POS chevy CPI 95 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-17-2004, 10:47 PM   #1 (permalink)
xtrm-s10's Avatar
Member # 13452
Send a message via AIM to xtrm-s10
Unhappy POS chevy CPI 95
Ok I know that There have been posts on this subject before. I have a 95 jimmy with a CPI motor or the "w" code on the vin. I that there is a problem with the injector on this motor. In the last 11,000 miles or so I have put in 4 of these things in my truck. It is getting to be a pain in the A$$. Dose any one have any Idea why.
Here are some of the things that I have also replaced
new fuel filter
new fuel pump
filter in the tank (strainer)
Can any one help with this it is getting to the point that I dont want to take out of the driveway.
a case of beer your choice for the right info
Brian Wakefield
xtrm-s10 is offline   Reply With Quote Quick reply to this message
Old 08-17-2004, 11:06 PM   #2 (permalink)
crash's Avatar
Member # 1588
new fuel filter
new fuel pump
Brian Wakefield
What exactly is it doing? loosing fuel to one cylinder? Regulator blowing out? We have nothing but problems with these things... Are you replacing it with OEM stuff or you going reman crap?
Mike Crash Kash
Old 08-17-2004, 11:16 PM   #3 (permalink)
xtrm-s10's Avatar
Member # 13452
ok the first one was good for 127000 miles. I now have 138... I am replacing them with ac delco parts. It has a good idle, good start. it falls on its face from appx 1,000 -2,200 RPM. Some times at start up it will spit and sputter a little. It will often die and then restart from motor still turning. Sometimes after it dies it will start and some times it wont.
Old 08-17-2004, 11:18 PM   #4 (permalink)
xtrm-s10's Avatar
Member # 13452
is this a fuel delivery thing or electric ?
It is driving me nuts
Old 08-17-2004, 11:20 PM   #5 (permalink)
Member # 3132
bottle of liquid sea foam into the tank, run it. it cleans the injectors, brothers truck did the same till we poured in a bottle. deposits clog the injectors. the newer cpi have larger injectors that are white or transparent white in color, the older poop ones are black.
Old 08-17-2004, 11:26 PM   #6 (permalink)
xtrm-s10's Avatar
Member # 13452
Is that ta the end of the injector (6 of them)
Where do I get that from " liquid sea foam"
Old 08-17-2004, 11:49 PM   #7 (permalink)
crash's Avatar
Member # 1588
Sounds more like you are having egr issues...
We also have problems with the check valve in the fuel pump and the fuel pump (actually more common in all GM high pressure pumps, GM can't build one to save there life, but thats ok, keeps me busy at work,lol)
Mike Crash Kash
Old 08-17-2004, 11:51 PM   #8 (permalink)
xtrm-s10's Avatar
Member # 13452
so then why would it start right after I put in a new injecter?
Old 08-17-2004, 11:58 PM   #9 (permalink)
crash's Avatar
Member # 1588
probably because you primed the heck out of it when you removed the old one (fuel coming out of the nylon fuel feed lines)...
Mike Crash Kash
Old 08-18-2004, 12:01 AM   #10 (permalink)
xtrm-s10's Avatar
Member # 13452
it will run good for like 2-3000 miles os I dont get it
Old 08-18-2004, 12:03 AM   #11 (permalink)
crash's Avatar
Member # 1588
A borderline pump will do that, pesky little fuckers...
Mike Crash Kash
Old 08-18-2004, 06:23 PM   #12 (permalink)
xtrm-s10's Avatar
Member # 13452
ttt
Old 08-18-2004, 06:34 PM   #13 (permalink)
Member # 3132
kragens, autozone, you want the liquid, not the aerosol. it is white can with red letters. we fixed my brothers with it, and a customers 96 tahoe. it really did work, with no other additives or work. it is that, or replace all 6 injectors at 100 buck a peice, or find a 2002 or newer (i would guess for updated injectors) so in a wrecker and buy the upper plenum with injectors. sometimes the injectors are covered by the dealer but only under a extended warranty, it is a service bullitin but not a recall. must be the truck it came in, and must not have a check engine light on, or other issues causeing the miss. i
It usually shows up more of a miss, off of idle, if whipping the gas pedal a bit, and if trying to go faster than 90 in a 5speed truck.
another problem with the cpi is the throttle body, if the accelerator ever sticks on you there is a little cup type thing spotwelded to the underside of the little butterfly in the t.b. and it will occasionally snag, and eventually break one of the welds and have to be removed, if it rips the butterfly thingie you have to weld the holes, or idle will be high, and slower engine braking.
Old 08-18-2004, 06:47 PM   #14 (permalink)
xtrm-s10's Avatar
Member # 13452
Thank you for the input guys
I drove it to work today and was lucky to even make it home, it died twice. Is there anyony here that works for a chevy dealership ( machinic) and has had some dealings with this. I was thinking of taking it to the dealer and having them figure it out, but that is a last resort.
Brian Wakefield
Old 08-18-2004, 08:01 PM   #15 (permalink)
crash's Avatar
Member # 1588
Brian Wakefield
I don't think you willl wanna drive it to seattle though
Mike Crash Kash
Old 08-18-2004, 08:47 PM   #16 (permalink)
xtrm-s10's Avatar
Member # 13452
how about if I cut it up into small pices and send it to you
Old 08-18-2004, 10:28 PM   #17 (permalink)
crash's Avatar
Member # 1588
I can see my wife now, hon, you got 75 boxes on the porch
Mike Crash Kash
Old 08-18-2004, 11:14 PM   #18 (permalink)
xtrm-s10's Avatar
Member # 13452
yea but they are all under 70lbs for the ups man.
So what are all of the things that can be wronge with my POS
Old 08-18-2004, 11:35 PM   #19 (permalink)
crash's Avatar
Member # 1588
CPI failures We see more failures to the popet valves on the injector than anything..
The nylon lines that hook into the injector crack
We have carbon deposits hanging open the egr valve (buildup where the intake and head meet breaks loose and thats where the carbon chunks come from).
Fuel pumps failing
Those are the things I see under a regular basis
Mike Crash Kash
Old 08-18-2004, 11:41 PM   #20 (permalink)
xtrm-s10's Avatar
Member # 13452
the last one has only 600 miles on it do you thank that the sea foam thing will work. or should I soak it in some cleaner.
Old 08-18-2004, 11:43 PM   #21 (permalink)
xtrm-s10's Avatar
Member # 13452
I dont know if the place that I got the part from will give me another one. If they do it will be the 5th one
