Let's talk about tall narrow mud tires for 16" wheels. Again - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-08-2019, 08:54 PM   #26 (permalink)
Member # 178200
Originally Posted by Action Fab View Post
I don't want 9" winde wheels. I'm interested in a tread pattern that is more aggressive than a standard MT radial. Basically looking for a streetable alternative to a tractor tire
Dude, you seriously need to come to the realization that this magical skinny ass tractor treaded, super long lasting, high load capacity, great road handling tire does not fucking exist, and pick one of the options you have to work with. You want streetable tires yet run welded diffs and plan on using the truck as construction equipment.......
SLOWPOKE693 is offline   Reply With Quote Quick reply to this message
Old 12-08-2019, 08:58 PM   #27 (permalink)
Member # 188393
Is that the per tire price?
Couldn't tell you. More options Products | Superior Traction LLC
Make a fast friend, adopt a greyhound
conwaymuddy is offline   Reply With Quote Quick reply to this message
Old 12-08-2019, 09:03 PM   #28 (permalink)
Member # 192237
generic cheap bias mud and snows
chains for mud
smaller sizes for better chain clearance
Old 12-08-2019, 09:08 PM   #29 (permalink)
YotaAtieToo's Avatar
Member # 25632
So are they 36" tall when new and 28" tall when they're worn out?
Old 12-08-2019, 09:17 PM   #30 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Why you sound so mad?
Lockout hubs and a spoiled rear drives great when you have 1" thick sway bars f&r with leaf packs 6" thick in the rear.
Action Fab is offline   Reply With Quote Quick reply to this message
Old 12-08-2019, 09:21 PM   #31 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Those are honestly pretty awesome. They have the right sizes. I'd hate to know what they feel like at speeds though.
chains for mud
I need to be able to run down and fill up my transfer tank and welder that go in the bed. I also want to drive it home sometimes without hassle.
Old 12-09-2019, 06:39 AM   #32 (permalink)
today
fredycruger's Avatar
Member # 225557
i like my 11's
fredycruger is offline   Reply With Quote Quick reply to this message
Old 12-09-2019, 09:46 AM   #33 (permalink)
Aggie06's Avatar
Member # 123554
Obligatory farm trucks should have these post.
https://www.petestirestore.com/900-1...525.html<br />
Aggie06 is offline   Reply With Quote Quick reply to this message
Old 12-09-2019, 11:40 AM   #34 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Tried to order SX2. They're unavailable. Went with the Trep instead. We'll see how they work out.
Old 12-09-2019, 01:34 PM   #35 (permalink)
Member # 25632
Boring
Aren't q78 tsls pretty much for this exact set up?
Have you looked at the weight ratings? That trailer you were looking at could have a shit ton of pin weight.
Old 12-15-2019, 09:37 AM   #36 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
Originally Posted by YotaAtieToo View Post
Boring
Q78's are only 35" tall. Would have worked just fine too.
A dump trailer will have a lot of tongue weight. I built my gooseneck hitch further forward than most to hopefully put as much weight onto the front tires as possible. I'm 10" ahead of the axle.
I don't plan to run heavy loads on the road. I have a dually for that purpose.
Tire load ratings have a lot more to do with weight at speed and dealing with the heat of carcass flex under load than it does physical carrying capacity. I feel like for my 5-10mph use on the property, it is going to be a non issue if I do overload them.
I'm still trying to find the trailer used. I am ideally looking for a 83x14' 14k. I found a 12' that's reasonable. But a 16', which is likely to put a huge tongue weight on the ball is also likely too big for dirt anyway. I can find them all day it seems. I've heard they won't lift when filled up with dirt loads so I'm not trying to buy something "big" just to have it be a finicky thing.
I'm probably maxing out with 6-8 yards at a time. If the trailer is 4k lbs and I can carry 6k on the hitch, all should be well.
Old 12-15-2019, 05:58 PM   #37 (permalink)
Member # 25632
I thought q78-16s actually measured 36" tall, so probably taller than the treps, unless they're better than the creepy crawlers. My 37 cc's were maybe 35s
Old 12-15-2019, 06:15 PM   #38 (permalink)
Member # 79509
Hope you're able to turn. Had to put an extension on a dump trailer because it wouldnt clear on a 10ft cab and chassis. Not all goosenecks are built the same.
Black Sheep is offline   Reply With Quote Quick reply to this message
Old 12-15-2019, 06:37 PM   #39 (permalink)
Member # 160338
Could try these and review.
https://images.app.goo.gl/y14DuVuxSGj9AUrP7
Lots of broken,and unfinished projects.
tagjeep is offline   Reply With Quote Quick reply to this message
Old 12-15-2019, 07:31 PM   #40 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
I guess we'll know soon enough. I think they'll be here tomorrow.
Old 12-15-2019, 07:52 PM   #41 (permalink)
Member # 25632
Originally Posted by tagjeep View Post
Their tires are pretty interesting. Looks like recaps. For how aggressive they are, they picked a lot of small sizes though.
Old 12-15-2019, 08:07 PM   #42 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
People don't seem to give their big ones to the recyclers that the recaps are salvaged from.
Old 12-15-2019, 08:17 PM   #43 (permalink)
Member # 25632
I'd still expect to see some 35x12.5r17 and 37x12.5r17s with all the jk's running those sizes.
I'd be curious about the 02 and 03 in the snow on a lightweight 35x12.5r15 carcass.
Old 12-16-2019, 09:36 AM   #44 (permalink)
Member # 177092
I was going to suggest a set of 325/85/16 XMLs if you can find a set that isn't 10 years old, they seem like they would be almost perfect for your application. They are taller than their nominal size and measure out at 38-38.5". I have mine mounted on some 16x7s (I think? They certainly are narrower than 8") unbalanced and they run smooth all the way up over 50 MPH. I paid $150/tire for them with 60-80% tread with the oldest one being 8 years old and the newest 4 years old.
'84 Bronco II is offline   Reply With Quote Quick reply to this message
Old 12-16-2019, 09:58 AM   #45 (permalink)
Member # 25632
That's pretty close to the 11r16 we talked about earlier, maybe a little wider.
Old 12-16-2019, 02:40 PM   #46 (permalink)
Member # 44136
a yard of dry dirt is 2000 lbs. Wet can be close to 3000. If you put that much dirt in a dump trailer it won't dump.
Also, I work in excavation. You don't drive your dump trucks on the dirt. Build a gravel road in and keep your truck and trailer on that. Start at the back and work your way out. Unless you want to spend more time digging yourself out than actually excavating. Your haul road should be 12inches of compacted rock if it's wet out, or it will go to shit as well.
Snowbird13 is offline   Reply With Quote Quick reply to this message
Old 12-16-2019, 03:03 PM   #47 (permalink)
Rooster831's Avatar
Member # 361841
id go with the sx2. 3650lb rating aint bad, but 40s have a 4080lb rating
the 37x12 sx2s i have measure 36.75 mounted, ive also heard that current sx2s are harder than the first few runs they did.
My bumper pull dump trailer will dump 5k lbs of green oak without issue. never struggled with DG or dirt either. 8x12 double axle trailer, nothing crazy.
Spending thousands of dollars on a vehicle for the sole purpose of driving over shit in the woods.
Rooster831 is offline   Reply With Quote Quick reply to this message
Old 12-16-2019, 03:09 PM   #48 (permalink)
Member # 44136
Not 6-8 yards though like op was talking about. 8 yards of wet dirt is over 20k.
Old 12-16-2019, 03:19 PM   #49 (permalink)
Get Off My Lawn
Action Fab's Avatar
Member # 77386
I tried to order the SX2. They're out of stock for an undefined amount of time.
Got the Treps mounted on a 16x6. They measure 36.25" @ 30psi.
Old 12-16-2019, 03:49 PM   #50 (permalink)
Rolling Mod
Beat95YJ's Avatar
Member # 22176
Are you In Australia?
& Blaine
:tank:
