71 Bronco with 38 tires - new gears - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-23-2019, 11:24 AM   #1 (permalink)
Member # 871982
I have a 71 Bronco with 38" tires, 4.9L/300 and an NP435, and I need to change the gears to make it highway-friendly, but still keep it offroad capable. As it is right, it way too low, it's set up for crawling and it doesn't pass 40 mph. I don't know what's in it. I was thinking about putting 456s.
I changed the tires to 38x13 (the ones in the pics 39x18.5)
Any thoughts? Thank you.
Does anyone know a good and honest off-road mechanic in the Catskills area?
Thunderchief is offline   Reply With Quote Quick reply to this message
Old 08-23-2019, 11:48 AM   #2 (permalink)
Member # 85771
It doesn't pass 40mph? Whats happening at 40 that makes you think it wont go any faster?
Make Forums Great Again!
Old 08-23-2019, 11:55 AM   #3 (permalink)
Member # 871982
It's on top of the 4th gear with revs are out of the roof and engine screaming. It was set up for hardcore crawling.
Old 08-23-2019, 11:56 AM   #4 (permalink)
Member # 847209
Sounds perfect to me as is!
ckkphoto is offline   Reply With Quote Quick reply to this message
Old 08-23-2019, 12:06 PM   #5 (permalink)
Member # 66173
drop the diff gears and add a doubler. Best of both worlds.
2000 XJ
jonzer12 is offline   Reply With Quote Quick reply to this message
Old 08-23-2019, 12:23 PM   #6 (permalink)
Member # 53528
with a 6.69 first gear in the np435 he probably doesnt need a doubler
rockyota83 is online now   Reply With Quote Quick reply to this message
Old 08-23-2019, 12:32 PM   #7 (permalink)
Member # 85771
C6
Old 08-23-2019, 12:36 PM   #8 (permalink)
Member # 79509
Take the transfer case out of low range
With 5.38s, youd be 2k rpm at 40mph.
Black Sheep is online now   Reply With Quote Quick reply to this message
Old 08-23-2019, 12:48 PM   #9 (permalink)
Member # 85771
But "hardcore rockcrawler"
Old 08-23-2019, 01:08 PM   #10 (permalink)
Newb
nvrenuf's Avatar
Member # 10903
Yep Yep
John
'91 K5 454, 4spd, Doubler, J76/70HD, 5.86's & 43's
nvrenuf is offline   Reply With Quote Quick reply to this message
Old 08-23-2019, 01:12 PM   #11 (permalink)
Member # 158308
My f250 is on 40s but i am getting ready to bob the back end to make it shorte! I bet we meet in the middle.
WTF is this Guy asks about his gears in his Bronco and you start posting pictures of your truck talking about bobbing it.
Anyway, your Bronco sounds like it has a great combo as is for off-road. Why is it you need to drive on the highway again? 4:88 is a good ratio for the mix.
73,76,78 Broncos, 77 F150 4x4, 93 C350.
Prizefighter is offline   Reply With Quote Quick reply to this message
Old 08-23-2019, 01:18 PM   #12 (permalink)
Member # 53528
maybe he has d60/70s with 7.17 gears
probably not though
Old 08-23-2019, 02:38 PM   #13 (permalink)
welndmn's Avatar
Member # 398
This.
Also, are you sure it's a 4.9?
That is not a commonly (like ever) swapped motor into an EB.
Mark
Old 08-23-2019, 04:37 PM   #14 (permalink)
xjtony's Avatar
Member # 50866
Lol
Low Budget Sammy
xjtony is offline   Reply With Quote Quick reply to this message
Old 08-23-2019, 10:18 PM   #15 (permalink)
Member # 871982
Originally Posted by welndmn View Post
This.
Hi, I know. But the previous owner put a 4.9L/300 long block and moved the radiator to the back.
Old 08-23-2019, 10:20 PM   #16 (permalink)
Member # 871982
Originally Posted by xjtony View Post
Lol
Ideally, I would like to be able to run at ~60mph without stressing the engine and still be able to have a good offroad setup.
Old 08-23-2019, 10:23 PM   #17 (permalink)
Member # 871982
probably not though
It sure feels like it, if not even more. I have no idea what's in there. This is my first offroad vehicle. 1st gear screams to change at 7mph.
Old 08-23-2019, 10:24 PM   #18 (permalink)
Member # 871982
C6
Eventually, I do want to put a small block an auto.
Old 08-23-2019, 10:27 PM   #19 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
What gears do you have now?
What RPM do you want to run at 60?
With an np 435 you only use 2nd thru 4th in normal driving.
Have you tried an rpm calculator?
& Blaine
:tank:
Old 08-23-2019, 10:27 PM   #20 (permalink)
Member # 871982
That's what I was told, ahahahahah. I don't know, this is my first offroad vehicle.
Does anyone know a good and honest off-road mechanic in the Catskills area? I'm in Kingston/Woodstock area.
Old 08-23-2019, 10:30 PM   #21 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Figure it out. If need be, jack up the rear end and count driveshaft revolutions while rotating the tire.
& Blaine
:tank:
Old 08-23-2019, 10:39 PM   #22 (permalink)
Member # 871982
I would like to be able to drive it somewhat normal in the highway if needed, but it will mostly be a Mountain vehicle.
I was told that the low gears are so granny and I should consider putting 411s or 456s to easy up a bit a be able to drive in town easier. 456s or 488s, or 538s?
No odometer just ears a feel.
Old 08-23-2019, 10:46 PM   #23 (permalink)
Member # 79509
Tried shifting the tcase out of low to hi yet?
What axles does this hardcore crawler have?
Old 08-23-2019, 10:46 PM   #24 (permalink)
Member # 871982
Lol
With the 4.9/300 I would to be at 2500 @ 60mph
Old 08-23-2019, 10:48 PM   #25 (permalink)
Member # 871982
I read that they make an overdrive kit for the NPs. Have you ever heard of it? it's worth it?
