Make ProRock D60 IFS Center - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-01-2019, 07:35 AM   #1 (permalink)
Member # 828594
Take 1 05+ superduty front D60, cut accordingly, have housing machined, then use Curries CV 35 Spline stub shafts... both should have 35 deg pressure angle... Thoughts..
GEspo is offline   Reply With Quote Quick reply to this message
Old 06-01-2019, 10:04 AM   #2 (permalink)
Bunk's Avatar
Member # 41059
Send a message via Yahoo to Bunk
I would be scared that material would be lacking in critical areas.
Bunk is offline   Reply With Quote Quick reply to this message
Old 06-01-2019, 05:47 PM   #3 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
What does a Ford Dana 60 have to do with a ProRock aftermarket housing?
& Blaine
:tank:
Old 06-01-2019, 07:28 PM   #4 (permalink)
lil,yota's Avatar
Member # 102395
Isn't it technically a DANA 60 for a Ford
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is offline   Reply With Quote Quick reply to this message
Old 06-01-2019, 07:42 PM   #5 (permalink)
Wheeling 24/7
Beat95YJ's Avatar
Member # 22176
Most 05+ super duty’s are Fords.
& Blaine
:tank:
Old 06-01-2019, 07:54 PM   #6 (permalink)
Member # 53528
what about using axle tubes with flanges welded on? the long side casting would need to be shortened but guys are doing that already
Old 06-01-2019, 08:37 PM   #7 (permalink)
lil,yota's Avatar
Member # 102395
That was an attempt at humor
My Dream Build
Dr Danger
Old 06-01-2019, 10:17 PM   #8 (permalink)
Member # 828594
Ok now you're talking... instead of altering and welding to the cast housing. Someone years ago did something with a D44 on a Hummer. What flanges will work with the 60 housing? The tubing is 3.75" I think.. The big goal here is to use it in some version of a 4x4 trophy truck, just less $300K
Old 06-01-2019, 10:31 PM   #9 (permalink)
Member # 53528
he wants to make one out of a superduty axle instead of buying a prorock from dynatrac, hence the title make a prorock d60 ifs center
Old 06-01-2019, 11:03 PM   #10 (permalink)
Member # 828594
If the tubing is used to mount flanges and support brackets, structurally the concern is the initial/factory 60's center to tube welds holding up...
Old 06-02-2019, 12:03 AM   #11 (permalink)
Member # 53528
he was responding to your initial comment about machining it
Old 06-02-2019, 12:28 AM   #12 (permalink)
Member # 828594
I'm still wondering about the tube to center welds... I see Currie and Spidertrax use the same mount points for their center sections(both 9's), looks like a 3 bolt plate for the axle flange.. maybe they'd be willing to part with a few billet mounting plates. Liking the $520 ea price for Curries series 30 35 spline...
Old 06-02-2019, 10:13 AM   #13 (permalink)
Bunk's Avatar
Member # 41059
You need to start looking at flange to flange measurements of an assembled ifs center.
Old 06-03-2019, 11:26 AM   #14 (permalink)
Member # 828594
So.. Currie is not selling any part of their housing due to not producing the unit in house.. however Moser will make custom axle stubs with ANY flange for 380$ (PAIR), and 100$ for 60 axle ends... I'd need custom axle bearing plates and then fabricate their housing ends to the 60s tubes.. Probably go with some basic CNC design and incorporate mounting points on the plates..
Old 06-04-2019, 04:12 AM   #15 (permalink)
arse_sidewards's Avatar
Member # 256962
Is there any reason you can't just turn down and drill your desired bolt pattern into some semi-float shafts and retain them with a C-clip? From there you can run CVs for whatever application you fancy.
Modifying the housing would be a simple case of cutting it down to width and boring it to whatever ID the semi-float bearing and seal want.
Old 06-05-2019, 10:27 PM   #16 (permalink)
Member # 828594
C clip is definitely an option too... Just rough measuring looks like possibly 17" from flange to flange due to the casting plug welds.. It would be around 15" if I want to ignore most of them.. Anyone have info/experience with how far the tubes extend into the cast center.. also what the welds are like at those points, ie how many... how far into the cast before the tubes will pull out??
Old 06-05-2019, 11:29 PM   #17 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
With out know what reason youre wanting a d60 specificaly, why even bother with a d60 oe conversion?
Juat get a 9.75 irs diff from a navigator or get a ruffstuff 9" housing withe brg flanges weled right to the housing.
Old 06-06-2019, 06:29 AM   #18 (permalink)
Dinkerdoodledoo
Member # 10448
Send a message via Yahoo to Grendel
Or a Camaro IRS chunk.
There are lots of IRS holding really big HP with wide tires and a hell of a lot of traction.
The chunk in the picture has an e-LSD that is pretty fucking close to a locker with 12v applied consistently instead of switched by the Body Control Module.
All the lockers and stuff also available.
Also has cooler ports.
Youre the only person on earth who knows all the details of your life, and thus, you are the most qualified captain of your own ship. Dont worry about justifying your course for pirate's sake. There's always someone here to tell you that you did it wrong.
Grendel is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 02:58 PM   #19 (permalink)
Member # 161331
Not that great.
Whats the flange to flange on that?
bdkw1 is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 03:17 PM   #20 (permalink)
Dinkerdoodledoo
Member # 10448
12.5" - has 37 spline anti-hop axle shafts with it.
They're handling 1200 hp in 3900 lbs cars with 13.5" wide tires that go 8 seconds in the quarter and they go all year +
We want to do one f+r to go awd with an NP120 t-case in an all aluminum Jeep.
Old 06-06-2019, 03:36 PM   #21 (permalink)
Member # 256962
Maybe he wants high pinion for a front application?
Otherwise, 9.75 all day.
Old 06-06-2019, 06:03 PM   #22 (permalink)
Member # 145904
double check those pressure angles. Ford 60 should be 30 and many racing parts use 45. Ford 9" can be had in either
winter4x is offline   Reply With Quote Quick reply to this message
Old 06-06-2019, 07:28 PM   #23 (permalink)
Member # 161331
So you would be flipping the front one over? Those are pretty narrow, they look good for the rear.
Old 06-06-2019, 08:41 PM   #24 (permalink)
Member # 53528
why would he need to flip it over to put it in the front?
Old 06-06-2019, 10:01 PM   #25 (permalink)
Member # 828594
I haven't thought too much about running a rear in the front.. I did read that there are oiling issues and gears being on the wrong side or something of the sort(dont quote me on that btw).. As far as a 9" I've done a bit of looking into it for the rear on my truck however I was told not to bother with it unless I was planning on running a 10" gear w/ MIN 40 spline shafts.. Gearworks is the only game for the larger 3rd housing and they have a HP front.. too much $ for 1.5" inches a side if we're talking the difference in 14" and 17" flange to flange.. Camaro irs is nodular iron??
