Late model 14b questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-17-2019, 10:07 AM   #1 (permalink)
Member # 744617
Searched but couldn’t find much. It seems like everyone’s tends to stick to the older ones.
I found a good looking 14b in a 2500 with factory disk brakes and I had two questions.
First, it has the drain plug right in the front middle bottom corner/edge. I’m worried if I shave it I will have to weld that all together and it would leave a weak spot in the most vulnerable place. I think the shave will end up cutting right thru the middle of the plug. Is my thinking true or will the weld be plenty strong to take on a rock?
Second, I like the option of the newer axles coming stock with disks and e brakes but not a fan of the calipers facing forward. Anyone have experience with this being a bad location? Or can I cover it up with a wheel?
Thanks!
Harborlocal is offline   Reply With Quote Quick reply to this message
Old 04-17-2019, 10:13 AM   #2 (permalink)
Member # 214685
Can’t say anything about the drain plug. I did a half shave, just ground down the lip.
My calipers do stick out pretty good but I figure you’d really have to smash them on a perfectly placed rock to fuck them up bad enough to worry.
Byro is offline   Reply With Quote Quick reply to this message
Old 04-18-2019, 01:49 PM   #3 (permalink)
MtnYota's Avatar
Member # 83913
Ballistic style shave kit cuts the entire drain plug out.
'85 Xtra Cab 3rz,Duals, D60/14b, Detroit front/rear, 35spline chromos,rears/chevys, bad temper
MtnYota is offline   Reply With Quote Quick reply to this message
Old 04-21-2019, 07:57 PM   #4 (permalink)
Member # 744617
Cool thanks guys
Old 04-26-2019, 11:35 AM   #5 (permalink)
E-Locker or Bust!
DMANbluesfreak's Avatar
Member # 163019
I second the comment about the brakes. The only thing to consider is the e-brake cable does stick out (if you intend to use it). I'm going to make a mini-skid for the cables on mine in the near future, but even without it I haven't had any issues over the past 4 years.
2001 Z71 Silverado, Ext. Cab, 5.3L V8 -
Shortened 17" w/Bed, AAM 14B FF w/ Grizzly, Dana 60 HP, Anti-Wrap Bar
4L80e, EcoBox/205 Doubler, 40" ProComps, Rock Sliders, Hidden Winch, Hydro Assist
DMANbluesfreak is offline   Reply With Quote Quick reply to this message
Old 05-01-2019, 07:29 AM   #6 (permalink)
Member # 21215
Location: Tennessee...The land of high horsepower and low IQ
Thanks!
The new 14 bolts are great axles. Drain plug is in a shit location. It completely rules out the simple "13 bolt" covers where all you have to do is cut off the bottom lip/bolt with a sawzall. If you want any sort of shave you have to do the full shave/weld plate/cover route. More expensive and time consuming. I just decided not to fool with it and run the full knuckle drag option. One thing to watch for, I've noticed that some of the late model 14s are really wide like 70"+ WMS. So be sure to measure. If you got lucky you may have a 4" tube casting version.
The bartender only serves brown liquor in hell, and that sure sounds like heaven to me.
redneckengineered is offline   Reply With Quote Quick reply to this message
Similar Threads
late model 14 bolt srw hubs Mike2.5 Axles/Tires/Wheels For Sale 6 10-27-2015 03:11 PM
Fiat buyback on jeeps and dodge trucks. Beat95YJ General Chit-Chat 94 10-20-2015 11:08 PM
Late model Power Wagon axles on LJ SHoppe715 Jeep - Hardcore Tech 10 03-26-2015 12:45 AM
Late Model Power Wagon Front Axle 87YJ Wanted! 0 10-26-2014 08:42 AM
Late Model Plastic Fuel Injection Fuel Hose yager General 4x4 Discussion 2 02-01-2012 09:44 AM
