CutlerFab Shop Thread - Page 7 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-30-2019, 06:27 PM   #151 (permalink)
Member # 502649
Killer as always, itís gonna take me a lot longer with tin work to make panels that nice! Do you buy card board or just old boxes? Iíve found that the card board makes the biggest difference in quality of templates.
Twmdodge99 is offline   Reply With Quote Quick reply to this message
Old 07-30-2019, 06:45 PM   #152 (permalink)
mcutler1's Avatar
Member # 167368
I buy picture framing backer from hobby lobby or Michaels. 33x40 I think, about $4 a sheet. Brakes nice, rigid enough, strong enough to drill and use clecos (carefully), and near the same thickness as 063 alum. I use a razor and ruler for straight sides, and long, straight tin snips for curves.
Agreed, closer the template material is to the material your working with the better. I haven't used regular old packaging cardboard in years.
Stock Car Steel, where I buy tubing, sells template material, but I've never used or seen it.
Sent from my SM-G892A using Tapatalk
90's throw back manche build
Last buggy Build thread;
LS2, th350, atlas 3.0, spidertrax 9's, 39's.
Instagram: CutlerFab
mcutler1 is offline   Reply With Quote Quick reply to this message
Old 08-04-2019, 05:48 PM   #153 (permalink)
mcutler1's Avatar
Member # 167368
Long week manipulating metal...
CutlerFab
Old 08-04-2019, 08:35 PM   #154 (permalink)
Member # 181868
Good tech there! That's really what I need to do. I've been using big sheets of cardboard I get between the aluminum when I order it. It's not that great.
Looking at weekend work, I need to play with my bead roller more.
Thanks for sharing.
Project : Amphibious HEMTT
Old 08-04-2019, 08:57 PM   #155 (permalink)
Member # 37016
Check out ram board at home depot or the like. Works awesome for templates been using it for years.
65Chevy4x4 is offline   Reply With Quote Quick reply to this message
Old 08-04-2019, 09:07 PM   #156 (permalink)
Member # 37016
Double post
Old 08-05-2019, 05:28 AM   #157 (permalink)
mcutler1's Avatar
Member # 167368
I've used it when I run out of the other. Maybe I've had the wrong thing, but it came on a roll and was a bit more difficult to keep flat. Much thinner than the aluminum. I do use it when I'm replicating a curve, it folds on the shrink areas really nice.
Old 08-05-2019, 07:35 AM   #158 (permalink)
Member # 37016
Yes it's on a roll. Trick is cut it into 3 or 4 ft long pieces before you need it. I usually cut 4 or 5 big pieces off roll and lay it flat under my workbenches on ground. After a day it's nice and flat. Easy to use.
Old 08-08-2019, 01:58 PM   #159 (permalink)
94toytruck's Avatar
Member # 18614
Damn dude, your work always makes me feel like a hack!
Eric
94toytruck is offline   Reply With Quote Quick reply to this message
Old 09-11-2019, 04:34 PM   #160 (permalink)
mcutler1's Avatar
Member # 167368
Boy, I have neglected my shop thread the past month...
Progress on winget buggy.
Old 09-11-2019, 04:35 PM   #161 (permalink)
mcutler1's Avatar
Member # 167368
CutlerFab
Old 09-11-2019, 06:03 PM   #162 (permalink)
giles45shop's Avatar
Member # 197896
Awesome work as usual. Your tin work always makes me want to head out to the shop and play with my bead roller some more. What did you use to secure the triangular vent on the front inner fender? I couldn't blow up the image enough to tell? I like using stainless steel button heads, but always looking for new ideas. I've benn thinking about getting the stuff to do some actual rivets for something different.
giles45shop is offline   Reply With Quote Quick reply to this message
Old 09-11-2019, 06:07 PM   #163 (permalink)
mcutler1's Avatar
Member # 167368
Thanks!
1/8 alum solid rivets
And I thoroughly enjoy doing them.
Old 09-11-2019, 06:56 PM   #164 (permalink)
Member # 181868
Thanks!
Great work as always.
Where did you get that hexagon metal?
Old 09-11-2019, 07:16 PM   #165 (permalink)
Member # 806345
Awesome work.
How much travel will this buggy be getting in the rear end with the shorter coilovers and trailing arms?
Sent from my iPhone using Tapatalk Pro
PintoBeans is offline   Reply With Quote Quick reply to this message
Old 09-11-2019, 08:01 PM   #166 (permalink)
Member # 502649
God it looks so good what do you sand the panels with?
Old 09-11-2019, 09:01 PM   #167 (permalink)
mcutler1's Avatar
Member # 167368
Thank you!
I cut that on the plasma table, hence the pattern being stopped on the triangle sides. I also bead rolled a flange to raise the honeycomb flush with the cutout.
Originally Posted by PintoBeans View Post
Awesome work.
I haven't cycled the suspension yet, chassis came to me as a roller from M & M fab, Pj knows what he's doing!
I'll cycle it soon, before I build the actual trailling arms, just to double check clearances. But it should net 20"~ wheel travel in the rear, easily.
3-400 grit wet/ dry paper. If it's all scratched up, I use a grinding wheel of solid red scotchbrite. Then I final the grain with red scotchbrite by hand.
Thanks guys!
CutlerFab
Old 09-12-2019, 04:43 PM   #168 (permalink)
mcutler1's Avatar
Member # 167368
Forgot to mention,
Solid rivets are super cheap, pennies on the dollar versus nice button or panhead fasteners and nut certs. A little more labor to do them right, but the results are worth it.
Obviously provided the panel is to remain fixed.
And I'm using Eastwood cheapo rivet set and backer bar.
Old 09-12-2019, 08:43 PM   #169 (permalink)
Member # 197896
Forgot to mention,
Thanks for the extra details, I was going to ask about that as I was starting to do some research into what was needed to start playing. Time to order some more tools
Old 09-12-2019, 09:46 PM   #170 (permalink)
mcutler1's Avatar
Member # 167368
No problem. After I did my first panel or two, I did spend a little more on layout tools- rivet fan, counter sinks, auto center punch, rivet cutter- so you can order 1/2 length and cut to cover nearly any thickness you may fasten.
This stuff certainly isn't needed for the do it yourself, but to be more efficient for profit.
Good places to start: and get ready if your a tool freak to be overwhelmed...
www.rivetsinstock.com
www.aircraft-tool.com
www.hansonrivet.com
And of course mcmaster-carr
Old 09-13-2019, 05:21 PM   #171 (permalink)
Newbie
AccuTune Offroad's Avatar
Member # 863148
Love it, thanks for the updates!
AccuTune Off-Road
Specializing in Tuning High Performance Suspension.
(424) 377-0808 |
*FREE* Custom tuning on purchased shocks. Fox Shocks, King Shocks & more!
AccuTune Offroad is offline   Reply With Quote Quick reply to this message
Old 09-13-2019, 08:40 PM   #172 (permalink)
mcutler1's Avatar
Member # 167368
Thanks Ryan!
Old 11-25-2019, 04:18 PM   #173 (permalink)
mcutler1's Avatar
Member # 167368
Man I've fallen behind..
Mo work
Old 11-25-2019, 04:20 PM   #174 (permalink)
mcutler1's Avatar
Member # 167368
Custom parts require custom homemade tools. Having #cncplasma for a year now has really expanded my thinking and love of fixturing to easier build more accurate and distinctive parts. I recently built this kick ass I- beam axle housing fixture along with fixtures for the @weldtables . And rather than having this large apparatus take up space when not in need, I decided it could double as a rotisserie for building trailing arms. I came up with this so I may simultaneously build and weld both arms at the same time with the cooling time between welds being shared. Not to mention spun around for the most comfortable welding position.
Trailing arms incoming..
Old 11-25-2019, 04:22 PM   #175 (permalink)
mcutler1's Avatar
Member # 167368
So much to catch up with... tail gear rock assault 9's going under Watford buggy.
Similar Threads
The Shop Security Thread Muckin_Slusher Shop and Tools 15 06-30-2017 07:22 AM
Gun Shop Bad for Arlington, VA emiller22207 General Chit-Chat 19 05-26-2015 07:49 PM
4x4 Store job posting in Carolina Beach, NC Pietro USA - Southeast 1 03-26-2015 11:35 AM
My shop thread... necronomikon Shop and Tools 12 04-11-2013 12:10 PM
Can't cut and paste text from posts ev13wt General Chit-Chat 14 04-08-2013 11:09 PM
