TJ- 5 speed to Auto Swap - Pirate4x4.Com : 4x4 and Off-Road Forum
View Poll Results: Which Automatic Would You Choose?
TH400 6 46.15%
42RLE 0 0%
Other 7 53.85%
Voters: 13. You may not vote on this poll
Old 10-10-2019, 08:24 AM   #1 (permalink)
Member # 322985
I've got an '03 TJ......Stretched/ Tons/ Atlas/ Stickies/ ORIs. I have every intention of doing an LS swap in the future, but I'm really starting to hate the 5 speed. I want to swap to an automatic, but I'm not sure if I want to wait until I'm ready for the LS swap to do that. I know it's not the BEST choice, but I have a freshly rebuilt TH400 sitting on the shop floor. Should I consider adapting that to fit behind the 4.0, or look for a Jeep automatic (42rle)/ ecm/ harness to fit? Am I overlooking another option? Or should I just keep wheeling it as-is, and wait until I'm ready to LS swap it to add the auto at that time?
beaureed445 is offline   Reply With Quote Quick reply to this message
Old 10-10-2019, 09:39 AM   #2 (permalink)
Member # 56430
I have a 97 TJ. Originally a 4 cyl and 5 speed rig.
I swapped in a 350 and TH400 to Atlas over 10 years ago.
If I were to do it again, I'd go LS with matching year's automatic, and use that car's wiring and computer as a complete package. The only thing I miss on my current setup is having an overdrive.
Currently running 4.56 gears in the diffs, and swap between 37s and 40s on the tires. RPM at freeway speeds varies, but it's always around 3000 to 3200 rpm, and with V8 power I'm sure I could easily drive freeway in the 2000 rpm range, if i had another gear.
TTC 1994, TTCC 2012, Trail Tours '05-'10, '12-'13
Member Eldorado Dust Devils, a PNW4WDA member
Treeclimber is online now   Reply With Quote Quick reply to this message
Old 10-10-2019, 09:48 AM   #3 (permalink)
Member # 322985
Thanks for the reply, @Treeclimber. I'm good with the LS, but I don't have much interest in an electronically controlled tranny.
I've got 5.38 gears, and the Atlas is 4.3:1. Tires are 42" Reds, but I do have a set of 40" MTRs (old pattern) for driving on the street. It sees VERY LITTLE street use though.....a few times each summer, I'll drive the family to dinner or out to grab ice cream.
Old 10-10-2019, 10:04 AM   #4 (permalink)
Member # 56430
Pretty sure that 42rle is electronically controlled.
If I had my choices, I'd go LS to 4L80 to Atlas... Not the 4l80e, but the 4l80.
Old 10-10-2019, 10:13 AM   #5 (permalink)
Member # 322985
Yep, the 42rle is electronically controlled. Brain fart on my part. And I also overlooked the 4l80 option, and was only thinking about the 4l80e. Thanks for pointing that out to me.
Old 10-10-2019, 12:18 PM   #6 (permalink)
Member # 616538
Are you sure they made a 4L80 non-e? Im my research, I think they only made the 4L80E. Could be wrong though.
Wisconsinite is online now   Reply With Quote Quick reply to this message
Old 10-10-2019, 12:54 PM   #7 (permalink)
Ak_F250's Avatar
Member # 39826
They didn't. There's no governor or provision for a governor, so shifting has to be controlled electronically or with a manual vb. The th400 was renamed the 3l80 for a few years until the 4l80e came out.
Dont let your rainbow haze cloud your judgment...I know More about alot of stuff most wouldnt think a gay guy would know...
Ak_F250 is offline   Reply With Quote Quick reply to this message
Old 10-10-2019, 01:54 PM   #8 (permalink)
Boomtacoma01's Avatar
Member # 139434
Swap in the TH400 and then use it when you do your LS down the road..
1985 Xtra Cab - 22RE, 39" Red Labels, D60, 14B, 3 Link/4-Link, A340F, Atlas II 4.3, Lone Star Light....
2017 Ram 2500 Crew Cab 4x4, 6.7 tow rig
IG: @boomtacoma01
-Chris
Boomtacoma01 is offline   Reply With Quote Quick reply to this message
Old 10-10-2019, 02:38 PM   #9 (permalink)
Member # 322985
That was my thought as well, @Boomtacoma01. And it'll already be mated to the Atlas (need to swap input shaft on Atlas, and add the adapter).
Old 10-10-2019, 05:14 PM   #10 (permalink)
vetteboy79's Avatar
Member # 31621
Send a message via AIM to vetteboy79
Could also do an AW4 swap and keep your existing Atlas & input all the same, run a standalone shifter for it (several options out there, and continue using it with the LS in the future...
The Alternative Rocker - Taurus SHO V6-powered, Explorer-framed, TTB-front, RCV'd, YJ-bodied east coast racer
Flying Pig Racing #512
vetteboy79 is offline   Reply With Quote Quick reply to this message
Old 10-10-2019, 05:16 PM   #11 (permalink)
Member # 56430
Not sure. I always believed they did, but, after reading your post it sure seems I am wrong.
different thread, but applicable info;
Originally Posted by GOAT1 View Post
If you are going the 4L80 route and want it full manual, no computer. Contact Charlie @ ATD transmissions. They make a valve body to eliminate the electronocs and make it a full manual. I bought one for a customer one time, but dont remember if it was forward or reverse. Not cheap either.
Old 10-10-2019, 05:59 PM   #12 (permalink)
Old School
Technohead's Avatar
Member # 130090
Wait until LS swap. Turbo 350 w/ full manual valve body.
-Eric
Redneck-at-Large
Technohead is offline   Reply With Quote Quick reply to this message
Old 10-11-2019, 07:36 AM   #13 (permalink)
Member # 322985
The TH400 that I have is freshly rebuilt, with a manual valve body. I planned to use it with the LS instead of a TH350.
Old 10-11-2019, 10:16 AM   #14 (permalink)
Old School
Technohead's Avatar
Member # 130090
Cool. Did not realize you already had a th400. I like the th350 because it's a bit shorter. Minor detail, especially for a stretched rig.
-Eric
Redneck-at-Large
Old 10-16-2019, 10:21 PM   #15 (permalink)
wvracer821's Avatar
Member # 260337
This is my vote, you can find AW4s all over the place for scrap price and there is plenty of standalone options from DIY to plug and play since its a very simple solenoid setup to control shifting. That will hold you over without an expensive adapter plate that is useless when you go to the LS. when its time for the repower I like the 4l80E because of electronic control and overdrive.
"Today, I broke my own personal record for most consecutive days lived."
wvracer821 is offline   Reply With Quote Quick reply to this message
Old 10-24-2019, 08:11 AM   #16 (permalink)
Member # 192976
Quick easy swap would be a TF999 from a 97-02 TJ. 42RLE fucking suck balls and I wouldn't swap one into anything if it were given to me.
Personally though I just go ahead and LS swap it, for the effort of a trans swap it may as well have a LS attached to it.
04 TJ - Links, Stretched, Dana 44's, Full Hydro and 38 TSL's
Carolina Trail Blazers
Redneck92 is offline   Reply With Quote Quick reply to this message
