Bump stops....rubber vs urethane vs EVA - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-01-2019, 06:09 PM   #1 (permalink)
Member # 99570
Gents,
I'm needing to buy / install some front bump stops on my samurai. My zuk is heavier than stock...….diesel, frame mods, heavy steel bumpers, sliders....you get the idea..... Guessing my zuk is 2600 lbs or so.....
I have 3.75" of front suspension compression before the leaf springs flatten. I like the OME 5 pack springs and their spring rate. The Bilstein shocks with valving works well too, but still hit my solid-rubber bump stops on hard hits while on the pavement at speed, and on deep holes on logging roads that I haven't slowed down for. The current solid rubber stops are harsh with essentially no compression.
I'm trying to research which ?universal? bump stops would be compressible by at least one inch on these big hits, in my zuk.
None of the manufactures......Daystar, Energy Suspension, etc, etc publish these specs on their products......so I'm left "guessing" if a particular bump stop will fit my needs. A universal bump stop for an F350 sure ain't going to work for my application.....
Any real-world experience on which bump stops are soft and compressible, for a 2600 lb truck?
Hydraulics are not an option for me at this time......keeping my search oriented towards rubber, urethane or EVA springs or stops.
Oh yeah...….something in the 2.5" tall size is what I can easily fit. The "gap" to fit them is only about 5.5" to 6" in height....and within that gap I will need to fit the bump stop and any bracket that needs to be fabbed.
Spokerider is offline   Reply With Quote Quick reply to this message
Old 12-02-2019, 09:42 AM   #2 (permalink)
Member # 213125
Go to any junkyard. It’s literally full of hundreds of nice soft OE bumpstops. Get the ones that fit your requirements. Plus side is they will only cost a few dollars.
Aisin is online now   Reply With Quote Quick reply to this message
Old 12-02-2019, 08:45 PM   #3 (permalink)
lil,yota's Avatar
Member # 102395
Timbren...
That is all
My Dream Build
If you were twice as smart you would still be stupid!
But, as with most evil people, they live unnaturally long lives.
Dr Danger
lil,yota is online now   Reply With Quote Quick reply to this message
Old 12-02-2019, 09:19 PM   #4 (permalink)
Member # 214670
I found some really nice bump stops off of a 2000s Isuzu rodeo. Two bolts and you are done.
Keydet15 is offline   Reply With Quote Quick reply to this message
Old 12-02-2019, 09:56 PM   #5 (permalink)
Member # 53528
same with 80s toyota in the rear, hold up great to hard beatings
Old 12-03-2019, 10:41 AM   #6 (permalink)
desertPOS's Avatar
Member # 3835
Originally Posted by lil,yota View Post
Timbren...
That is all
This.
https://timbren.com/aeon-springs/
They used to have a really good chart showing all the different dimensions with different part #s for different springs, but couldn't find it just now - looks like their site's been updated. Showed stuff like regular dimensions, max deflection dimensions, weight rating, etc. Actually had stats to help build your suspension at full bump, and with the product specs offered, if you got a spring that was too stiff, you could just order the same thing with a lower weight rating.
Special Thanks to:
, West Kern Environmental Consulting,
desertPOS is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 11:32 AM   #7 (permalink)
Member # 5371
Send a message via MSN to rockota
3rd Gen 4Runner rear bumps. They are "progressive" and can be trimmed. Might be worth looking at.
rockota is offline   Reply With Quote Quick reply to this message
Old 12-04-2019, 04:39 AM   #8 (permalink)
YJUnlimited's Avatar
Member # 870338
From my personal experience poly bumps just ended up exploding. Probably changed out 3 or 4 of them.
87 YJ, Unlimited stretch, TPI 350, links, tons, 4D’s, and stuff.
YJUnlimited is offline   Reply With Quote Quick reply to this message
Old 12-04-2019, 06:26 AM   #9 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
I just use shit out oF the junkyard. So stupid cheap and the poly ones like to explode.
RANGERROD is online now   Reply With Quote Quick reply to this message
Old 12-05-2019, 07:55 AM   #10 (permalink)
Member # 149176
Timbren...
That is all
X2 on Timbren
I went through so many polyurethane Daystar ones. One hard hit they shatter.
I moved over to Timbren after doing some research and been racing a few years on them and still look like new.
I would have 2-3 shattered Daystar ones after a race. I contacted Daystar they said they are just not design for hard hits.
The Timbren might be large but they really work.
http://timbren.wpengine.netdna-cdn.c...ns-r070815.pdf
I run the A00540-65
Sponsors:
Corbeau, Tom Wood, PSC, Polyperformance, Inner Air Lock, Miller Welds, Heavymetal Concepts, Clayton Offroad, Baileigh
customcreationsllc is offline   Reply With Quote Quick reply to this message
Old 12-05-2019, 10:07 AM   #11 (permalink)
Member # 83301
timbren are decent if you know the application you need. I am running s10 blazer rear bumpstops as the secondary bump, with smaller hard rubber as the the final stop stop...
'79 chevy k30 vortec 350/sm465/205/205/5.13's 40" NITTO trail grapplers on dirtylife beadlocks.
Old 12-06-2019, 11:28 AM   #12 (permalink)
Member # 29113
Send a message via Yahoo to pitchitpitchit
Timbrens are the way to go.
This is what I used on a TJ and a JK.
Timbren a525-65
https://www.sdtrucksprings.com/index...ducts_id=31546
Here is the Timbren comparison chart
http://timbren.com/wp-content/upload...ring-Chart.pdf
pitchitpitchit is offline   Reply With Quote Quick reply to this message
Old 12-06-2019, 02:20 PM   #13 (permalink)
Member # 3682
Perfect timing guys, looking for some for my CJ7. Just ordered the A525-65s.
cj7jeep is offline   Reply With Quote Quick reply to this message
