Member # 7226
Composite Fairlead??
Just ordered my Amsteel Blue, and needed a Fairlead for my M8000, wanted to know how the RBS fairlead are holding up? I did a search but just found info on it ,not any real info on how its held up to alot of abuse. So which way should I go Composite or Aluminum fairlead?? Thanks for the help
Member # 9801
All the composite fairleads I have seen (even the one I built) have substantial damage from what appears to be heavy up, down, or side pulls. The material compresses, and leaves a dent. They also deflect under moderate up and down loads allowing the rope to rub on most winch bumpers.
[CENTER]Project Freak - Resurrection[/CENTER] |
Sponsored Links |
My composite has held up well, but it does flex...I enlarged the bumper opening behind it just in case it flexed into the metal. The bottom side of it is well scratched from rock rash as well...however, there are no sharp edges to abrade the rope.
My alum one ended up with a few sharp edges after some rock contact. IMO, each has advantages and disadvantages....
Brian 'woody' Swearingen - IH8MUD Inc. '74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR |
Member # 2042
Why not combine what Malltero and Woody have done. Open up the hole on your bummper behind the fairlead AND weld a piece above and below the fairlead to add strength?
I had an aluminum one for my warn that I got from Spidertrax... Worked well...
Mike |
Member # 14004
How do the composite fairleads do in mud? I've got aluminum now and its fine in the dry, but after a heavy down pull at a mud pit I found chunks of pretty blue plastic stuck to the fairlead!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - TBI 304/T18a/D300/60/70/5.86/43's 87 Samurai - GSX carbs/16V 1.6/GRS-II/linked rear/31's |
Member # 1516
The first time I got to use my new rope and fairlead the Amsteel Blue sliced right through the plastic and got cut on the piece of angle used to support it
![]() Go aluminum. Tass
Nothing to see here, move along............. |
that guy
how about i start making better composite fairleads out of say solid teflon or delrin. the ones u guys are buyin are made outta good old UHMW plastic oil impregnated material it will score pretty good delrin or nylon will not do that and it won't deflect so bad. how many should we start makin, and what colors. LOL
#12 (permalink) | |
Member # 14004
2) It gets burrs if you hit a rock.
#14 (permalink) | |
thhhpptthh!
ding ding ding....
nail... head...hit. ![]()
My mom wrote a kids book! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Quote:
#15 (permalink) | |
Member # 14004
Will the insert hold up under heavy up/down loads? Will it reduce damage to my synthetic rope in muddy conditions?
#17 (permalink) |
Details on the RBS fairlead: https://www.pirate4x4.com/tech/billav...ead/index.html
you could try following up with billavista to see how it's held up in the last year.
"OBie" CalRocs 2010 #5150 Last edited by YJ_OVER_SJ; 09-17-2004 at 12:31 PM. |
#18 (permalink) | |||
Member # 33730
Still waiting for some pictures . As far as mud , I don't know . Quote:
I would like to find a vendor that is more into the selling part to sell them , I rather just make them . Quote:
#19 (permalink) | |
You have a pretty good idea there but I'd be worried about a few things like: 1. the composite center popping out of the aluminum fairlead under load or being pulled in to the winch drum, 2. temperature changes causing expansion/contraction of the aluminum causing #1. 3. replacement of the center in case of wearing or cracking or other unknown issues? 4. Cost $?$?
"OBie" CalRocs 2010 #5150 |
#22 (permalink) | |
thats nice! where can I get one from? and how much are the replacement composites?
#23 (permalink) | |
Member # 34756
![]() ![]() Be sure to make a vendor thread when you've got those bad boys for sale somewhere. And thanks for doing what you do ![]() Walt<><
<>< Worthy is the Lamb that was slain to receive power, and riches, and wisdom, and strength, and honour, and glory, and blessing. |
#24 (permalink) |
Nose to grindstone
Thats an interesting idea~however arent you worried about the friction caused by the lack of radius on the composite material?
We also have a new lead coming out with a nickel empregnated teflon coating that is 35rc
MFGS of the STAR-LAB CNC machines The finest CNC plasma tables Made in the USA by Bulltear and can be found online at To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. and at local welding stores Hypertherm and Thermal Dynamics We also make parts for AMC To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Thread Tools | |
Display Modes | |
