D30 Powertrax no-slip Defects. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-10-2019, 05:22 PM   #1 (permalink)
Member # 868102
Lurked around here for a bit, always a good source of information hidden in some useless banter
06 TJ
d30/d44 3.73 gearing
6spd manual
31in patagonias
Installed the rear no-slip first, and have had no issues with it for the past few months.
1: A week later I installed the front no-slip in the d30.
Blew up 20 miles later, on road only. Drove from a friends house to mine.
2: Warrantied it out, was paranoid installing it. I literally put it in/out at least 3 times to make sure everything was lined up correctly and done right.
drove ~1500 miles, a day of light trails(2wd mostly) and a day of fun in the mud. Someone pointed out that I was 3wd. I popped the cover to check for issues. The springs were collapsed just enough to not keep both sides engaged all the time. Annoying, but not a huge issue. Then I noticed it was cracked around the pins.
3: Little pissed, but warrantied it out again. New locker arrives, already split around the pins. Brand new, never been installed.
First one I chocked up to being user error or defective. 2nd one was definitely a defect. 3rd one, someone wasn't doing their job.
whitrzac is offline   Reply With Quote Quick reply to this message
Old 05-11-2019, 07:49 AM   #2 (permalink)
Member # 177092
So have you talked to someone in engineering at Powertrax? You shouldn't be having those kinds of failures, especially with the way your Jeep is set up and how you have been using it. It sounds like they may have had a bad run or two of the casings that need to be recalled.
I have installed a Lock Right into a LJ with 35s that wheels hard trails (but doesn't get beat on) with no issues. I also installed an Aussie or Spartan (I don't remember which) into an XJ that had the tar beaten out of it on 33s and later 36s, and he never had a problem with the lunch box locker. So, I don't have personal experience with the Powertrax unit, but they are all more or less the same and should be able to stand up to some abuse.
'84 Bronco II is online now   Reply With Quote Quick reply to this message
Old 05-11-2019, 08:01 AM   #3 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
For what it's worth, the Aussie and Lokka brand lunch boxes have been flawless for me. By that I mean I typically break a cross pin or carrier before I lose the pins or physically break the locker.
Action Fab is offline   Reply With Quote Quick reply to this message
Old 05-11-2019, 04:33 PM   #4 (permalink)
Old School
Technohead's Avatar
Member # 130090
Unhappy
Torq Master locker. Done.
-Eric
Redneck-at-Large
Technohead is offline   Reply With Quote Quick reply to this message
Old 05-11-2019, 06:19 PM   #5 (permalink)
Member # 868102
I got a corporate spiel after I called on the first one. I haven't had a chance to call about the 2nd, or the one broken in the box yet.
Old 05-11-2019, 06:46 PM   #6 (permalink)
Member # 177092
You might send them an email with the pictures you posted here. I have typically had better luck discussing product defects via email rather than on the phone with customer service.
If they don't believe it is a defect, I would try and get a refund and buy a different brand.
Similar Threads
POWERTRAX LOCK-RIGHT Lockers - Just Differentials justdifferentials Axles/Tires/Wheels 8 08-30-2016 11:16 AM
POWERTRAX LOCK-RIGHT Lockers - Just Differentials justdifferentials JTS Parts & Accessories 6 08-30-2016 11:16 AM
Basic IFS Bump Steer Tech ThinAirDesigns General 4x4 Discussion 187 04-13-2015 12:32 PM
PowerTrax No Slip in 8.8 Cant get C-Clips out pbj-tj Jeep - Non Hardcore 12 08-18-2012 06:40 PM
cheapest place to buy a powertrax no slip portworks General 4x4 Discussion 6 03-28-2012 07:36 PM
