Ruffstuff Y link tierod roll - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-12-2020, 07:22 AM   #1 (permalink)
Mr.RatBastard's Avatar
Member # 9307
I am putting together a early bronco with full width axles out of a 1978 F-150. Iam getting close to putting the steering on. I ordered a Ruffstuff 1 ton GM Y link kit. All good until a friend reminded me he used this setup on a Cherokee and never could get it to drive right and ended up taking it off switching to crossover.
He had a problem with tie rod roll. I started researching it and Ruffstuff sells "the cure" so the problem is real. Why didn't they include it? Anyway before I start cutting and fitting I want to know how likley is it I will have a problem? Will the cure fix it if I do? Should I do something different? If so what?
3.5" lift, 35's-37's, Toyota pwr steering box.
Mr.RatBastard is offline   Reply With Quote Quick reply to this message
Old 02-12-2020, 09:08 AM   #2 (permalink)
welndmn's Avatar
Member # 398
This is not a Ruffstuff issue, but an issue with all Y style steering.
Yes, the Cure takes a lot of loose feeling out of the steering.
Your firend that never got it right, I'm guessing had some other issue. People have been driving with Y style steering for years.
Mark
Old 02-12-2020, 09:18 AM   #3 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
I had that same steering setup on my Cherokee. I had "The cure" installed on it and it was fine. I removed it to see if there was a difference. I didn't notice any difference and just left it off.
desertCJ is offline   Reply With Quote Quick reply to this message
Old 02-12-2020, 10:29 AM   #4 (permalink)
Member # 9307
I agree my friend could of had other issues that contributed to the problem. I know Ruffstuff didn't invent Y link steering but I think they did patent the cure even though Ford had something similar way back when. There must be a issue or they wouldn't sell the cure.
The big question is what causes it so I can avoid it? Too much angle on the drag link or misalignment of the drag link and tie rod(from the top looking down) or more basic parrellel drag link and track bar close to parrellel as possible not being good?
Old 02-12-2020, 03:00 PM   #5 (permalink)
desertCJ's Avatar
Member # 9026
I think that the distance front to back from the pitman arm to the tierod connection point being longer than necessary would cause it to be worse.
Edit: Keep the drag link as close as parallel to the tiered while still having clearance as possible.
Old 02-13-2020, 06:18 AM   #6 (permalink)
_Stucky's Avatar
Member # 182743
My experience with the cure is that I couldnít get the tierod end to seat fully. My truck drives fine with ruffstuff y link and no cure. Personally I think itís a snake oil type thing.
_Stucky is offline   Reply With Quote Quick reply to this message
Old 02-13-2020, 08:36 AM   #7 (permalink)
P.B.A.
RANGERROD's Avatar
Member # 172656
Iíve seen with and without the cure. I know in my friends tj it made a difference since the drag link was at such a steep angle. I think it would roll the tie rod up and down because of this. I imagine if it was more parallel to tie rod you wouldnít see this roll. If that makes sense.
Old 02-14-2020, 06:27 AM   #8 (permalink)
Member # 9307
Ruffstuff said they would swap out the tre's for heims. The new problem that would create is at least 6" difference in length between my track bar and drag link. Keep the Y link, switch to crossover? Any other suggestions?
Old 02-14-2020, 07:08 AM   #9 (permalink)
desertCJ's Avatar
Member # 9026
Keep the Y link. You don't even know if you have a problem right?
Old 02-14-2020, 07:24 AM   #10 (permalink)
Member # 9307
Correct but since I haven't cut or installed anything it wouldn't cost anything to switch to crossover style now if there is less chance of having a problem.
Old 02-14-2020, 11:27 AM   #11 (permalink)
desertCJ's Avatar
Member # 9026
Cross over is fine but isn't it going to cost you a high steer arm and hardware? Is the passenger side knuckle already setup with studs?
Old 02-14-2020, 12:19 PM   #12 (permalink)
Member # 763194
I used the one ton set up and the cure on my Dodge, it never worked well for me. I think the Y link is just a poor design. I switched to Ruff Stuff crossover with all hiems and love it, big difference!
Topar174 is offline   Reply With Quote Quick reply to this message
Old 02-14-2020, 01:51 PM   #13 (permalink)
Member # 9307
I would mount the drag link on top and tie rod on bottom of the knuckle.
Old 02-14-2020, 02:26 PM   #14 (permalink)
desertCJ's Avatar
Member # 9026
I see. I ran that setup with 3/4"x 5/8" hiems before as well. Just have to keep an eye on that nut/bolt, make sure it stays tight. You may run out of angle on the drag link hiems depending on your setup. It worked fine for me though.
