1994 K2500 4X4 SBC 400 Build - Advice! - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-26-2019, 02:58 AM   #26 (permalink)
b454rat's Avatar
Member # 16536
Those are Vortec heads.
Web wheeler
b454rat is offline   Reply With Quote Quick reply to this message
Old 03-09-2019, 09:51 AM   #27 (permalink)
Member # 863542
GRRR - Stupid Oil Leaks!
Not that many miles on it and it looks like it's been slinging oil for years!!
Oh well, that's part of the reason I took it out I guess.
Chevy94K2500 is offline   Reply With Quote Quick reply to this message
Old 03-09-2019, 02:07 PM   #28 (permalink)
Member # 863542
just to add!
Obviously the rear main was leaking!
Valve train look good
intake and runners look ok
Spark Plugs look ok
1357 Left to right
2468 Left to right
Little carbon
Next to dig into!
Old 04-12-2019, 12:48 PM   #29 (permalink)
Member # 863542
little update
Been busy at work, but I have managed to tear everything down, installed new seals, got the correct oilpan gasket, went with the 038 head gasket, MSD-8361 on it's way. Should have the float kit & air cleaner for the holley 4150 carb I will be installing.
Ended up swapping the cam out for a Lunati, little more lift not much, also did the comp cams coil spring & keeper upgrade. Spoke with lunati about the cam and is what they suggested. Dialed it in, that was fun.
This time, will be running it and tuning it on the run stand I built out of 4X4's and some angle iron. Will post pics later.
Old 04-15-2019, 05:23 PM   #30 (permalink)
Member # 863542
Some updated pics
The heads are done, Comp Cams LS Springs, and keepers:
Mocking the run stand up to bolt up the engine
All bolted up!
I hope to have fixed the oil pan leak
Rebuilt the Holley, that was fun, a lot of parts.
My new air cleaner, real happy with this!
And I took some advice, this came in today!
Will get to work on the rest of the assembly tomorrow hopefully...have to wire up the run stand, add the radiator, and a few minor other things tach..etc
Similar Threads
SBC gurus, advice needed. Byro Chevy 16 12-04-2018 10:46 AM
Ultimate Wrangler Build Ups and Swaps thread gtxracer Jeep - Hardcore Tech 364 09-28-2017 04:54 AM
*FAQ* PBB ZUK BUILD table of contents--HELP BUILD! supazuk94 Suzuki 7 09-09-2017 09:21 PM
Project Build ups: dog walker Toyota - Land Cruiser 87 02-14-2017 06:09 AM
PBB Tow Rig/Trailer Build Threads Ken Carter / BRUISER Tow Rigs and Trailers 1 02-04-2010 09:08 AM
