W6FTW
Member # 133266
Rebuilding piggybacks, bleeding trapped air?
About to dive into a piggyback rebuild, specifically a king piggyback. I've worked with remote resis before and getting the trapped air out from the resi is pretty cut and dry.
What about a piggyback? Any ways to bleed out the trapped air? Sent from my SM-G920V using Tapatalk
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Rolling Mod
Member # 22176
I have never played with a king, but I have done shocks with short reservoirs by filling up the bottom of the shock to the top of the resi then jamming the floating piston in. It wastes a bunch of oil and makes a huge mess, but it works.
I can break a steel ball in a rubber room! Companies helping me get dirty: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & Blaine :tank: |
Sponsored Links |
Member # 3775
Yup, what frank said, except I don’t find that I loose any oil or make any mess. It probably depends on relative size of the shock body vs reservoir.
I wheeled twice this year, that might be a personal record. |
W6FTW
Member # 133266
Makes sense. So basically like plunging the piston and the seal head to remove air with a regular shock, you just plunge the ifp on the resi first to get rid of the air.
Thanks! Sent from my SM-G920V using Tapatalk
Thread Tools | |
Display Modes | |
