Goatbuilt Kids Buggy Chassis Build - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-16-2019, 09:07 AM   #26 (permalink)
MNorby's Avatar
Member # 11448
Send a message via Yahoo to MNorby
Very cool concept and build. Thank you for sharing here.
MNorby is offline   Reply With Quote Quick reply to this message
Old 09-16-2019, 03:10 PM   #27 (permalink)
4xcrawler's Avatar
Member # 87361
Originally Posted by charlieboyd65 View Post
Awesome! Sub'd!
Thanks!
Originally Posted by WildWilly4x4 View Post
Nice build! I have a mini willys jeep that I have been building for my son. Running a Honda 300 motor in mine. I started a thread on it a few years ago, but I haven't updated the thread. rig is pretty much ready to tear down and paint, other than finishing up the brake system, drive lines, and building a cage for it. Brakes and driveshaft adapters have been the big hold up on mine due to the odd LJ20 axles I am running on it.
Contact Brian at Driveline Tech, or pm me and I can give you his info, he can get your adapters and shafts easily, heís also building a mini buggy so knows all about this exact package
Originally Posted by OnTheSpot View Post
You are a cool dad!
Is that a pull start I see?
Thanks, yeah it has electric start and pull start backup, the pull start can be modified to run a pulley and mount a real psc belt driven steering pump too
Originally Posted by GiS View Post
Great proportions and "full size" tech in a small package!
To help me wrap my mind around scaling, what are the dimensions of your chassis table there? 3x6'?
Thanks, yeah itís 3x6 I believe, Iím out of town now wheeling in Moab
Originally Posted by Blase View Post
super cool!!!
Thanks
4xcrawler is online now   Reply With Quote Quick reply to this message
Old 09-16-2019, 03:11 PM   #28 (permalink)
4xcrawler's Avatar
Member # 87361
Thanks!
Old 09-17-2019, 04:39 AM   #29 (permalink)
WildWilly4x4's Avatar
Member # 17680
Here are a couple pics of my kids project. Nowhere near the caliber of fab going into yours, but should be fun all the same.
'50 m38, 60, 14bolt, 4.3, 420, dana 300, 35" krawlers on trailready's/ '80 Blazer 60,14 bolt, tpi 350, th400, 205, 35" swampers
Link to my M38 build:
WildWilly4x4 is offline   Reply With Quote Quick reply to this message
Old 09-17-2019, 09:50 AM   #30 (permalink)
4xcrawler's Avatar
Member # 87361
Nice, anything to get our kids involved is an awesome project!
Old 09-17-2019, 10:29 AM   #31 (permalink)
atxrunner's Avatar
Member # 136876
Great work! I love Drew’s stuff. Would you be willing to cut some more axle link brackets and sell them?
atxrunner is offline   Reply With Quote Quick reply to this message
Old 09-17-2019, 10:51 PM   #32 (permalink)
4xcrawler's Avatar
Member # 87361
The #kidsbuggy finally got to stretch its legs for the first time to check clearances at full droop and flex. Everything is working out perfect without an inch to spare. Fox 2.0x12 air shocks. 1.5Ē Al lower links from @WideOpenDesign, 1.25x.120 DOM uppers. PSC 1.75x6 ram mounted. Now itís time to burn everything in and plate it all up.
Old 09-17-2019, 10:52 PM   #33 (permalink)
4xcrawler's Avatar
Member # 87361
Old 09-17-2019, 10:59 PM   #34 (permalink)
4xcrawler's Avatar
Member # 87361
Originally Posted by atxrunner View Post
Great work! I love Drewís stuff. Would you be willing to cut some more axle link brackets and sell them?
Thanks. Once I finish the rear truss and make sure everything works itíll be easy to cut duplicate parts of any of the link/truss mounts if someone would like them for their build. I just donít want to cross any lines on here due to not being a vendor.
Old 09-18-2019, 03:38 AM   #35 (permalink)
Member # 17680
what are your plans for the power steering pump? I would assume electric over hydraulic? if so, I would make sure to beef up the stator, and maybe go to a much stouter regulator rectifier. The stock rectifier on my 450 foreman is barely adequate for stock four wheeler duties.
Old 09-18-2019, 05:27 AM   #36 (permalink)
Member # 143737
He mentioned the possibility of being able to remove the pull start and fab a belt drive PS pump. Maybe doing that for a GM 1 wire isn't a bad idea.
Then the kids can run all the LED pods and halos they want
POS Ranger on narrow 3/4 tons with a 357w noise maker
posford is offline   Reply With Quote Quick reply to this message
Old 09-18-2019, 06:42 AM   #37 (permalink)
4xcrawler's Avatar
Member # 87361
The plan to start is a Toyota MR2 electric power steering pump, thereís several guys running them with good results off the stock quad electric systems. Iíll also be running an Odyssey 925 battery which is massive for the little bit of power this thing needs and could just straight run the pump if needed then charge when weíre back at the house. If that plan doesnít work, then thereís the option to convert the pull start to a belt driven TC or P pump and/or a small Alternator.
Old 09-18-2019, 12:22 PM   #38 (permalink)
atxrunner's Avatar
Member # 136876
Originally Posted by 4xcrawler View Post
The plan to start is a Toyota MR2 electric power steering pump, there’s several guys running them with good results off the stock quad electric systems. I’ll also be running an Odyssey 925 battery which is massive for the little bit of power this thing needs and could just straight run the pump if needed then charge when we’re back at the house. If that plan doesn’t work, then there’s the option to convert the pull start to a belt driven TC or P pump and/or a small Alternator.
The Mr2 pump will be fine for slow crawling but a bit sluggish for high speed stuff. I have a buddy here in Texas that’s had good luck with crank driven pumps where the pull start was. His sons and Cody Wagner’s run crank driven. The only downside to crank driven is that it stalls the motor unless the kiddo learns not to turn in too hard at full lock. We have been working with PSC on this and if you call them when and if you ever decide to switch to a traditional pump they will have an idea what you need. We run a blue top optima with the MR2 pump and it will run all day but does need to be charged after a long day.
Old 09-18-2019, 12:26 PM   #39 (permalink)
atxrunner's Avatar
Member # 136876
This the way I wired it and itís been problem free for three plus years now.
Old 09-18-2019, 12:26 PM   #40 (permalink)
mobil1syn's Avatar
Member # 9795
Send a message via AIM to mobil1syn
ryan did something different on codys buggy that i believe solved the stalling issue because he went to a different motor then he runs which allowed for a different sized pulley.
We are all born Arminians. It is grace that turns us into Calvinists
-George Whitefield
mobil1syn is offline   Reply With Quote Quick reply to this message
Old 09-18-2019, 02:24 PM   #41 (permalink)
atxrunner's Avatar
Member # 136876
Ryan is running an older rancher 350 motor and he used a new rancher 420 fuel injected motor in Codyís.
Old 09-18-2019, 07:05 PM   #42 (permalink)
4xcrawler's Avatar
Member # 87361
The Mr2 pump will be fine for slow crawling but a bit sluggish for high speed stuff. I have a buddy here in Texas thatís had good luck with crank driven pumps where the pull start was. His sons and Cody Wagnerís run crank driven. The only downside to crank driven is that it stalls the motor unless the kiddo learns not to turn in too hard at full lock. We have been working with PSC on this and if you call them when and if you ever decide to switch to a traditional pump they will have an idea what you need. We run a blue top optima with the MR2 pump and it will run all day but does need to be charged after a long day.
Awesome, thank you for the info! I hadnít got far enough along to even look into wiring yet. I think the pump will be good to start, my 4yo doesnít need to go fast yet, lol. My 10yo drives my buggy so that way theyíll both be able to drive now. I think she would definitely out run the steering trying to haul in it lol
Old 09-19-2019, 07:33 AM   #43 (permalink)
Member # 675081
Manual steering
Very cool build. I like your designs for the a kids kit and I think you will do good with a kids kit.
I 'm going to build one for my grand kids next year and will use your kit. For my steering I don't want the ram, pump and lines. I've been working on a Rack on axle design with in shaft electric power steering if your interested PM me for more details.
Keep up the great work!
OCB
Angle X is offline   Reply With Quote Quick reply to this message
Old 09-19-2019, 09:58 AM   #44 (permalink)
4xcrawler's Avatar
Member # 87361
OCB
Thanks. The chassis is based off of Jesse Haines design for the full size 2 seat chassis kit produced by Goatbuilt. I just took it and changed it all and scaled it down to work as a mini buggy and fit the parts list I wanted. The chassis should be in production soon from Goatbuilt so contact them when you're ready.
The in shaft electric power steering systems work ok for a RZR and going fast, but they don't have near enough power to turn big tires on a solid axle in the rocks, especially with water in the front tires. There's several people running them on smaller kids buggies though with smaller 30" tires and Sami axles and they work ok. I run 36" tires on my RZR Turbo S4 which has 25% more steering power than most electric shaft systems and that thing doesn't turn at all going slow in the rocks, and that's with an adult yanking on the steering wheel, a little kid would have they're arms ripped off when they bumped into a rock. Which bring up another point on the full hydro system, run a non-load reactive orbital that way when they do run into stuff the steering wheel isn't yanked around as much and possibly hurting them.
Old 09-19-2019, 02:19 PM   #45 (permalink)
Member # 14644
I'm curious about the in shaft electric power steering as well. There are some 400 watt kits that seem stout with out the hydraulic complexity.
Here's a 700 watt kit as well.
https://www.proutvparts.com/products...22ecf6be&_ss=r
1986.5 Nissan crawler - dual cases, one tons, 42's
bignissan is offline   Reply With Quote Quick reply to this message
Old 09-20-2019, 05:23 PM   #46 (permalink)
Member # 14644
If I'm thinking of this correctly, the 700 watt kit should put out around 100 ft lbs compared to the 400 watt kit at 60 ft lbs. If you use a manual steering box with a standard 20:1 ratio, that's 2000 ft lbs out put. Seems pretty good!
Old 09-20-2019, 07:44 PM   #47 (permalink)
Member # 873218
Absolutely! I have twin 4 yrs old and I want to get started on a project like this soon
steve.pro.mb is offline   Reply With Quote Quick reply to this message
Old 09-22-2019, 10:46 AM   #48 (permalink)
4xcrawler's Avatar
Member # 87361
Yes, itís definitely a option depending on how youíre wanting to build and your budget, thereís several people that use them with good results. Just like any other rock crawler, you can go power steering, hydro assist, or full hydro, just depends on what you want. Another thing to note though, if using a steering box youíd need to run a 3-link and panhard obviously and not a 4 link.
Do it!
Old 09-22-2019, 10:50 AM   #49 (permalink)
4xcrawler's Avatar
Member # 87361
The rear truss for the #kidsbuggy from mock up to completion. First cut out of 16ga to check fit, then cut out of .120 100XT, jigged and squared on the bench to set tab locations, then like legos keep adding pieces after the inside welds are done. To help from tabs warping too much and making your spacing for your joint to tight, I first weld all the outside edges. This pulls the tabs apart and gives you a little extra room with the mock up heim finger tight. Then when switching to welding the inside joints I put a little bolt spacer in there to give about 1/16 extra play in the joint (or you can use a really thin washer). Then after all the inside joints are weldwe the tabs have enough tension from welding that they pull back to straight once the spacer is removed and your joint easily slides in and out again with perfect spacing.
Old 09-22-2019, 10:51 AM   #50 (permalink)
4xcrawler's Avatar
Member # 87361
