Member # 13526
NV4500 lower cover leak???
I picked up this NV4500 off a fellow board member a little while back. Its got a small leak from the lower cover on the front. I got a good deal on the tranny so the leak doesn't bother me.
Its the silver dollar sized aluminum cover in the pic below. Yeah, below the input shaft cover. The question: Is there and easy way to just pop/pry that cover out to seal it? Anyone have a similar issue? This is a Dodge case purchased from AA originally. I need to get this thing sealed up before I bolt it to the Atlas and drop it in.
Scotty To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 970-420-4198 |
Member # 613
that plug covers the bearing race for the lower shaft, when I bought the trannys that I built the one in my dually with one had silicone on one j/b weld on the other. When I put the tranny back together I used a good silicone to set the plug back in.
Sponsored Links |
#3 (permalink) | |
Member # 13526
Thread Tools | |
Display Modes | |
