Fuel Pump And Regulator for Q-jet Carb - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-07-2019, 02:56 PM   #1 (permalink)
Member # 1236
I'm looking to install a Quadrajet on the 350 chevy motor in my 51 flat fender. What fuel pump should I use and do I need a pressure regulator to keep from overpowering the float/needle when I'm bouncing on the rocks? Should the fuel pressure regulator have a return to tank line? A long time ago I had a vacuum operated Cagle regulator on it and it ran good but I can't find one out there on the web. Also, is the Q-jet better on steep climbs? I used to have a 600 CFM Holley and it was a bitch getting it to work on high angles.
'51 M-38, 350, T-18 to D-18 w/OD, 2xD44, 2xDetroit
loco4x4 is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 03:11 PM   #2 (permalink)
Member # 69633
Location: I live in my body: On the land near Paradise Township, Jefferson State, not by choice.
Does the 350 Chevy have a provision for a mechanical fuel pump ?
I would use that over an electric pump, much more reliable fmpov.
Call summit.
The less a person knows ǝɯosʍɐ ɯI , the more certain they feel about the little they know.
ParadiseAutoElectric is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 05:02 PM   #3 (permalink)
Twankie's Avatar
Member # 230823
Run a factory mechanical pump from a 70’s-early 80’s Chevy. It will be internally regulated and have a return line.
Twankie is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 05:52 PM   #4 (permalink)
Member # 1236
The mech pump is now blocked off. It had one on there when I bought the jeep in 89. Since I will feed from the tank drain thru the floor (tank under driver's seat) into a sump tank below the floor, it should be easy enough to draw from. I should have the clearance for the pump.
Old 05-07-2019, 07:25 PM   #5 (permalink)
lil,yota's Avatar
Member # 102395
That carburetor only wants 9-12 psi.
Just get a cheap electric pump, mount it near the tank.
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 07:38 PM   #6 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Yup. Either just buy a pump, plate, and rod and put a mech on it or a cheap pre-regulayed elce pump
Most carb only want 7psi but old school jeep guys install a hand opp, mech regulator and roll the psi real low when putting over obsticals
Old 05-07-2019, 08:55 PM   #7 (permalink)
Baldy110's Avatar
Member # 104602
The Q jet is the best carb for a 4x4. I ran one for years, it'll run pretty much at all angles except upside down when set up right. There's a reason it's called hillbilly fuel injection.
Baldy110 is offline   Reply With Quote Quick reply to this message
Old 05-07-2019, 09:58 PM   #8 (permalink)
Newbie
M92pv4u's Avatar
Member # 860424
I've used Carter and Holley electric fuel pumps on a quadrajet, it ran best with the factory cam driven pump. As for the return line I installed a 70s dodge style inline fuel filter they had a built in return line. Something like this https://images.app.goo.gl/6ynhrp6f5D17nkcj8 The part # I used is in the picture.
M92pv4u is offline   Reply With Quote Quick reply to this message
