Critique my 3-link numbers - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-27-2019, 10:02 AM   #1 (permalink)
Member # 113606
Im all set to burn this front 3-link in, would love some insight on if i need to change something. Thanks! 1981 j-20, belly at 23.5, 5in up, 9in down travel currently.
Bump
Ride Height
Fight Crime...Shoot Back.
[SIZE="4"][COLOR="Red"]ΜΟΛΩΝ ΛΑΒΕ[/COLOR][/SIZE]
[QUOTE]Originally Posted by [B]Muddin [/B]
It wasn't a little "achoo". It was "achsshemmiddtpppthpphphphphtsmmmppp...spray".[/QUOTE]
j20brett is online now   Reply With Quote Quick reply to this message
Old 11-28-2019, 09:55 AM   #2 (permalink)
Member # 153241
Which program is this? Looks nicer than the one I’m using. Your CG looks way too high, I measured mine recently and it was 34.7”.
Greg S is offline   Reply With Quote Quick reply to this message
Old 11-28-2019, 11:40 AM   #3 (permalink)
mouse's Avatar
Member # 53906
Interested in the program as well. Any reason not to extend the track bar further out on the axle?
As I live saith the Lord, every knee will shall bow to me, and every tongue shall confess to God.
mouse is offline   Reply With Quote Quick reply to this message
Old 11-28-2019, 11:41 AM   #4 (permalink)
Custom User Title
Provience's Avatar
Member # 138976
is your tie rod going to clear your panhard upper mount if you steer full left/right while at full bump?
If you can, is there space to move the panhard upper closer to the axle?
Provience is online now   Reply With Quote Quick reply to this message
Old 11-29-2019, 08:02 PM   #5 (permalink)
Member # 852104
This is the most recently updated spreadsheet calculator.
pirate4x4.com/forum/general-4x4-discussion/204893-new-version-my-4-link-analyzer-request-help-17.html#post38104162
I noticed something seems off about the front pinion angle calculation. The rear link geometry seems to affect the front pinion angle. I think this is a bug and I sent a PM to Bush65, but its been a few years since he updated it so who knows if hes still around.
I agree the CG seems high. I found a paper about finding the CG of a few stock trucks and they found an F150 to be about 27 or 28 inches.
deepblue.lib.umich.edu/bitstream/handle/2027.42/913/80554.0001.001.pdf?sequence=2
Obviously a lifted truck will have a lifted CG, but that paper gives you a starting point. Because the unsprung weight is not lifted, the CG will raise by less than the lift amount. Larger tires will lift both sprung and unsprung weight, however.
ajm8127 is offline   Reply With Quote Quick reply to this message
Old 12-02-2019, 06:32 AM   #6 (permalink)
Member # 113606
It wont right now, but i plan to trim off the lower bolt hole from the upper and lower panhard mount. I had to move the upper mount out to clear the diff at bump.
I may be able to move the axle panhard mount out to the inner c and attach the ram off of it. Thats whats limiting its location currently.
I didnt calculate the CG height per se, just used the top bell housing bolt as a reference. Ill see what it takes to calc it out.
Old 12-02-2019, 08:41 AM   #7 (permalink)
Member # 196897
I would look for a straight pitman arm and move the track bar and drag ling up a bit. I might be concerned about how far that track bar brackets sits out side the frame if you are going to mount the shock/strut above the axle.
If you can raise the frame side link mounts up.
thedirtman is offline   Reply With Quote Quick reply to this message
Old 12-02-2019, 11:54 AM   #8 (permalink)
Member # 192976
I'd rock it, I would definitely try and get a longer track bar though (Or at least the same length as the drag link). Don't see any reason that mount couldn't be at the C.
04 TJ - Links, Stretched, Dana 44's, Full Hydro and 38 TSL's
Carolina Trail Blazers
Redneck92 is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 07:53 AM   #9 (permalink)
Member # 113606
The drag link is 36.5", panhard is 34.25" right now.
I could move the panhard out to the knuckle, which is about 6" more. Would that not result in more bumpsteer?
