check out this Dana 70 front - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-25-2002, 09:54 PM   #1 (permalink)
Member # 1476
closed knuckle 70 thanks to Dave Bergerson
livermore2 is offline   Reply With Quote Quick reply to this message
Old 01-25-2002, 09:57 PM   #2 (permalink)
Member # 2521
old Dodge? Low spline count? D44 U-joints?
Looks purty, somebody must be fixing the weak links
Slagburn is offline   Reply With Quote Quick reply to this message
Old 01-25-2002, 09:58 PM   #3 (permalink)
Member # 1476
tracta joints
these are Tracta Joints, no their not u-joints and no their not big birfs either
Old 01-25-2002, 09:59 PM   #4 (permalink)
road1will's Avatar
Member # 8871
Send a message via AIM to road1will
yeah those are strong. what truck did that axle come out of?
road1will is offline   Reply With Quote Quick reply to this message
Old 01-25-2002, 10:01 PM   #5 (permalink)
Member # 1476
here is a 44 next to this 70
now look very closely at the size difference
Old 01-25-2002, 10:02 PM   #6 (permalink)
Member # 6708
Can you unlock the Hubs or are they a fixed hub plate?
Looks like there are no roller bearings, how does it deal with friction when the steering is full left/right?
Looks BIG
Eric
'There will be pork in the tree tops by morning!'-Lion in Winter.
'Dear,dear.....what ever shall we do with mother.'-Lion in Winter.
"Mr. President, We must not allow, a mine shaft gap!"-Gen. 'Buck' Turgidson
'Do you expect me to talk Goldfinger?' 'No Mr. Bond, I expect you to Die!'
Alpo is offline   Reply With Quote Quick reply to this message
Old 01-25-2002, 10:22 PM   #7 (permalink)
Member # 14
Re: here is a 44 next to this 70
What are you comparing it to there, a 60 shaft??
Cliffy [JD] is offline   Reply With Quote Quick reply to this message
Old 01-25-2002, 10:23 PM   #8 (permalink)
Hayraker's Avatar
Member # 5946
Looks like they would be super strong as long as you always drove in a straight line, maybe weak when you cut the wheels. If anybody else wants something like that, skeetshooter has a big ass Napco front with the same tracta joints.
I.R.B.S.T.M.
Hayraker is offline   Reply With Quote Quick reply to this message
Old 01-25-2002, 10:29 PM   #9 (permalink)
Member # 2757
Yo moss, is that for your Yota bro? SAWWWEEEEET
ESREVER NI EVIRD
SMART ASS is offline   Reply With Quote Quick reply to this message
Old 01-25-2002, 10:35 PM   #10 (permalink)
Member # 1476
yes old Dodge but it has no u-joints!
Old 01-25-2002, 10:39 PM   #11 (permalink)
Member # 1476
came out of a 2 1/2 ton Dodge 4x4 driller/concrete buster, this thing has never seen the street, it was trailered from jobsite to jobsite.
Old 01-25-2002, 10:43 PM   #12 (permalink)
Member # 1476
Looks BIG
Eric
yes it has warn hubs just like a 60, the main and stub axles rest on bronze bushings, there are no bearing in the tracta joint, just thick meaty slabs of steel
Old 01-25-2002, 11:29 PM   #13 (permalink)
Member # 347
Ok... so a 44 is smaller than a 70? Whod-a-thunk?
Ya gotta give us a picture that makes better sense, too. Show us a shot into the mouth of the Tracta joint, with a Dana 60 u-joint uncapped for reference... I'm curious about the difference in cross-sectional mass, 4 trunions vs. (effectively) two plates. Tough to compare 'em, actually, since the Tracta engages from the pivot of the joint on out on one axis, and from the 'caps' on in on the other... and a u-joint engages at the caps, with a secondary pivot across the center of the joint's cast body.
Don't get me wrong -- a seventy is a sweet axle, but the closed-knuckle 70s are a compromise over the open knuckles, both in turning radius and most likely, ultimate strength. When you break the axles, drop in a Spicer-style set of axles and u-joints.
Randii
[B]
[/B]... you pick up after your dog, so clean up after YOU, too.[I][SIZE="1"]
- [B]VIRTUAL RALLY[/B] for the HAMMER TRAILS in JOHNSON VALLEY
- [B]VIRTUAL RALLY[/B] for TELLICO
and
- [B]KOH Pledge Drive:[/B] for
[/SIZE][/I]
randii is offline   Reply With Quote Quick reply to this message
Old 01-26-2002, 01:54 AM   #14 (permalink)
Member # 7646
Ok so how does that tractor joint work??? I cant picture it working like how I can with a norem U joint
85 suzuki sj 410, 82 suzuki sj 410 pickup 68 IH pickup, 78 Scout II
76 Scoutt II turbo 345 propane
Chief yelling alot is offline   Reply With Quote Quick reply to this message
Old 01-26-2002, 05:30 AM   #15 (permalink)
Member # 1476
Re: Re: here is a 44 next to this 70
Randii
Scott Kurtzer, a good friend of mine (who Mike Schaffer used to work for) says these are much stronger than a 60 U-joint. if a 60 was stronger beleive me i would use one. 60s are much easerier to find than these. these joints were VERY expensive for Dana to build, they were hand carved on a lath, unlike a 60 joint. thats why they didnt make too many if them. i dont think i will be breaking these joints but if i do i also have a set of spares and i will make the same joint next time out of 4140. i wont be running 60 style u-joints anytime soon! i only had a 44 lying around to compare the size so you can get an idea of the strenth of this joint.
Old 01-26-2002, 09:52 AM   #16 (permalink)
Member # 6708
What are the spline counts for the shafts inner and outer?
Eric
Old 01-26-2002, 09:56 AM   #17 (permalink)
Member # 1476
on this front the spline count is 23 inner and outer and on the rear axle its 35
Old 01-26-2002, 10:07 AM   #18 (permalink)
Member # 6708
ok, since it's obviouse the pitch is courser than the D-60 what is the diameter of the shafts? being courser I can't get a mental image of relative size. I would hope it is at least as big of a shaft as the D-60 or you wouldn't be going through the trouble of puting this under a Toy
You got your own mill for making those steering arms or did you have to use one that a friend had?Just curiouse, I work as a machinest.
Eric
Old 01-26-2002, 11:02 AM   #19 (permalink)
Member # 1476
shafts are 1 1/2'' same as a 60. the lathe belongs to Dave Bergerson. he is the master mind behind this whole project!
Old 01-26-2002, 01:50 PM   #20 (permalink)
Member # 347
Re: Re: Re: here is a 44 next to this 70
...these are much stronger than a 60 U-joint.
Well, I disagree, but I have only held the parts in my hand and compared them visually... I haven't run them. It'll be interesting to see how they hold up for you. Older Toyota Cruisers used a similar technology in their axle joints, and those were weaker than the same size Birfield, and coarse-splined, to boot.
Ummm.... that's a comment on the production process, to me, more than the strength.
If you go through these like most of us go through Birfields, be prepared to get some ribbing!
Props to you, though, for trying to do something a bit different than the crowd of folks going after those stylish 60's or Rockwells.
Randii
Old 01-26-2002, 04:52 PM   #21 (permalink)
Member # 6708
Master mind or Lunatic ?
Eric
Old 01-27-2002, 11:06 PM   #22 (permalink)
Member # 1476
t
[QUOTE]Originally posted by randii
are you sure you were holding a 70 and not a 44 or 60? how many times do i have to say these are nothing klike a 44 or 60 setup the toyota LC had a joint that looked like a close knuckle 44 or 60. nothing like this! i woulnt run a closed knuckle 60 if you paid me! those things are WEAK
Old 01-28-2002, 01:58 AM   #23 (permalink)
Member # 5790
I would run them if you paid me!!!! it just depends how much
jeeper111 is offline   Reply With Quote Quick reply to this message
Old 01-28-2002, 02:11 AM   #24 (permalink)
fcfred's Avatar
Member # 3263
mossberg,
how come you're running 23 spline inners and outers?
it seems that if you're going to the trouble of getting custom shafts you should be able to upgrade to 35 splines
or don't they make a 35 spline side gears for a 70?
maybe the current shafts are from dana and the custom ones out ouf 4140 will be 35 spl?
i think your axle is bad-ass and I would trade my 60 for it any day
lets see more pics!
tractas are dope!
Team Tank
old junk, new junk, unfinished junk
Live Large-RIP Jason Payne
fcfred is offline   Reply With Quote Quick reply to this message
Old 01-28-2002, 09:00 PM   #25 (permalink)
Member # 1476
i dont have the $ for custom shafts, i have to run stock for now. but if and when i break i will use 4340!
