valve" can hold the car up and still take the whoops, basically making the car float, that is one hell of a calculating valve, I would think computer controlled or will be in the near future, because that is key for speed in the desert, probably made out of Plutonium or unobtainium .
Valley Rock is offline   Reply With Quote Quick reply to this message
Old 02-20-2019, 11:14 PM   #25 (permalink)
ZAG
ZAG's Avatar
Member # 14113
so they replaced bybass valve spring with nitrogen spring.
gets un linear spring curve in to valve
ZAG is offline   Reply With Quote Quick reply to this message
Similar Threads
***** FOX COILOVER OVERSTOCK SALE ***** ALL SHOCKS VALVED FOR YOUR RIDE ***** TRD Suspension 5 03-30-2016 08:53 AM
Fallon Fox Comes Out as Trans Pro MMA Fighter JParuBob General Chit-Chat 149 03-10-2013 06:33 AM
Obama signs law giving himself, Bush lifetime Secret Service guard BEAR General Chit-Chat 56 01-10-2013 10:49 PM
Fox 11" 2.5 Smooth Body Remote Res & Fox 11.5" 2.0 Coil-Overs blacked outg Misc. Stuff For Sale 8 01-16-2012 09:58 PM
