Will this A-arm hold up? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-17-2004, 07:19 PM   #1 (permalink)
desertCJ's Avatar
Member # 9026
Send a message via AIM to desertCJ
http://community.webshots.com/photo/...72036090uSglMH
This is the upper A-arm for my front suspension. I have already put some 3/16" gussets on the part the Axle rod end screw into. It is 1 1/4" schd 40....some of you might scoff at that but you can blow me The only thing I can think of to make it stronger is to weld in some tubes from the crossbar to the start of the bend? This thing is a TIGHT fit underneath my dual sump 5.0 oil pan So is it gonna wad up or will it do?
desertCJ is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 07:40 PM   #2 (permalink)
Keith's Avatar
Member # 52
You give me shit huh..... I think it will taco at the crossbar.
Rockzombie Smurf
Keith is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 07:49 PM   #3 (permalink)
desertCJ's Avatar
Member # 9026
I give you shit.......you give me shit, that's how it works man
So, why do you think it will buckle at the crossbar instead of bending in the bends? Like I said, I do have room to run some tube from the front of the a-arm back to the crossbar. If it wasn't for the dual sump of my oil pan than this wouldn't be an issue at all! I know I could build a standard a-arm...but I'm working with some tight spaces because I'm keeping the ride hieght as low as possible.
Old 08-17-2004, 07:50 PM   #4 (permalink)
1972CJ5+1's Avatar
Member # 15811
I said the same thing about sch40 until the other day. I was trying to bend some for shock hoops and the thing ripped apart in the bender. Mine was 1.9 sch40 in a 2" die protools 105 bender. I'm sure this was a freak deal, but I could not immagine what would happen to you if this happened to your a-arm. We have bent all sorts of sch40 for stingers, sliders, etc without issue, but this made me think twice.
[COLOR="Lime"][SIZE="3"][B]booger weldz [/B][/SIZE]alternate account[/COLOR]
1994 fzj80 Elockers front and rear, 35 km2s, 10k winch, coolest station wagon in the world!!
[COLOR="Silver"]♣[/COLOR][B][COLOR="Lime"][FONT="Arial Black"][B]Bink'sFab[/B][/FONT][/B][/color][COLOR="Silver"]rication[/COLOR][COLOR="Lime"]♣[/COLOR] -
1972CJ5+1 is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 07:53 PM   #5 (permalink)
desertCJ's Avatar
Member # 9026
I don't know man...I made my ENTIRE chassis from schd 40....so I've made HUNDREDS of bends without a single f up. What spec was your pipe? A53A?
Old 08-17-2004, 08:00 PM   #6 (permalink)
BadAZYj's Avatar
Member # 6815
Looks kinda weak to me, but Im no expert. I for one wouldnt put it on my rig... I might use it to plumb a sink into my garage though
Well this sucks...
BadAZYj is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 08:16 PM   #7 (permalink)
ZJim's Avatar
Member # 24099
Send a message via AIM to ZJim
That would make a totally sweet bong!
ZJim is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 08:50 PM   #8 (permalink)
pissnmetal
StudNuts's Avatar
Member # 12035
Send a message via AIM to StudNuts
I think if you continued your tube from the top of the a-arm down to that crossbar, that would hold the bends in the 'a' from trying to push or pull.
I'm just a dude playing a dude pretending to be another dude.
StudNuts is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 09:06 PM   #9 (permalink)
desertCJ's Avatar
Member # 9026
If your talking about right down the center.....then that is out of the question. The oil pan is in the way......the rear sump is behind the crossbar and the front sump is in front of the crossbar. This was the only way I could think of to build the a-arm without hitting the oil pan or lifting my buggy sky high.
Old 08-17-2004, 09:21 PM   #10 (permalink)
fcfred's Avatar
Member # 3263
why not triangulate your lower links and make your uppers straight?
Team Tank
old junk, new junk, unfinished junk
Live Large-RIP Jason Payne
fcfred is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 09:27 PM   #11 (permalink)
Keith's Avatar
Member # 52
Would having the bars relatively straight at the frame mount, would that put a good amount on lateral forces on the joints? All you can do is try it. If it bends, it bends......no big. If you use it, I would put a large plate over the crossbar joints to spread the load over a larger area.
Rockzombie Smurf
Old 08-17-2004, 09:28 PM   #12 (permalink)
desertCJ's Avatar
Member # 9026
No room. I guess I could have done it that way, but my drivetrain would've had to be quite abit higher or the bellypan lower. I also have ALL the brackets fabbed and welded already.....this is the last piece. Basically the two options are brace the bends or run it......from what I'm hearing and what I was kinda thinking, I'm just gonna brace the bends. That's all I can do without basically starting from scratch(Actually more work than scratch) on the front suspension!
Old 08-17-2004, 09:31 PM   #13 (permalink)
desertCJ's Avatar
Member # 9026
I don't think so, because the lateral forces are translated into push/pull forces. Think about it
Old 08-17-2004, 09:42 PM   #14 (permalink)
Bushwhacker's Avatar
Member # 9138
Send a message via ICQ to Bushwhacker
Glad I'm not the only one going through that crap right now.
I wanted to run a triangulated 4 link on my TJ and keep it low, but the oil pan/d shaft and exhaust are in the way. Thought about triangulating the lowers at the axle but the mount would have been a pain to make.
Ended up making an A arm and 3 linking it. I was either going to run a straight arm A or miter cut them and run them straigth down the frame like you did and then bend into the heim. I opted for a standard A shaped arm so its should be strong enough. I would gusset the hell out of yours tho.
WEROCK Judge
RROCK Legends Competitor
97 TJ buggy,4.0,727,Atlas,D60,14B
Bushwhacker is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 09:43 PM   #15 (permalink)
bgreen's Avatar
Member # 9801
Pro-Tools sells dies for 1.5" pipe (1.9 OD) should make alot nicer bends.
the tube riping apart... I think I remember some people on here having the same problem with regular tubing as well. Does anyone have that thread handy?
[CENTER]Project Freak - Resurrection[/CENTER]
bgreen is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 09:46 PM   #16 (permalink)
Keith's Avatar
Member # 52
not when you try to turn the steering, or are off camber.....right? That piece is going to be what is holding the body over the center of the axle. Why could you not use a four link setup, and use urethane bushings on one end of the upper links to keep them from flopping down cuz of the bends. Then you may be able to spread the bars apart a bit at the axle bridge, and take some of the bend out.
Rockzombie Smurf
Old 08-17-2004, 09:55 PM   #17 (permalink)
bgreen's Avatar
Member # 9801
what about something like this... Pretty crude drawing, sorry. The red represents some 1/8 plate wrapped around the top and bottom 1/4 of the tube, to kinda double up the wall thickness on the bend plane.
Old 08-17-2004, 10:00 PM   #18 (permalink)
desertCJ's Avatar
Member # 9026
I'll brace the bends with some tube back to the crossbar and then some other stuff if I can fit it. I got what I wanted out of this thread, which is basically make it as stout as you can. I can make it stouter....so I will I am really against changing the overall suspension design at this point though.
Old 08-17-2004, 10:14 PM   #19 (permalink)
TRD
TRD's Avatar
Member # 8286
why not change your suspension to parallel uppers with the lowers triangulated at the frame?
That might fit a little better for you?
Ryan
Phone: 424-377-0808
Email: [email protected][websiteURL]
Shop
- Custom Spring and Valving Specialists
See what we're up to:
Coilovers, IBP's, Bypasses & Adjustable Shocks In Stock
Now Hiring - Technical Sales Rep
TRD is offline   Reply With Quote Quick reply to this message
Old 08-18-2004, 09:21 AM   #20 (permalink)
desertCJ's Avatar
Member # 9026
Old 08-18-2004, 10:17 AM   #21 (permalink)
GOAT1's Avatar
Member # 5969
Needs more triangulation
But seriously, I dont think it will break, but it might flex and let the front end wander when you steer.
GOAT1 is offline   Reply With Quote Quick reply to this message
Old 08-18-2004, 10:46 AM   #22 (permalink)
desertoy's Avatar
Member # 292
I think the welds will eventually start cracking at the center heim boss.
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
2008/2009 W.E. Rock West Coast Series Champion
2008 Pro Rock Champion
Just "HAMMER" it!!
My Buildup
desertoy is offline   Reply With Quote Quick reply to this message
Old 08-18-2004, 10:47 AM   #23 (permalink)
TRD
TRD's Avatar
Member # 8286
missed that one
Ryan
Phone: 424-377-0808
Shop
Old 08-18-2004, 12:23 PM   #24 (permalink)
Pook's Avatar
Member # 3370
you have to make sure you keep the weld positioned so its on the top side of the tube. not on the outside of the bend, and i know you can get away with it on the inside sometimes, but in any postioion other than on the top or bottom of the tube (in relation to the dies) the weld does not need to majorly stretch or shrink. The only time tubing or pipe breaks on me is when i am asleep at the bender and forget.
:grinpimp:
Pook is offline   Reply With Quote Quick reply to this message
Old 08-18-2004, 01:29 PM   #25 (permalink)
desertCJ's Avatar
Member # 9026
I have/will have hydro steering. I did some work on it and I'll get a pic of how it looks now.
