SuperDuty ('07) steering box input shaft size? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-14-2019, 08:48 AM   #1 (permalink)
Member # 728961
I'm trying to connect the SuperDuty gearbox to the F-150 intermediate shaft. I already cut off the U-joint from the F-150 intermediate shaft, leaving a perfect bare square shaft. I'm looking for the right U-joint to order so I can weld it on. What is the input shaft size/spline count on the SuperDuty gearbox?
texastruck is offline   Reply With Quote Quick reply to this message
Old 06-14-2019, 08:49 AM   #2 (permalink)
Member # 728961
I've read it may be 3/4" 36 spline or 32 spline, but I'm not sure if they are talking about the sector shaft (where the pitman arm bolts to) or the input shaft.
Old 06-14-2019, 08:50 AM   #3 (permalink)
Member # 847209
I am not an expert but the suprduty has a dana 60 35 spline axle. I believe same for steering box. I will be upgrading mine as well in January
Sent from my SM-N910P using Tapatalk
ckkphoto is offline   Reply With Quote Quick reply to this message
Old 06-14-2019, 09:27 AM   #4 (permalink)
6gun's Avatar
Member # 95448
Not necessarily the best way but I simply measured, aligned and welded the SD input shaft to my Ranger's steering shaft.
Sent from my LG-H700 using Tapatalk
'99 Ford Ranger 4.0/5R55E/BW1356E/5.13 gears/'06 D60 F/99 Sterling R/ 39X12.50 Kanati
6gun is offline   Reply With Quote Quick reply to this message
Old 06-14-2019, 10:04 AM   #5 (permalink)
Member # 728961
You welded the Ranger steering shaft directly to the input shaft? I'm not sure if I want to do something that permanent.
Old 06-14-2019, 12:22 PM   #6 (permalink)
6gun's Avatar
Member # 95448
No, we welded the upper half of the Ranger steering shaft to the lower half of the SD shaft. Not much of a picture but this is it.
Old 06-14-2019, 01:46 PM   #7 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Thatís essentially how built my steering shafts. Cut weld. Done.
Old 06-14-2019, 11:10 PM   #8 (permalink)
Member # 728961
ah ok that makes much more sense. Looks like that's the route I'm going to take. Just got to find a junkyard superduty shaft for a decent price. Thank you.
