T-case strength - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2019, 12:41 PM   #51 (permalink)
E. Spengler
Subybaja's Avatar
Member # 206384
Originally Posted by R.DesJardin View Post
What if someone made a killer aluminum housing design with a 271 style chain drive internals? Atlas? TWF? I bet the front output bearing housings could be built eccentric to allow chain tightening.
Milemarker used to make a ChainSaver kit for the 203 that did that.
We had part of a slinky. But I straightened it.
Subybaja is offline   Reply With Quote Quick reply to this message
Old 03-30-2019, 03:07 PM   #52 (permalink)
Member # 181868
Originally Posted by gt1guy View Post
No, that would break things. Front and rear tires would be trying to spin at different speeds.
Twin stick will allow you to have 2wd at either end. Front engaged/rear in neutral would be front wheel drive.
I see. I have heard of mud trucks having differnt ratios in the diffs. They have the front turn faster so they have better steering. I don't know how much differnt speeds they would run. I would assume they can't run in four wheel drive except in the slop for breakage reasons.
I can think of some very limited reasons to have front wheel drive only. But I can hardly say that's a major advantage. I could be wrong.
Project : Amphibious HEMTT
Old 03-30-2019, 03:55 PM   #53 (permalink)
Elwenil's Avatar
Member # 41063
It's a big advantage for a crawler in tight quarters or when you just need the front to shift over a bit. It's called a front dig and can be used to reposition the front by spinning the front wheels while the rear stays stationary.
1988 Dodge AW450 Ramcharger-318TBI-NP435-NP205-D60s
Odin Owns Ye All
Elwenil is offline   Reply With Quote Quick reply to this message
Old 03-30-2019, 04:11 PM   #54 (permalink)
YotaAtieToo's Avatar
Member # 25632
8 year member on world's largest rock crawling site, doesn't know even the most basic rock crawling fundamentals
Old 03-30-2019, 04:45 PM   #55 (permalink)
Member # 53528
do they even have any rocks in florida?
Old 03-30-2019, 05:39 PM   #56 (permalink)
don't know nothin'
ridenby's Avatar
Member # 136902
They import them.
ridenby is offline   Reply With Quote Quick reply to this message
Old 03-30-2019, 06:53 PM   #57 (permalink)
Member # 181868
Originally Posted by YotaAtieToo View Post
8 year member on world's largest rock crawling site, doesn't know even the most basic rock crawling fundamentals :
I would not say that is "most basic rock crawling fundamentals". I would say that is an advanced rock crawling feature right along with cutting brakes and rear steer. Many (probably most) people rock crawl without any of those features. (Because they don't have them)
Anyways, I said I was ignorant of driving with the front in high range and the rear in low range. Not, front dig.
Old 03-30-2019, 07:48 PM   #58 (permalink)
Member # 214685
I liked the ability to drop down a big ledge. Front in rear out, lock up rear with cutter brakes. Creep over the edge with the front pulling and rear dragging, squats the rear and lets the front still pull.
Byro is offline   Reply With Quote Quick reply to this message
Old 03-30-2019, 08:33 PM   #59 (permalink)
Member # 111580
I would argue most rigs on anything bigger than 37s other than toyotas have and use front dig, I would agree its a basic fundamental. I use it ALL the time.
BUCK OFAMA
4 seater LS1 buggy
best vendor on pirate...
dragrcr65 is offline   Reply With Quote Quick reply to this message
Old 03-30-2019, 09:29 PM   #60 (permalink)
Member # 177092
I agree 100%. I am not sure how front dig could be considered a "fundamental."
I guess I didn't get the memo; I have a two rigs with 37"+ tires. I wheel with several guys on tons and 40"+ tires and none of them have front digs either. In fact, I don't think I have ever seen someone perform a front dig in person.
I am not saying it is not a useful feature, or that no one is running rigs capable of performing front digs, but I would say it is a far cry from a "fundamental." As a matter of fact, I have seen more rigs with rear steer than I have seen performing digs.
'84 Bronco II is offline   Reply With Quote Quick reply to this message
Old 03-30-2019, 10:30 PM   #61 (permalink)
Member # 25632
Relax, I was just giving you shit, hence the
Where are you located? I'm guessing not on the west coast. I didn't say it was a fundamental of wheelin. I was talking about rock crawling.
Not saying that people don't rock crawl outside of the west coast, but for the most part technical rock crawling is on the west coast.
Old 03-30-2019, 11:07 PM   #62 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Front digs are very common on the west coast. If you aren’t with Toyota guys you see them all the damn time.
& Blaine
:tank:
Old 03-31-2019, 10:09 AM   #63 (permalink)
Member # 177092
Not on the coast, but in the southwest
I am in New Mexico and be assured, we have some of the hardest, rockiest, and technical trails of the west. I don't really wheel with the buggy guys, so they are probably a different story, but I can't specifically remember seeing anyone using a front dig on the trail.
New Mexico is one of the poorest states though, and it seems for the most part, the rigs us locals are running are a lot lower buck than what you see in Colorado, Utah, Arizona, and California. Leaf springs and regular coil springs are a very common sight on extreme trails around here as are swampers and junkyard tons.
Edit: The Farmington guys are probably an exception since they've got all that oil money and comp crawling is pretty big up there.
Old 03-31-2019, 10:30 AM   #64 (permalink)
Member # 214670
People use front digs anywhere. Itís a great test of front driveline strength. Iím not sure I would be thrashing a front dig on anything less than a 60 ring gear and 205/atlas.
Keydet15 is offline   Reply With Quote Quick reply to this message
Old 03-31-2019, 10:36 AM   #65 (permalink)
Member # 25632
I wasn't trying to start a big debate, just giving the guy from floriduh a hard time.
Old 03-31-2019, 10:56 AM   #66 (permalink)
Member # 79509
Front dig is fundamental.
Anyone disagreeing has their head in the sand.
Black Sheep is online now   Reply With Quote Quick reply to this message
Old 03-31-2019, 11:09 AM   #67 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
I have seen many done with Dana 44ís and 37ís. Chromoly axles are a must. I have a friend who did them in an ifs Chevy with 37ís (ifs always broke)
People do them with 300ís/205ís/atlas/etc. if itís possible, people will do it.
& Blaine
:tank:
Old 03-31-2019, 11:17 AM   #68 (permalink)
lil,yota's Avatar
Member # 102395
Front digs are a pain in the ass
Because after you have a transfercase with them you won't ever want a transfercase that doesn't have em.
And you'll do what ever it takes to get em....No matter what it cost.
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 03-31-2019, 01:08 PM   #69 (permalink)
arse_sidewards's Avatar
Member # 256962
You can go a hell of a lot of places without doing a front dig.
Knowing what one is is probably more fundamental than actually having and using that capability.
Old 03-31-2019, 01:33 PM   #70 (permalink)
Member # 25632
My solution was a selectable rear locker. Not exactly the same. But can be just as effective if done properly.
Old 03-31-2019, 02:21 PM   #71 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
I've front digged plenty of Dana 30's. My old ZJ was even LP30 front. Had the 5.9 and 4.3 atlas. I did a dig in it several times. Even with 4.56's. It really has a lot more to do with being reasonable about the condition. I was alway up hill without a bound front end. I had a selectable rear locker too so typically using the parking brake worked better than a full dig would.
Action Fab is offline   Reply With Quote Quick reply to this message
Old 03-31-2019, 06:42 PM   #72 (permalink)
clb 017's Avatar
Member # 166307
Good hearted ribbing ALERT
Front digs are very common on the west coast. If you aren’t with Toyota guys you see them all the damn time.[/QUOTE]
cuz yota guys just drive thru that shit.
Wish I had the capability tho..
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is offline   Reply With Quote Quick reply to this message
Old 03-31-2019, 06:59 PM   #73 (permalink)
Member # 181868
Well actually I've done front digs a few times. Got stuck in muddy snow in Canada one time and had to get out and dig up front so I could lay some logs in front of the tires. I always carry a shovel for those occasions. So there!
Old 03-31-2019, 07:02 PM   #74 (permalink)
clb 017's Avatar
Member # 166307
Didn't Bobby Long do t case shaft testing along the line of the axle test?
Phawk photofukkit.
Old 04-02-2019, 09:36 PM   #75 (permalink)
Member # 111580
Front digs are very common on the west coast. If you arenít with Toyota guys you see them all the damn time.
Wish I had the capability tho..[/QUOTE]
come follow me and tell me you drive through it
BUCK OFAMA
4 seater LS1 buggy
Similar Threads
TMR CUSTOMS - Transfer Case Support Kit TMR Customs Motor/Tranny/T-Case Performance 343 01-18-2017 07:46 PM
New Revolution Gearing packages available now! SweetCJ7 Axles/Tires/Wheels 2 07-15-2016 12:11 PM
Chevrolet Tracker/Vitara/GV T-Case Low Gears RJ6 Suzuki 6 04-04-2016 03:08 AM
Another teenager student love story. With a twist. BassnTruck General Chit-Chat 193 05-25-2013 12:14 PM
