Old NP ring gear new planetary - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-25-2019, 05:59 PM   #1 (permalink)
Member # 175478
Hey guys,
I had a whine in my doubler setup and I was told I put an old style ring gear in and probably a new style planetary. I have pics of the ring gear I used and the planetary I DIDNT use, meaning the other style I put in.
A) do I need to swap it out? Will it blow up?
B) I plan to drive it 700 miles Wednesday.
C) Does it get quieter as they wear in.
06 Hummer H3- 5.3/4l60e/factory H3 4:1. 3 link front, spring over rear. custom D70 front/Eaton HO72 40in STT pros
2017 invited reader Ultimate Adventure
06 H3 is offline   Reply With Quote Quick reply to this message
Old 11-25-2019, 10:28 PM   #2 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Id find a different planetary. Rings are a fucking bitch to get out.
Well youll need an input too.
What spline is yours?
Old 11-26-2019, 03:03 AM   #3 (permalink)
finally fuckin in
sterlingfire's Avatar
Member # 232666
Everything i read when researching what planetary to use said that using any of the old stuff with the new parts would eventually grind itself to pieces.
Originally Posted by 03f350
... Well first off FUCK JEEPS..
sterlingfire is online now   Reply With Quote Quick reply to this message
Old 11-26-2019, 06:46 AM   #4 (permalink)
arse_sidewards's Avatar
Member # 256962
Yup. Gears are only hardened for a few thou at the surface. Once you get through that all hell breaks loose.
Old 11-26-2019, 07:01 AM   #5 (permalink)
Member # 175478
I pulled the t case and swapped the new style planetary for the old style.
I probably put 5 miles on the setup. Do you think it was enough to grind down the hardened teeth surface of the ring gear? There was sparkles in the fluid.
Much quieter!!!
Old 11-26-2019, 07:57 AM   #6 (permalink)
finally fuckin in
Member # 232666
Much quieter!!!
Only one way to find out... pull it again
Old 11-26-2019, 08:10 AM   #7 (permalink)
Member # 175478
I guess I would have to pull it after I put miles on it with the correct planetary setup now.
I had 5 miles on the improper setup. Hopefully it didnít do damage to the ring gear, when I had it out it didnít look bad but I didnít look too close. Wish I had pics of it
Old 11-26-2019, 10:11 AM   #8 (permalink)
finally fuckin in
Member # 232666
So there's a break in years.
94 and down
95 and up
Do you know what years you used?
Old 11-26-2019, 05:28 PM   #9 (permalink)
Member # 175478
94 and down
95 and up
I had a 94 down ring gear and a 95 up planetary. I took the 95 up planetary out and put a 94 down in it
Old 11-26-2019, 07:40 PM   #10 (permalink)
finally fuckin in
Member # 232666
Sounds like you need another donor case. That's a bummer. Hope you get it sorted.
Old 11-26-2019, 08:19 PM   #11 (permalink)
Member # 175478
Why? I put the correct one in?
Old 11-27-2019, 03:55 AM   #12 (permalink)
finally fuckin in
Member # 232666
Lol i misread that
