Where is the 4-link analyzer? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-04-2004, 10:29 AM   #1 (permalink)
Member # 15727
I have searched through A LOT of pages and I could not find it. Does anyone happen to have it saved in there favorites and could post a link?
Whats the story with the search button anyway?
team #313 Rock Diamond Racing
Specail thanks to the4x4place.com
thejeepjeepkid is offline   Reply With Quote Quick reply to this message
Old 08-04-2004, 11:39 AM   #2 (permalink)
Member # 12516
Send a message via Yahoo to Lt1Cj7
http://www.isd623.org/ben/jp/fourlink/index.cfm
Lt1Cj7 is offline   Reply With Quote Quick reply to this message
Old 08-04-2004, 12:33 PM   #3 (permalink)
Member # 5110
http://home.earthlink.net/~triaged/Files/
Link to thread on my calculator https://www.pirate4x4.com/forum/showthread.php?t=204893
Triaged is offline   Reply With Quote Quick reply to this message
Old 08-08-2004, 07:01 AM   #4 (permalink)
P&T Jeeps's Avatar
Member # 3916
I need a bit of help w/ this calculator, I've had success w/ it before, have the majority of the info filled in, but for some reason I can't figure out what to put in the below categories (i realize if you put the curson over the box it further explains the input variable but these are cut off so I can't figure them out):
CoGX: measurement from center of axle to roughly the bellhousing/motor junction?
CoGY:
CoG Height: measurement from ground to roughly the top bellhousing bolt?
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB...
P&T Jeeps is offline   Reply With Quote Quick reply to this message
Old 08-08-2004, 08:08 AM   #5 (permalink)
Member # 32963
Send a message via AIM to ridefast
CoGY: center of gravity distance from center of axle towards tire
positive moves it towards right hand (passenger side) and negative values move it towards drivers side
CoGX: distance from center of rear axle forward
CoG: height of center of gravity from ground
im assuming that the measurements are for overall weight distribution, or center of gravity, not really to the bell housing, but i could easily be wrong
ridefast is offline   Reply With Quote Quick reply to this message
Old 08-08-2004, 02:01 PM   #6 (permalink)
Member # 5110
In the excel version that I made only the "CG Z" does anything...I have no idea why I even put in the others?
On the HTML one having the others will calculate the roll over angles...but I think these guys did a better job of it then I could.
http://www.jeepaholics.com/tech/cog/
