Canít get bumpstop out!!! - Pirate4x4.Com : 4x4 and Off-Road Forum
Register Blogs FAQ Community Calendar Premium Memberships
Old 05-17-2019, 08:52 AM   #1 (permalink)
G.C. Bandit's Avatar
Member # 3237
Send a message via AIM to G.C. Bandit
Anyone have additional ideas how to remove this thing. I have sprayed WD 40 between the bumpstop and can. Tried beating the top of the bump stop with hammer. I have put a pipe wrench on it and tried to rotate the bumpstop to loosen things up. All with no luck. The bumpstop hasn’t moved a inch. Yes, snap ring is removed and can bolt is loose. It has been installed for almost 9 years
TJ/Wrangler MUTT...
Dana 80 37 Spline, Discs :)
Bling HP60 Dendenbears,Chromos/Longfields FULL HYDRO 47LTB's Locked with C&R BreadLocks 350TBI Sm465 203-205 Gen2 Doubler
[SIZE="5"][B][COLOR="Blue"]ROCKZOMBIES4X4.com[/COLOR][/B][/SIZE]
R.I.P. Dave "Kyle"
That was one hell of a ride, I will never forget!
G.C. Bandit is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 09:24 AM   #2 (permalink)
Member # 3007
Sounds like you have some aluminum to steel corrosion
Most common way to get it was powdered drain cleaner. Make sure you get one that doesn't include aluminum already
Bones is online now   Reply With Quote Quick reply to this message
Old 05-17-2019, 01:17 PM   #3 (permalink)
Weasel's Avatar
Member # 5639
heat the outer mount and coole the bump with CO2? Depressurize first
Kindness doesn't condemn or condone
Just Add Lightness
Weasel is offline   Reply With Quote Quick reply to this message
Old 05-17-2019, 01:47 PM   #4 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
2" tube aligned with the outer edge, bottle jack with some pressure, dump a coke on it, and leave overnight. should be laying on the floor in the am
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote Quick reply to this message
Old Today, 07:01 AM   #5 (permalink)
Member # 113606
Can you not take the pinch bolt out and pry the two halves apart some?
Fight Crime...Shoot Back.
[SIZE="4"][COLOR="Red"]ΜΟΛΩΝ ΛΑΒΕ[/COLOR][/SIZE]
[QUOTE]Originally Posted by [B]Muddin [/B]
It wasn't a little "achoo". It was "achsshemmiddtpppthpphphphphtsmmmppp...spray".[/QUOTE]
j20brett is offline   Reply With Quote Quick reply to this message
Old Today, 07:21 AM   #6 (permalink)
Bunk's Avatar
Member # 41059
Send a message via Yahoo to Bunk
dissimilar metals partied and joined as one
Bunk is offline   Reply With Quote Quick reply to this message
Old Today, 09:54 AM   #7 (permalink)
Member # 113606
Well, yeah, i get that. To help break the parts apart, pry between the pinch bolt bungs with a prybar of your choosing.
Old Today, 10:15 AM   #8 (permalink)
Member # 1889
I've driven a cold chisel or a big screwdriver in between the pinch bolt bungs, parallel to the bump can, to help spread it just a bit. It rarely takes much spread, but depends on what's welded on, where, and I've never tried removing one that's been in place as long as OP's.
Scott@Rockstomper is online now   Reply With Quote Quick reply to this message
Similar Threads
California keeps a secret list of criminal cops, but says you canít have it 87manche General Chit-Chat 12 04-23-2019 10:00 PM
Nature photographer canĚt get paid because a monkey ĚownsĚ the photo Landslide General Chit-Chat 27 08-07-2014 08:24 AM
Full body rig - ORI strut rear bumpstop paradox YeeP General 4x4 Discussion 12 05-17-2013 10:08 AM
bumpstop question poolman450 Toyota - Truck and 4Runner 15 06-13-2012 10:42 PM
(1) Air Bumpstop hotdogboy Wanted! 7 03-01-2012 08:43 AM
