Bending 7075 links in tube bender - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-08-2019, 10:09 PM   #1 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Yes, its been done but I cant remember who did it
Looking for feedback on this and how it worked out for the bender. Any bent pins or failures? I can make new pins but making new arms would be a pain. I only need 10-15 degrees so I can clear the frame on my TJ. I could probably triangulate the lower links but Id have to redo the entire mounts and I like my geometry at the moment.
Looking to do 2 7075 lowers and uppers. Currently run 2x.250 wall Heretic fab lowers and 1.75x.120 uppers with JJs. I know of one 4500 car that runs these but they bought the car with them installed. I asked WOD to make the links and bend them but theyre scared to do the bends. I might ask again if they can bump up to 2.25 or larger and feel comfortable doing it. Anyone want to try some 2.25 or 2.5 diameter 7075 bends for me?
97 TJ Build:
2013 Raptor SuperCrew Tow Rig
Porsche
Fab Parts:
PNW Shock Tuning:
gtxracer is offline   Reply With Quote Quick reply to this message
Old 04-08-2019, 10:14 PM   #2 (permalink)
Member # 189239
Go get you a harbor freight pipe kinker and give it a whirl. Alot of guys been there .25+ wall links with them. Video it JIC.
YROC FAB. is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 05:50 AM   #3 (permalink)
Member # 10
X2 the HF kinker. They work really well on thick-wall steel (I've done 2".495 wall with no drama) --I've never tried 7075 though.
Carl Whitmore
I Lean is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 08:07 AM   #4 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Didn't think of that. I see a 12T kinker in my future
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 04-09-2019, 10:50 AM   #5 (permalink)
Member # 101407
Would cracking be an issue? Maybe throw a little heat into them in the bend zone?
Elvis38 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 11:44 AM   #6 (permalink)
Member # 267321
Rock krawler suspension did an 1.75" 7075 upper for me, you could give them a call.
wellstig1 is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 12:01 PM   #7 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Bent or straight?
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 04-09-2019, 12:21 PM   #8 (permalink)
ISDTBower's Avatar
Member # 94026
Maybe use your die in a press instead of a bender or kinker. Solid will not kink actually. The key will be making a shoe for the bottom that will not squirt out when you press the die down. Someone in your neighborhood probably has a 50 ton press that should do it. Warming to 250-300*f might help. Usually aluminum has about half it's strength around 350- 450* True annealing doesn't happen until the 600-700* range.
"Warming the material to 250 F will greatly assist formability." Speedy metals.
ISDTBower is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 01:49 PM   #9 (permalink)
NERD
gtxracer's Avatar
Member # 25303
After going through the options, I've decided that bending 2.0" x .250 wall 4130 will be an easier task. We have a heat treat oven here that should fit. If not, I know a place that can heat treat for us after welding. Links are shorter, about 24", so should not be a problem. I'm now deciding if I want to use a typical bung with step or machine a pinch bung (pictured below).
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 04-09-2019, 01:53 PM   #10 (permalink)
Member # 267321
It's a bent one for the upper on a rear 3 link, it's to clear a cross member at full bump.
Old 04-09-2019, 02:20 PM   #11 (permalink)
Member # 14094
Send a message via AIM to Hvy_Chevy
What's wrong with the links you have?
Size does matter.
Leave the Zukes to those who really understand.
Hvy_Chevy is offline   Reply With Quote Quick reply to this message
Old 04-09-2019, 04:16 PM   #12 (permalink)
NERD
gtxracer's Avatar
Member # 25303
Nothing except not bent
I can anneal them to bring them back to normalized state. Requires 1525F for an unknown soak time. Mine are also cryo frozen which I am unsure how that effects annealing. If I can get them into the normalized state I could possibly bend them. I believe I'd have enough thread engagement to try this. I'll do some measuring and report back.
97 TJ Build:
Porsche
Fab Parts:
PNW Shock Tuning:
Old 04-09-2019, 04:22 PM   #13 (permalink)
Member # 14094
Ah! I see. I thought you had them in and "working" just wanted to replace with aluminum.
Size does matter.
Similar Threads
Affordable Bender 1-3/4" tube Bender $299 crewcabcrawler Tools and Supplies 3 05-17-2015 06:32 PM
Affordable Bender Tube Bender $299 Special includes die set crewcabcrawler Tools and Supplies 1 12-08-2014 07:45 AM
Baileigh RDB-050 Tube Bender.............$895 BAILEIGH INC. Tools and Supplies 19 03-10-2014 10:32 PM
20% Off Tube Bending Dies, Software & Tube notchers TMI Tools and Supplies 3 11-16-2012 08:25 AM
