SM465 / 203/ 205 all 32 spline - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-03-2019, 11:21 AM   #1 (permalink)
Member # 603617
We got a build going on 76 chevy k10 350 4 speed 205 Dana 44 front 14 bolt rear around 10 inch lift and 38s. I got lots of random parts but we wanna do a doubler and stick to a 4 speed ORD changed there site around and now it's got us confused. So they have a short 32 spline shaft for the 465 from ORD and I have a 32 spline 203 but the adapter to go between the two I'm not sure of. They have a dana 300 adpater they say you just drill the 203 to match? The double for the 205 is simple enough just I haven't seen the short 32 spline shaft version put together, just the long 32 shaft version of the 465. Has anyone on here done this? Or have any pictures, just trying to go as short as possible in a short box chevy
Bad_Larry is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 11:57 AM   #2 (permalink)
Member # 214685
I read the first sentence and that’s where I stopped.
Why people put D44s in front of 14b’s is beyond me. A V8 and 38s is gonna shred a D44.
Byro is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 12:55 PM   #3 (permalink)
clb 017's Avatar
Member # 166307
Phawkin 1 post wonder
Ummm newbie section
If its made in china IT WILL FAIL!
Phawk photofukkit.
clb 017 is online now   Reply With Quote Quick reply to this message
Old 12-03-2019, 01:52 PM   #4 (permalink)
rugburn's Avatar
Member # 45
Yep, it's Tuesday
John Runberg
Swedish American :usa:
rugburn is offline   Reply With Quote Quick reply to this message
Old 12-03-2019, 03:04 PM   #5 (permalink)
Member # 603617
The 44 is just what's in there rite now. I got my built dana 60 underneath my other rig. I dont wanna swap it cause I got a dually one but waiting cause I want to find some srw outters around here instead of buying brand new ones. Then get my link setup onto it
Old 12-03-2019, 03:06 PM   #6 (permalink)
Member # 603617
I kinda used all my good parts on the 69 the dana 60 /14 bolt geared n locked 468 bbc nv4500 and 205
Old 12-03-2019, 09:44 PM   #7 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Originally Posted by Byro View Post
I read the first sentence and thatís where I stopped.
Why people put D44s in front of 14bís is beyond me. A V8 and 38s is gonna shred a D44.
Well. It was a factory combo for 18 years
Ya dont always need a d60.
And sometimes you just got to run what you got.
Fwiw im building a cj for totalgirlfriend with this entire setup. D44 14bff sbc 465 203 205 and will be running 36" @ 4k lbs
Iirc. The 32spl shorty is a clone of the 10spl output so that you could use the oe 465/203 adapter.
A d300 adapter could work but now youll have to plug and redrill the 203 case face.
Old 12-04-2019, 09:52 AM   #8 (permalink)
Member # 603617
Oh nice. I found a couple factory adapters from ebay. It was kinda pricey but I get the rare factor. I'll snag the shaft get the tranny thrown together. I'd rather get that factory adapter that would be sweet, guess I can always sell it if not n buy the dana 300. Re drilling holes ain't bad sense gotta gut the 203 anyway. Thanks tho I'll throw some pictures when I get it all around and the process.
Old 12-04-2019, 05:46 PM   #9 (permalink)
yblow's Avatar
Member # 155086
I have the same setup. The dana 300 adaptor is a little shorter. It wouldn't work on my set up unless I cut 1/2" off my 465 output shaft and I installed the short shaft. Not sure sure if I had a short input shaft. I ended up using factory bracket.
What gears you running?
Anything worth doin rite, is worth doin twice
yblow is offline   Reply With Quote Quick reply to this message
Old 12-04-2019, 07:18 PM   #10 (permalink)
Baldy110's Avatar
Member # 104602
Don't listen to him Larry. I'm running a high pinion Dana 44 with a Detroit, SBC, SM420 and 38" Swampers in a 4000lb rig. I been wheeling the piss out it for 20 years. In all those years of hard wheeling I've only broken a hub. Not everyone needs a D60.
Baldy110 is offline   Reply With Quote Quick reply to this message
Old 12-04-2019, 07:34 PM   #11 (permalink)
Member # 214685
Perhaps Iím biased to the fact my 44 was a money pit that always managed to grenade at the worst of times.
Old 12-04-2019, 08:07 PM   #12 (permalink)
Baldy110's Avatar
Member # 104602
To bad, my experience is It's a stout axle. I'm sure I could break it if I tried to but so far it's held up to a lot of abuse.
Old 12-04-2019, 10:02 PM   #13 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
They have a limit. I rocked mine for a couple years. Then i put a 465 and 36 tsls on a 7k lb truck. Wrecked it every trip.
Weight. Hp. Tire size and traction. All add up.
Old 12-05-2019, 12:50 AM   #14 (permalink)
Member # 603617
Hell that ain't to bad. Rite coulda bwen a tad longer by mistake. I'll definitely try to find the factory bracket.
Running 456 gears deciding on putting a locker in for it or waiting for the 60
Old 12-05-2019, 12:53 AM   #15 (permalink)
Member # 603617
That high pinion is a sweet deal tho my 95 chevy I sas a hp ford dana 60 into front drive line or universal still haven't went
Old 12-05-2019, 06:42 AM   #16 (permalink)
Member # 13786
For WIW I have a factory adapter and a rebuilt 203 range box sitting under my bench that was built for either a 2wd or a divorced t-case. Where you located?
KWTMECH is offline   Reply With Quote Quick reply to this message
Old 12-05-2019, 09:50 PM   #17 (permalink)
Member # 603617
Oh copy probably end up to long tho? Oregon coast
Old 12-09-2019, 08:56 PM   #18 (permalink)
McCracken's Avatar
Member # 41137
Send a message via AIM to McCracken
I have a 465/203/205 set up. I'm not familiar with the short 32 spline version but that would have been nice back when I put mine together. All I can add is that, yes you have to drill and tap the face of the 203 for the adapter to work. I used a (rare to me) 465/205 adapter for a long shaft 32 spline.
[QUOTE=climbit;14733286]you guys take this shit way too seriously.[/QUOTE]
McCracken is offline   Reply With Quote Quick reply to this message
Old 12-10-2019, 08:43 AM   #19 (permalink)
yblow's Avatar
Member # 155086
Is the adaptor for sale?
Old 12-10-2019, 11:06 AM   #20 (permalink)
blatant asshole
total newb's Avatar
Member # 464641
Blazen rockwells has one for sale for $150. Hes not on here much anymore but i can put him in touch with you.
Old 12-10-2019, 11:08 AM   #21 (permalink)
Member # 13786
Let me look around I may have another
Have one----200 shipped CONUS
Old 12-11-2019, 02:38 PM   #22 (permalink)
yblow's Avatar
Member # 155086
Sounds good
